Scan Tool/check Engine Light Tool.... - Technology - Contractor Talk
Old 07-22-2017, 07:37 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,260
Not sure if I posted this already....
Pretty cool and inexpensive gadget.
Downloaded an app for $5 and it tells me all kinds of things I don't understand....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Robie is offline
Old 07-22-2017, 07:44 AM   #2
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,062
Re: Scan Tool/check Engine Light Tool....
Ads are covering the thanks button. So..... thanks!
illbuildit.dd is offline
The Following User Says Thank You to illbuildit.dd For This Useful Post:
Robie (07-22-2017)
Old 07-22-2017, 07:48 AM   #3
House surgeon
Those things have come a long way for the likes of us. Even the harbor freight one tells you everything they can tell you at O'Reillys. T-Mobile has one they offered me a few months ago. I think it's time I get one too
Old 07-22-2017, 07:57 AM   #4
Robie's Avatar
So...the check engine light comes on.
I buy this thing...plug it in...get the app (one is free, the advanced one is $4.99 and ad free)
It tells me it's the Power Steering sensor.
Takes me to a link that describes what it could be
Another link how to repair it
Turns out it was a little low on fluid.
It gives you all kinds of stuff...
A google type map that shows where you are
It will track all engine performance between trips or...every time you start or shut off the engine..
RPM's, coolant temps, vacuum, etc, etc, etc.
Like I said...most of the stuff I don't understand.
But for $28+-, it saved me a trip to a mechanic for $150.00
Robie is offline
Old 07-22-2017, 07:58 AM   #5
Robie's Avatar
I think Verizon offered me one also but there is a monthly fee with it.
Robie is offline
illbuildit.dd (07-22-2017)
Old 07-22-2017, 09:16 AM   #6
VinylHanger's Avatar
Rewards Points: 8,204
They are great. I bought one for 11 bucks maybe 6 or 8 years ago. It has saved me countless trips to the mechanic for repairs. I had a severe tranny problem, as in the rig wouldn't move and it would stall out, and the code sent me down the rabbit hole.
Ended up being a bad alternator. Now when it acts up, I just unplug it for a minute or so and it fixes it. A new alternator would work also I suppose.
VinylHanger is online now
Old 07-22-2017, 09:25 AM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,720
I bought one back in 2011, thought it was super cool, then never used it and gave it away to a friend.
Inner10 is offline
Old 07-22-2017, 09:28 AM   #8
hdavis's Avatar
Rewards Points: 3,145
I'll give another vote for the bluetooth approach. There are a bunch of elm327 interfaces that hook up to a ODB2 connector and transmit via bluetooth to your smart phone. Not all of them work all that well, but I trust Robie did his homework.
The big thing to consider is the app you're going to use. Some of them offer more than others - real time monitoring, transmission code reset, and so on. For $20 you can get a heck of an app. If you have a powerstroke diesel, there is even one that is geared just to monitor the usual suspects on that engine which can cause expensive engine damage if they aren't caught before a code is set.
For $40 for an interface and app (or less), you can get more performance and features than my $400 scan tool has.
hdavis is offline
Old 07-22-2017, 09:33 AM   #9
Robie's Avatar
This is the app I used. There is a link to the website.
https://play.google.com/store/apps/d...l.torque&hl=en
Robie is offline
hdavis (07-22-2017)
Old 07-22-2017, 09:34 AM   #10
hdavis's Avatar
2011's apps weren't as good as they are today.
hdavis is offline
Old 07-22-2017, 09:37 AM   #11
Robie's Avatar
I keep mine plugged in.
Robie is offline
hdavis (07-22-2017)
Old 07-22-2017, 10:53 AM   #12
hdavis's Avatar
If your app allows continuous monitoring of either fuel/air ratio or the O2 sensor output, you can use it to accelerate for the best fuel use. To minimize pumping losses, depress the throttle as much as you can without causing the mixture to go rich.
I bought a closeout tablet to use ODB2 apps on that cost $60 - you may be able to find a cheaper one, but for under $100 it's a better dedicated setup than my $400 tool.
hdavis is offline
Robie (07-22-2017)
Old 07-22-2017, 11:27 AM   #13
Inner10's Avatar
I did that for a week but I kept hitting it with my knee, on my half ton the damn thing was in a really awkward spot.
I believe it, but the torque app was sweet.
Inner10 is offline
Old 07-22-2017, 11:31 AM   #14
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 4,702
I love old vehicles with no sensors or electronics, so much simpler.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-22-2017, 02:07 PM   #15
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,268
I use an Elm327 with Novascan for software. Gives me access to a lot more information than most software does, including such things like Mode 6 TID 53 for Ford misfire data which is often used. Although I still am trying to find a good lab scope for my iPad IE: PICA.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
hdavis (07-22-2017)
The Tool Belt Thread... 2ndGen Tools & Equipment 1715 09-16-2018 11:38 PM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Best 12V cordless drill LIGHT ??? lewisthepilgrim Tools & Equipment 10 12-19-2013 10:11 PM
Light activated exterior lighting wallmaxx Electrical 9 05-10-2013 04:50 PM
