Trade: Hardwood flooring contractor
Backsplash Caulk
Just finished a back splash (marble) and cntrtops (ceramic tile).. all 12x12's and i want to caulk the transition from the countertops to the backsplash. What should i use? Silicone? Latex caulk? the latex with silicone caulk. Im assuming i want something with a mildicide (sp?) also?? I obviously need something that's water RESISTANT. Thanks
Chris Frate Pasquale Floors |
Trade: Kitchen & Bath dealer/remodeler
Re: Backsplash Caulk
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems." Margaret Mead |
Trade: General Contractor, Remodeler
K+B silicone.
It's all about the Avatar
Trade: I have no face!
Silicone, mildew resistent, clear, hair line bead..................happy customer.
#5 | |
Remodeler Extraordinare
Re: Backsplash CaulkQuote:
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor |
My vote: Mildew resistant clear silicone
- Build Well - |
this is the exact product we use
http://www.homesupplies4u.com/tilegrout_caulk.htm Moisture and mildew resistant Siliconized 4 Unlimited colors Moisture and mildew resistant
Trade: Residential General
If you want a very nice clean line, mask either side of the caulk joint to leave the size you want and then caulk. I picked up that trick from granite installers. The brown paper mask about 2 1/2" wide works pretty well. It's gummed only on one edge like a post-it note. It works very well for masking straight lines in this application.
#9 | |
Thanks for the info...I bookmarked the link you provided
- Build Well - |
A.W.. that's the product that i used..it was sanded and was color matched to my grout. I actually filled it with grout first.. let it dry for 2 days then used the caulk... we'll see....thanks for the info guys..
| Caulk flat panel doors in cabinets? | cstrombe | Painting & Finish Work | 8 | 02-25-2007 06:04 PM |
| Best exterior trim caulk | wackman | Painting & Finish Work | 13 | 02-14-2007 09:11 AM |
| trim coil window stops ,casing, quad caulk for sale ..closing shop | window man | Contractor Swap | 7 | 07-05-2006 09:46 PM |
| Ceder siding to caulk or not to caulk??? | Dave Mac | Painting & Finish Work | 10 | 05-26-2006 09:33 PM |
| How to get caulk in a real tight spot | ProWallGuy | Painting & Finish Work | 19 | 04-11-2006 06:04 PM |
