Creating Round Corners With Sketchup...?
Old 02-13-2009, 01:29 AM   #1
Sharpie
trav007's Avatar
Trade: Renovation contractor
Rewards Points: 150
Here is the initial model for an open office door that a client wants to put some sort of doorway in. I'm thinking custom french doors with side lights.
Anyhow, the drywall is all rounded corners and I thought I'd put a framework inside the doorway without disrupting the existing drywall and also negating the need for casings.
So, my question is...does anybody know of a relatively painless way to create the curved edges in Sketchup?
I wonder if I could have figured it out by now.......hmmmm
Travis
www.customkreations.ca
"The most perfect technique is that which is not noticed at all"
-Pablo Casals
trav007 is offline
Old 02-13-2009, 10:14 AM   #2
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,040
Re: Creating Round Corners With Sketchup...?
On the bottom part of the wall make a radius the size that you want the bull-nose to be in that corner.Then click all three corner lines of the door opening and go into tools to get the "follow Me" tool.
Then click on the face of the of the corner radius you made and this will work if you are able to follow this mess of an explanation.
Maybe the pics will help.
Andy.
Creating round corners with Sketchup...?-door-radius.jpg   Creating round corners with Sketchup...?-door-radius-2.jpg   Creating round corners with Sketchup...?-door-radius-3.jpg
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Kent Whitten (02-14-2009)
Old 02-13-2009, 10:39 AM   #3
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,484
Andy, showed you the easiest way, thats how I do it as well.
Cole is offline
Old 02-14-2009, 10:39 AM   #4
Sharpie
trav007's Avatar
Rewards Points: 150
All I can say is .....bitchin....thanks guys. Its amazing how easy things can be when you know how.
Travis
-Pablo Casals
trav007 is offline
Old 02-14-2009, 05:00 PM   #5
mics_54's Avatar
Trade: contractor
A couple of additional notes on the follow me tool. Sketchup doesnt like very small facets so if you have difficulty with surfaces being completed with the followme tool...scale the drawing up by a factor of 10 or 20 or 100 the do the followme operation and reduce the size back to normal when you finish. Also the followme tool works better if the surface you wish to extrude begins perpendicular to the axis of the intended operation. Also make sure that your radius stays with in the profile of the original corner. If the followme tool operation doesnt auto erase the subtrahend you may need to select the items and intersect and erase the undesired elements.
mics_54 is offline
Round corners..Help!! profinish Drywall 11 07-23-2009 02:10 AM
Sketchup dock rendering casey344 Drafting & CAD Forum 16 12-26-2008 08:21 PM
Sketchup procedure TDF Decks & Fencing 8 11-17-2008 08:21 AM
Question with quarter round haskl33 Carpentry 14 05-31-2008 06:49 AM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 06:37 PM
