1860s House With Vinyl
Old 02-24-2018, 07:49 AM   #1
Metheds21's Avatar
Trade: Landscape
Rewards Points: 6
Hey all im residing my 1860s house and im trying to decide what i want to do i figured id get some other opinions.
Heres the deal the house has vinyl siding but has the old wooden clapboard siding underneath. Ive ripped about 1/3 of the vinyl off and discoverd that the wood siding under it is in good shape and im thinking about ditching the vynal all together. Now i have no issues with vinyl but i take issue with this installation, it being installed over the clapboard creates a wall void and in the section i took down i found multiple paper wasp nests, i also feel like the house is hiddin and wont be able to spot other potential problems under the vynal in the future.
So i guess im asking what would you guys do? Scrape and paint or put up new vinyl? Ive included a couple pics
Metheds21 is offline
Old 02-24-2018, 01:19 PM   #2
slowsol's Avatar
Rewards Points: 2,212
Re: 1860s House With Vinyl
That wood siding looks like a mess.
In your situation, Id probably fan fold and put new vinyl up.
-John
slowsol is offline
The Following 2 Users Say Thank You to slowsol For This Useful Post:
greg24k (02-25-2018), Metheds21 (02-24-2018)
Old 02-24-2018, 01:24 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,698
I don't think it looks that bad. No obvious patches or door/window fill ins.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 02-24-2018, 02:47 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 958
Bad thing is that old of a house more then likely has lead paint on it , so then you have that to deal with. As a home owner you can get away with it, but do you want all that mess around your house in the dirt. All the time of sanding it and painting so you can do it again a few years down the road, not me would cover it with something .
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 02-24-2018, 04:27 PM   #5
going_commando's Avatar
Trade: Electrician
Rewards Points: 252
Lead paint chips make the plants grow better.
going_commando is offline
The Following User Says Thank You to going_commando For This Useful Post:
Old 02-24-2018, 05:47 PM   #6
Metheds21's Avatar
Trade: Landscape
Rewards Points: 6
Ouch ya its lead paint for sure but im not scared and ya the siding is full of nails and staples from the vinyl job but the wood seems solid no cracks or lifting or rot.
I dunno seems like a waste to rip perfectly good siding off just cause i dont want to paint...is going back over it with vinyl acceptable? I wouldnt know how to keep the fing paper wasps out of the void is the thing
Old 02-24-2018, 06:06 PM   #7
FrankSmith's Avatar
Rewards Points: 4,598
It depends if this is your long term house and your budget. If you arnt that tide to the house and don't have a large budget than vinyl is the go to. If you are staying for a long time and have a good budget it might be worth buying a little nicer material. Either way I would install new siding before restoring the old. Looks like a good house for a lift as well. I can install as more siding by myself with a lift than I can off planks with another guy. Not to mentions its less frustrating and a lot safer.
FrankSmith is online now
The Following 2 Users Say Thank You to FrankSmith For This Useful Post:
Metheds21 (02-24-2018), Randy Bush (02-24-2018)
Old 02-24-2018, 06:20 PM   #8
Metheds21's Avatar
Trade: Landscape
Rewards Points: 6
It seems most people would go vinyl, im kinda surprised i thought at least some would hate it. Its kinda looked down on around here we even have some homeowners assc with ordinances against it. That being said keep the opinions coming i have no idea what i want to do yet.
And how would you guys do the install over the wood siding? Or strip off the clapboard and install vinyl against the sheathing?
P.s this is my long term house i bought it for the land knowing the house needed a bit of work but ive got waterfrontage and a dock so its worth it to me. My budget is about 10k max
Old 02-24-2018, 06:55 PM   #9
Randy Bush's Avatar
Rewards Points: 958
You have that right . I use mine anywhere I can get it in to work too.
FrankSmith (02-25-2018)
Old 02-25-2018, 07:53 AM   #10
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I dislike the look of vinyl so if it was my house I would doctor up the wood siding one side at a time and paint it. If it's original that's saying something for the wood. I'd invest in an airless if I didn't have one.
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
hdavis (02-25-2018)
Old 02-25-2018, 08:01 AM   #11
General Contractor
greg24k's Avatar
Rewards Points: 7,356
Most likely the house built in that time used "Brick Nogging" and clapboard siding went right over it and nailed into studs and there is no insulation. I did a whole house renovation with a rear addition which was built about the same time in the 1890's it had the same thing, clapboard siding and aluminum siding over it only they used nailing strips 16"OC over clapboard. I used rigid foam insulation over the clapboard and the house looked awesome after it was completed not to mention had some insulation which helped a lot.
greg24k is offline
Old 02-25-2018, 11:13 AM   #12
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,878
Originally Posted by Metheds21 View Post
...My budget is about 10k max
Box of matches and some ground round then.
SmallTownGuy is offline
Old 02-25-2018, 11:37 AM   #13
hdavis's Avatar
Rewards Points: 9,001
Depends on how much time you want to spend on it.
I'd tend to rehab the wood siding. Chances are the tar paper under the clapboards is gone. If you get into that, you're pulling the clapboards, so just take the paint off the edge, and flip them over when you reinstall so you have all bare wood to paint.
hdavis is online now
Old 02-25-2018, 11:49 AM   #14
hdavis's Avatar
10K is plenty for equipment and materials. 4x 24' ladders, electric power washer, spray rig, filler, caulk, paint. Easily under 5K.
Old 02-25-2018, 12:09 PM   #15
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
If you can put 200 hours of your time into it, you can probably refurb it beautifully on a low budget. I never liked the look of vinyl at all. So this would be my vote.
Golden view is offline
hdavis (02-25-2018)
Old 02-25-2018, 03:00 PM   #16
Lettusbee's Avatar
Rewards Points: 2,610
Pricing must be a lot different in Maine, or you are referring to that gable end of the house only?
Lettusbee is offline
Old 02-25-2018, 03:06 PM   #17
Lettusbee's Avatar
What part of the country are you in? I personally hate vinyl siding for a lot of reasons. But it seems to be a very popular option in other parts of the country. Especially the wetter parts. Around here, it's not allowed on new construction, period. The sun and the wind destroy it pretty quickly. Not to mention the reflection off of windows melting their neighbor's siding.
My main reason for hating it, is just like you said. There are a million places for the bugs build their nests.
There are a lot of options for vinyl though, and if you go that route, at least go up the quality scale a notch or two, avoid the cheapest product. Also, look up what fanfold is. Someone mentioned it earlier, but it sounds like you're not familiar with it.
Old 02-25-2018, 03:13 PM   #18
hdavis's Avatar
I'm guessing whole house size based on what I see. His labor is free in this equation. That gable end wouldn't take me 20 hours to clean, fill, caulk, final scrape, and paint 2 coats, and That's working off of ladders.
I'm putting this in the 140 hour ball park.
Old 02-25-2018, 03:15 PM   #19
Lettusbee's Avatar
Oh, ok. I didn't read it correctly. I though you were referring to putting up new siding.
Thanks
The Following User Says Thank You to Lettusbee For This Useful Post:
hdavis (02-25-2018)
Old 02-25-2018, 03:22 PM   #20
Randy Bush's Avatar
Rewards Points: 958
Fanfold is normally used on top of the old clapboard, serves a number of purposes. Air seals older houses and provides a flat surface for the new siding. While I know it is not for every part of the country, a good steel job is hard to beat. Can last a long time ,40 -50 yrs or more. In 20 yrs of residing house have only done 3 vinyl jobs. Would be hard pressed to use it.
Need your thoughts on this house wrap nightmare.... crissyissy General Discussion 20 02-10-2014 11:41 AM
200 year old house resto/reno blackbear Carpentry Picture Post 38 08-27-2012 09:25 PM
Historic Brick House (Findlay, Ohio) WerkBrau Excavation & Site Work Picture Post 12 07-02-2012 04:54 PM
need some wood siding advice Spike7 Windows, Siding and Doors 47 06-28-2012 10:27 PM
Vinyl and Fiber cement siding questions Bond111 Windows, Siding and Doors 2 06-18-2010 04:03 PM
