Television Hookup Question... - Technology - Contractor Talk
Old 02-03-2018, 07:40 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 804
I'm doing some work for a good customer today.
They bought a Samsung Smart TV to replace their older non-smart one.
They have a Comcast cable box next to the present TV. He says he has a router/modem in his den with his computer.
I'm 'assuming" unless the wifi signal will reach his new TV, I have to rely on the Comcast TV box for a signal, plugged in through the antenna or source on the TV. The box looked fairly old and I doubt it has hdmi.
Does anyone know..are smart tv's fully functional hooked to a cable box?
At home, I have Comcast but just a router/modem and it is hard-wired to the tv with an hdmi cable.
Any help is most appreciated.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 02-03-2018, 07:53 AM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 3,500
Re: Television Hookup Question...
I have two Samsung smart tvs. Don't use the smart part. They are just hooked up to the cable box
NYgutterguy is offline
The Following User Says Thank You to NYgutterguy For This Useful Post:
Robie (02-03-2018)
Old 02-03-2018, 08:12 AM   #3
90%-er
onmywayup's Avatar
Rewards Points: 1,556
Hooked to the cable box, they will have their regular cable, but they will NOT get an internet signal (which the "smart" function depends on) through the normal CAT 5 TV cable.
The way to accomplish getting the smart function to work on their TV is to either connect it with WIFI, or, if you have access, running an ethernet cable from their modem to the back of the TV. If you go that second route, and you have a couple days' time, buy the ethernet cable on Amazon. It will be many times cheaper than home depot /lowes, and there is no gain from paying more for these things. They all work the same (for most people's purposes) no matter what bullsh!t the carton says on the more expensive ones.
onmywayup is online now
The Following User Says Thank You to onmywayup For This Useful Post:
Robie (02-03-2018)
Old 02-03-2018, 08:27 AM   #4
Robie's Avatar
Rewards Points: 804
I wonder.....if I switch the cable box for the modem/router....will their PC work from the cable box?
It's been so long, I've forgotten.
Robie is online now
Old 02-03-2018, 08:30 AM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,394
Won't work here but Comcast may have that functionality. Here you need a set top box for cable TV and the Router/Modem for internet. No all in one boxes.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 02-03-2018, 08:33 AM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,421
Nope. The cable box doesn't provide the kind of data signal the PC needs, and the router doesn't provide the TV signal for all those Comcast channels. It's possible there could be a combination box available these days, but I haven't had occasion to find out.
Tinstaafl is offline
Robie (02-03-2018)
Old 02-03-2018, 08:42 AM   #7
90%-er
onmywayup's Avatar
Not sure about Comcast in your particular area, but I have had cable service in the past that had a combination box. I believe that was with AT&T and that was years ago. Canceled my cable right after that.
If you can't pull the new cable, the wifi signal doesn't reach the TV, and you have any tech savvy at all (or know a tech dork like me in your area), another option is to install a wifi repeater that boosts the signal high enough to get to the TV. As a matter of fact, for about $250 and a few minutes with their cell phone connected to their wifi, you can easily install Googles' home wifi system that is about as idiot-proof as possible and lets you easily add a whole lot of wifi repeaters anywhere in the house that you have an electrical outlet.
I put that system in at my house last year. Even plugged one in at my pool filter shed so we have a strong signal all over the backyard. I'm glad to walk you through it if you want to go that route.
Robie (02-03-2018)
Old 02-03-2018, 08:49 AM   #8
Robie's Avatar
Rewards Points: 804
This is one of those cases where...I shouldn't say money is no object but...close.
I'm thinking...just let them rent another modem router from Comcast and be done with it.
Robie is online now
Old 02-03-2018, 08:55 AM   #9
Inner10's Avatar
Why another router, wifi won't reach?
Old 02-03-2018, 08:56 AM   #10
Robie's Avatar
Rewards Points: 804
I don't know yet.
Modem/router is in a den...down the hall.
Probably 40' away with 4 walls separating everything.
Robie is online now
Old 02-03-2018, 11:05 AM   #11
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 2,170
Have them go to the cable provider to give them the new updated box which has an HDMI output
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Old 02-03-2018, 11:25 AM   #12
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,574
That's got to be a pretty old box.
A new box in place of the old would be on Comcast, as long as it isn't switched for a dvr type upgrade.
The Samsung would certainly have wi-fi, but one will only know how steady the feed will be if you turn it on and address the router.
I am a big fan of ethernet cable for the streaming stuff. Don't have to worry about the signal from the wi-fi router being the bottleneck or the weak link.
So for the internet (streaming) via wireless, you either already have a good signal, you improve the signal by moving the router, or you set up some type of repeater of second router closer to the TV. OR your pull some ethernet cable and put a jack near the TV.
Last option, since you already have a coax at the tv, you could move the modem and wireless(if separate) to the TV area. This could cause problems if he is hardwired into a computer at its current location, of if it changes the distribution of wi-fi throughout the rest of the house.
Above all, a good roof
Mr Latone is offline
Old 02-03-2018, 12:20 PM   #13
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I would upgrade the box if the wifi won't reach. I got a TV a customer gave me after she udgraded to a new one. My HTPC and Roku are hardwired from the modem with network cable via wireless modem.
I have no cables at the location for the extra TV so I hooked it up to an old android box with wifi. It works great and I can hardly tell the difference speedwise.
RangoWA is offline
Old 02-03-2018, 05:44 PM   #14
Robie's Avatar
Rewards Points: 804
Was able to connect via wifi...excellent signal.
It only took maybe 2 hours for him to figure the password out.
I finally texted the wife, who is on vacation in Mexico and she pointed it right out.
He can take back the old cable box.
Thanks everyone!
Robie is online now
AustinDB (02-12-2018)
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 55 01-20-2017 10:48 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
