My File List Is Backwards?
Old 05-24-2008, 01:51 PM   #1
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Ok, let me explain. When I open a folder to access a file, the list starts at Z, instead of A. This is apparently a system-wide default setting because it happens in every folder I open.
To explain it better, let me throw out a hypothetical situation. Say I want to post a picture here. The name of the picture is Adams_003.jpg. I browse for the folder, click Browse > My Documents > My Pictures > Adams. When the Adams folder opens, I see something like this: Adams_105, Adams_104, Adams_103, etc. Instead of seeing Adams_001, Adams_002, Adams_103, etc.
This isn't really important, but drives me nuts. Does anyone know if there is a default setting somewhere to make these folders open in alphabetical or numerical order, the right way instead of upside down and backwards? ARGHH!!!
Its probably something simple, and staring me right in the face, but I can't find it.
ProWallGuy is offline
Old 05-24-2008, 01:54 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: My File List Is Backwards?
Right click in folder, Arrange Icons by Name, do it again and it will reverse the order.
mickeyco is offline
Old 05-24-2008, 02:04 PM   #3
ProWallGuy's Avatar
Do I need to do that everytime I open a folder, or will that create a system-wide change?
Old 05-24-2008, 02:13 PM   #4
KentWhitten's Avatar
I am assuming winxp.
Open a folder, click on the gray bar where it says "name" it should have a little arrow beside it. this denotes that this column is set as the "arrange by..."
click it once, your names are alphabetical, click it again, your names are reverse alphabetical. down arrow means reverse, up arrow means alphabetical
now to keep it there. while you're still in the folder, go to Tools>Folder Options>View Tab>Apply to All Folders.
This should keep it looking this way from now on. If not, you've got something much deeper and I'd have to walk you through it slowly.
Salmon Falls Cabinetry
KentWhitten is offline
Old 05-24-2008, 02:28 PM   #5
ProWallGuy's Avatar
That did it. You the man!
Now, we'll see if it stays this way.
Old 05-24-2008, 02:46 PM   #6
mickeyco's Avatar
In that same:
There is a check box in the window below the Apply to All Folders button (may have to scroll down), Remember each folder's view settings, make sure it's checked (selected).
mickeyco is offline
