Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling
Old 06-27-2007, 04:53 PM   #1
Trade: painting
add corbels to an EXISTING granite tile countertop
I ma a painter by trade so this topic is a little out of my reach.. The house I have has a tile (12" x 12" granite) countertop in the kitchen. The old owers in a pinch place plain white UGLY shelf supports under the overhang as "poor mans" corbels... I would like to remove these and insert / add some really nice hardwood corble that I have... The new corels has "keyhole" slots in hte back which are going to be imposible to use considering the countertop is already in place.... DOes anyone have any suggestions on mounting these / how to replace the old... ...
thanks
Jeff
jkrause is offline   Reply With Quote
Old 06-27-2007, 06:33 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
You need to tell us if they are going to be structural or decorative? If they are just decorative how about some scotch tape?
Mike Finley is online now   Reply With Quote
Old 06-27-2007, 06:42 PM   #3
mdshunk's Avatar
PL adhesive? Long trim screws?
mdshunk is offline   Reply With Quote
Old 06-27-2007, 08:04 PM   #4
Trade: Kitchen & Bath dealer/remodeler
Does the over hang cantilever over a stud wall or are there cabinets below ?
If cabinets are supporting the counter top you may be able to secure the decorative corbels by adding blocking and screwing from inside the cabinets into the backs of the corbels.
If it is a stud wall you may have to cut an access panel, attach the corbels to some blocking, and then secure the blocking to the studs.
You may have to use some decorative trim around the access panel to finish.
"We are continually faced with great opportunities which are brilliantly disguised as unsolvable problems."
Margaret Mead
DesPro is offline   Reply With Quote
Old 06-28-2007, 04:50 AM   #5
Professional Remodeler
firemike's Avatar
I agree with DesPro, try to secure from the inside of the cabinet or the back side of the wall if at all possible.
If you can get to it from the indise of the cabinet, you might have to use a piece of lumber or plywood to stiffen up the side of the cabinet if it is flimsy.
A couple times I have successfully done it from the back side of a wall by locating the stud, drilling a through-hole, and using long lag bolts or timber screws. All I needed on the back side was a 1" hole (or hole big enough for the washer you are using) under the lag bolt/timber screw, countersinking it slightly into the stud. Once installed, a couple coats of EZ-20 and a touch-up with paint and you never knew they were there.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline   Reply With Quote
Granite Tile Countertops over Laminate c5150b Ceramic & Stone Tile 6 11-29-2007 11:20 PM
Granite Tile Countertops over Laminate c5150b Remodeling 17 09-11-2007 10:58 AM
Granite Tile Countertops over Laminate c5150b Flooring 5 04-05-2007 10:57 PM
Granite Tile counter over wood MattCoops Ceramic & Stone Tile 2 02-10-2007 09:19 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
