Trade: Landscape Contractor
Fax Machine That Saves To A Pdf
We do mostly public work so when someone faxes us a RFQ the usually send all the specs pertaining to the job. 99% of the specs we already have. So most faxs are like 10 to 40 pages, its killing me on paper.. Does anyone have or have seen a fax machine that would save the faxes to a computer like in a .pdf doc this way i can choose the pages to print. plus then from the .pdf i can also email them out.... thanks
joe |
Trade: Carpenter/GC
Re: Fax Machine That Saves To A Pdf
google efax, there are other programs as well
I do not know of a machine that will do what you want, but you can get a program that will save your faxes as a doc (don't know which format) |
Fentoozler
I had a small HP 4110 that saved FAX right to the HD.
It has since "expired" and is replaced by a Brother MFC 465CN...if it saves to HD, I am actually unsure.
my efax sends me the fax in some format, it's not pdf, but it can be converted to pdf
http://www.google.com/search?hl=en&q...convert+to+pdf
Lots of free converters around I use http://www.freepdfconvert.com/ |
i would need a modem connection in my laptop for that google fax program to work right? i ordered these without the 56k modems cuz i thought id never use them lol... thats why i was looking for a fax machine then just hook it to our laptops.. and dont these fax services cost money monthly?
You could get something like this
3Com 56K with X-Jack. http://www.amazon.com/3Com-100Mbps-X.../dp/B00004Z8VG http://ec1.images-amazon.com/media/i...L000014110.pdf |
Why are you still using a fax machine?
I don't think there is anyone around here that can't send you the plans, specs, etc. in a email. This way you can view them and print what you need. When I deal with the engineers, inspectors, etc. we all email documents back and forth. Usually in PDF format, but with the engineers usually in DWG format. But the engineers can send in PDF format if you don't have a way of looking at the DWG drawings, or they don't want you to mess with their drawings. Last edited by Kgmz; 12-21-2008 at 04:15 PM. |
#9 | |
Re: Fax Machine That Saves To A PdfQuote:
i agree, 50% of the people still use fax.. if you want to send them a computer and teach them how to scan and use pdfs. i'll gladly give you contact info. lol.. but untill then i still have to use a fax machine for these stone age clients... on another note im amazed that they dont make a fax machine like this, or one that i can find easily on the internet! |
you don't need a modem. I use efax, and I'm sure there are others similar. Someone sends you a fax. They call a phone number, though it won't be the one you have now, and the efax company emails you the file. If you want to send a fax, same deal. Send it through email to efax and they send it for you. No more fax machine.
Trade: Low Voltage
Huh?
Pretty much any multifunction printer/fax/scanner machine with a network port will do this. When they receive a fax you can either print it out, or have it emailed to you as a PDF, or both. I've been using a Dell 1815dn for 2 years.. not that I ever get faxes.. but it does it. |
Autodesk TrueView is a free dwg viewer. It sounds like you already have this base covered, but maybe others didn't know this.
Trade: Repair and remodeling contractor
I know of a product that I think accomplishes what you are looking to do
http://www.scantopdf.co.uk/?referrer=Google&gclid=CPmYt9DnqpcCFQE0xgodC11-iQ Unforutnately I do not know enough about this stuff to give better details since I just efax my docs (estimates, invoices, etc.) directly out of my system. Seems a little technical. It looks like you have to get deeper into it. Hope this helps. Happy holidays. Phil
Phil Tonks For all your Remodeling & Home Improvement needs in South Florida visit www.pmi1call.com |
#14 | |
i have a network port and a rather expensive multi function laser printer so how do i get this to work? thanks |
Cabinetmaker
My Brother MFC 420cn which has an updated newer model saves every fax internally, has software with it, the software allows you to view every fax and decide if u want to dump it or print it, what page to print etc. Its 3 yrs old and even then it only cost 125 bucks!!!!!!
MFC Multi Function Machine; printer,fax,scan,copier, Photo Card reader. |
#16 | |
Trade: Low Voltage
I would suggest consulting the documentation that came with it. It should list the options and the setup required for getting it to work with your email service. As I mentioned, pretty much all machines with a network port will have this option. I trialed several different models 2 years ago before I settled on this Dell. So I can only imagine that this is common now. |
| AttiCat machine Question | Onarooftop | Insulation | 45 | 12-04-2011 08:03 PM |
| Slot Machine Sound Agitating | Bubbles | Electrical | 4 | 12-10-2008 06:38 PM |
| Washing Machine Flooded Basement (again) | Richie-C | Plumbing | 22 | 12-01-2008 07:06 PM |
| wanted 5/6" seamless gutter machine | levine50 | Contractor Swap | 1 | 11-21-2008 05:31 PM |
| Best Brand names for gutter machine | lennba | Roofing | 2 | 09-12-2008 02:32 PM |
