Trade: CARPENTER CONTRACTOR
Alco Siding ???
Has anyone had any problem with fading siding and had siding replaced by Mastic ?
I have job from 94 that siding color just washed away from barn red to gray. thanks. |
Re: Alco Siding ???
Thats Lake Forest. They will give the HOMEOWNER, (not you) new siding, and around $100-140/sq for the homeowner to pay someone to have it replaced.
Trade: Framing
Re: Alco Siding ??? |
Re: Alco Siding ???
Pretty much all the lake forest blends between 1990-1994,1995 went bad Woodland green, timberstone, natural cedar are the ones we see a lot of
Re: Alco Siding ???
Home owner has to pay to have it installed all over again and cost of removal of old siding ????
#6 | |
Re: Alco Siding ???Quote:
Homeowner has a house with 30 sq of bad siding They file a claim They get a voucher that entitles them to 30 sq of mastic Quest siding, and any other corners and J that were affected, which they can redeem anywhere the product is sold. They also get a check for aprox. $100-140 per square that they can use to pay someone to replace the siding. Most companies are going to charge more than $100-$140 so the homeowner needs to chip in usually. This is pretty good considering the install is 18 years old and the product is no longer made so they give you Quest a product that is a much higher quality
| The Following User Says Thank You to Patrick For This Useful Post: | Tom Struble (08-10-2009) |
| Need advice for Siding | Jerdog44 | Windows, Siding and Doors | 5 | 06-04-2009 05:03 PM |
| ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing | Grumpy | Roofing | 0 | 03-03-2009 09:40 AM |
| 100+ y/o siding repair. to run or not to run. | VALCOR | Windows, Siding and Doors | 19 | 02-25-2009 06:22 PM |
| siding an old house | gtmstang | Windows, Siding and Doors | 14 | 12-20-2008 06:21 PM |
| log cabin vinyl siding | Home Serve | Windows, Siding and Doors | 6 | 04-28-2008 08:16 AM |
