Chief Architect Vs SolidBuilder
Old 12-27-2008, 07:57 PM   #1
Panzer5's Avatar
I'm debating whether to buy one of these programs. I've heard some good things about CA - and recently learned about Solid Builder. CA runs $1850(lite)-$2500. Can't find pricing for SB but I guess it's about the same.
I'm intrugued by SB's claims regarding materials lists & cut lists - and wonder if CA has similar features (or whether SB's are worth the $$).
Anyone with experience willing to explain the difference or what you like / don't like about them?
thanks!
Panzer5 is offline
Old 12-27-2008, 08:19 PM   #2
Jeff (socal)'s Avatar
Trade: student
Re: Chief Architect Vs SolidBuilder
Originally Posted by Panzer5 View Post
I'm debating whether to buy one of these programs. I've heard some good things about CA - and recently learned about Solid Builder. CA runs $1850(lite)-$2500. Can't find pricing but I guess it's about the same.
thanks!
If you want your question answered go to www.chieftalk.com
Personally i learned CA at a local college using version 9 and 10 then bought the X1 (latest). X2 will be out soon. The other one that i have seen is SOFTPLAN but i still like CA because of the support you get from other users.
Jeff (socal) is offline
Old 12-28-2008, 02:23 AM   #3
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
I use both, if you want dead-nuts accurate material and take-off and even cut lists on lumber and sheathing then SB will do it. I find it difficult to get 3Drenders out of of SB though. If you need the great looking construction docs. and 3D stuff then CA is the way to go.
I mostly use CA in my work because of the ease of making the con. docs. and designing the new build and creating as-built plans. SB will give you the actual size of lumber needed to cut each jack rafter or whatever, it is amazing in that regard.
SB is coming out with version 18 (it is out now rather) and CA is going to come out with version X2 very soon.
Andy.
ScipioAfricanus is online now
Old 12-28-2008, 07:25 PM   #4
Panzer5's Avatar
Thanks ScipioAfricanus!
Originally Posted by ScipioAfricanus
...if you want dead-nuts accurate material and take-off and even cut lists on lumber and sheathing then SB will do it.
Those are the features of SB I found the most intriguing.
It's difficult, however, to know whether those features are really useful in the real world - absent the opinion of someone who uses the program. Sounds like you found them to work well.
What's the learning curve like?
Of course with a new version of CA only months away... it may not make sense to buy CA now. Considering I'm on an annual fiscal year and looking for a write-off, I may buy SB...
(Unless I read some bad reviews in the next day or two)
Panzer5 is offline
Old 12-28-2008, 09:40 PM   #5
I used to think so.......
wallmaxx's Avatar
I have Solid Builder 17.5, Soft Plan, and AutoCAD. And I am familiar with eFrame from Mitek.
I hear good things about Chief if you want to create typical looking plans.
I draw for my own framing use so I have found that SoftPlan (similar to Chief) is not precise enough to give me what I need.
It is true that I can generate roof rafter cut sheets from SB and they are dead on accurate...the problem is trying to get the thing to draw very complex systems exactly as you want to build them. The software just takes a heap o' learning to get good with it.
For my most precise and typically fastest dwgs I turn to the KING - AutoCAD
wallmaxx is online now
Old 12-28-2008, 09:56 PM   #6
Panzer5's Avatar
Thanks for the response. Question:
How complex is 'very complex'? How well does it handle hip and/or gable roofs? Can it do balloon framing? What type of complex roofs are you doing that the program struggles with?
also, is 'heap o' learning' the typical time it takes with any complex program, or do you think it takes more effort than it should to get good with it? (most software takes time to get good, after all...)
Panzer5 is offline
Old 12-28-2008, 10:48 PM   #7
construct1's Avatar
Trade: Carpenter/Builder/General Contractor
Send a message via Yahoo to construct1
Evening all..
When you say you turn to the "King" Autocad, do you mean Autocad Architecture or Revit or just Autocad? ANd what is the learning curve with whatever program you are using? I have been kind of looking into Autocad myself.
Thanks....
construct1 is offline
Old 12-29-2008, 12:07 AM   #8
wallmaxx's Avatar
SB is very easy for common pitched hip and gable combinations as well as bastard hipped types.
It easily handles 90% of the typical stick framed roofs out there.
My problem is that I end up framing some projects with things like conical towers intersecting into multi-pitched multi-plated roof systems. I had no idea how to asign a roof plane to this so that it would "cut" through the main front roof. When I try to draw them out with SB, I spend 20 - 30 hours with tech support and on one occasion they couldn't even frame it. The girl once said, why do you frame such cut up homes? (Maybe because that's what's payin the bills)
As far as AutoCAD goes, I'm not wealthy enough for the high end 3D stuff. The software in my machine is the 2D kind...the "software" between my ears does the 2D to 3D conversion as I draw so that I have correct 2D finished dwgs.
SB is really an awesome pgm. I like it from a production software point of view. If you want to create architect "looking" prints, I would not use SB over Softplan or Chief.
I have used SB for multi-unit production, whole house cut sheets, etc...it works well. I will put up some of my SB stuff on Picassa soon and get a link up for you.
Old 12-29-2008, 12:15 AM   #9
wallmaxx's Avatar
Here's where SB shines (no necessarily pretty but they are accurate)
File Type: pdf lvl 1 - 2A PLYWOOD CUT SHEET ARCH D.pdf (71.8 KB, 460 views)
Old 12-29-2008, 09:27 AM   #10
modterry's Avatar
Trade: Custom Modular builder
Wallmaxx,
We have autocad 2009 - can it do the kind of wall framing details like you showed in your pdf's for panel type production?
I usually review our plans and have to get the draftsman to correct all the time in AutoCad. I am considering spending the time to be proficient at least in the floor plan, elevation area.
We build our walls on a framing table and am working hard with the guys to do pre cut lists, for studs, headers, etc prior to framing.
The guys are starting to come around with the process and it is starting to save time
I want to layout our walls like your framing plan pdf numbering them in the plan.
Many thanks for your feedback.
Terry
modterry is offline
Old 12-29-2008, 11:21 AM   #11
wallmaxx's Avatar
AutoCAD "can" do it...but specific 3D modeling software is designed to track everything continuously. Make a change like move a wall...and it will adjust the joists and dimensions associated with it automatically. Ask Framerman, I think the acronym is BIM.
In autoCAD you will have to adjust everything yourself...unless they have changed the way they work.
I like SB for things like that. Say, the customer wants a window right where two wall panels join. In SB, no sweat. Join those two walls, insert the opening and then re "break" the wall into 2 or three panels (whatever your size constraints are)
In the autoCAD I use, I have to redraw and dimension the plan view, the panels and the elevations. In SB, one change in the plan view is automatically updated in the panel view, elevation and material list.
Material list? AutoCAD only sees the lines as lines...not assignable objects.
Old 12-29-2008, 03:30 PM   #12
Panzer5's Avatar
That is one heck of a roof! I think just about any program would have problems with that one (not too many people building castle towers these days!).
Thanks for the info!
Panzer5 is offline
Old 12-29-2008, 11:01 PM   #13
Eater of sins.
There are a few programs that could do this fairly well, this is Chief I made a lot of assumptions from the picture above. Took about 10 min. to do but is not at all accurate yet.
It can be done if one has all the parameters.
Andy.
Old 01-01-2009, 06:32 PM   #14
construct1's Avatar
Pretty fancy frame there Mike. Well, with all my inquisitiveness, and my hunger for new, I just went ahead and bid on a SB program on ebay. Nothing new nothing ventured as they say.
I want to thank everyone posting their views on all the software, it definitely helps on decision making. And by the way, Happy New year to everyone and may it be a Healthy, Happy, and PROSPEROUS ONE!!!! That always helps with all the rest...
Gino....
Old 01-01-2009, 10:56 PM   #15
Eater of sins.
Gino, where did you see SolidBuilder on Ebay? Not that I want to bid I already own Version 17 I'm just curious.
Andy.
Old 01-04-2009, 12:00 AM   #16
construct1's Avatar
Hey Andy,
I am not sure how I found it. I think I was looking for auto-cad architecture and that listing for solid builder came up in the search.
I ended up winning the auction. The seller has been very helpful. He has emailed me several times now about the response he has got from Digital Canal about transferring the license. They have given him a very cold shoulder about selling the program. Hopefully it can be resolved. I have Soft Plan all ready but reading all the posts about solid builder made me want to give it a try.
Old 01-04-2009, 02:55 AM   #17
Panzer5's Avatar
For those who use SB + CA (or another) - can you get the two programs to 'talk' to one another (i.e. can you transfer files (like the floor plan) between them) or do you end up doing one whole draw in SB and another whole draw in CA?
Panzer5 is offline
Old 01-04-2009, 02:58 AM   #18
Handle It!
MALCO.New.York's Avatar
So tell me Panzer....What is it that you know about Panzer Tanks and Hedgerows and Bradleys.....
This is strictly an opportunity in Educational Edification!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-04-2009, 07:55 AM   #19
duckdown's Avatar
Trade: Home Theater
We have the latest versions of Chief Architect and Autocad...
duckdown is offline
Old 01-05-2009, 10:51 AM   #20
Panzer5's Avatar
I know a bit about all of the above.
Spent several years with Uncle Sam's Misguided Children in Tanks & Tracks.
I've never gotten a tank stuck in a hedgerow, but I can assure you; tanks don't go where the cattails grow!
Panzer5 is offline
Chief Architect Design Software Tao_Rider Drafting & CAD Forum 14 12-26-2008 12:09 AM
First Chief Architect Drawing.... orson Drafting & CAD Forum 48 11-02-2008 02:29 PM
Architect Season Kaiser General Discussion 18 09-07-2008 08:09 PM
Chief Architect 10 genbuilers Drafting & CAD Forum 23 01-19-2008 09:42 AM
Owens-Corning Architect 30's VA Remodeler Roofing 8 08-23-2007 01:29 AM
