Buying A Costco Security Camera System
Old 12-15-2014, 06:32 PM   #41
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
Re: Buying A Costco Security Camera System
Originally Posted by EricBrancard View Post
Are those Lorex IP cams the same as the Hikvision ones?
Correct me if I am wrong Inner but Lorex, Flir and Digimerge are all the same company.
SectorSecurity is offline
Old 12-15-2014, 06:35 PM   #42
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,602
Originally Posted by cwatbay View Post
That is true. It does replace SDI. I didn't want to get too much into it with folks that don't have a lot of depth in the subject.
I did forget to mention that you need to have a TVI capable DVR to use TVI cameras, but I kinda figured that would be a moot point here.
And, yes, IP is more flexible. I program IP cams all freaking day to work with various networks.
One thing that is not discussed much is API.....which every IP Cam salesman seems to not understand or want to talk about. This is especially true with "inexpensive" NVR's with on board POE.
But then again, this whole discussion is about low end analog systems.
Luckily most quality main stream products have API available or are ONVIF so compatibility is less of a concern.
By installation flexibility I meant architecture wise, a job in the summer I had one NVR and a bridge between two apartment buildings. Another I'm working on now I have a fiber trunk joining three groupes of 35 cameras...can't do that with analog or SDI.
Inner10 is offline
Old 12-15-2014, 06:35 PM   #43
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 1,862
Originally Posted by Inner10 View Post
He's paying a whole 400 dollars for the kit he better make good use of the supplied cables!
I sometimes think about someone using the funky cables that come with these kits. Running the wire from the cam, through walls, behind toe-kicks, through the attic. Stapling it all down, then coming up 6 inches short from the DVR
cwatbay is offline
Old 12-15-2014, 06:41 PM   #44
Cuz I have never done that pulling cat cabling on an almost empty box.
Old 12-15-2014, 06:42 PM   #45
cwatbay's Avatar
Again, you are correct on the "quality" end of NVR's. API should not be an issue, but then again, one should really contact the manufacturer of the NVR and check the compatibility list of camera manufacturers.....even if the cam is Onvif.....there can still be issues with the processing of the video signal. But this is primarily in reference to Kits and NVR's with on board POE.
I have yet to have any issues with free standing NVR's, Video Servers and separate Managed POE switches.
cwatbay is offline
Old 12-15-2014, 06:45 PM   #46
cwatbay's Avatar
I thought that is why they make CAT5e couplers
You know, if you look closely at the cable, it will have teeny tiny letters and numbers on it that tell you how may feet you have left (or used up)
cwatbay is offline
Old 12-15-2014, 06:56 PM   #47
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
I was curious because I have a client that would like better quality on a couple cams, but it's an older dvr system... So they wouldn't be able to use the the TVI cams? What about adding a 900 line cam to and older system that's 700 now (I think)?
Sorry to hi-jack your thread Mike..
-Steve
TimelessQuality is offline
Old 12-15-2014, 07:19 PM   #48
GC/carpenter
Californiadecks's Avatar
Rewards Points: 3,486
No worries, I'm learning.
Californiadecks is offline
Old 12-15-2014, 07:21 PM   #49
GC/carpenter
So do you recommend I purchase the cable separately? Possibly a better quality? Or should I just use what they give me?
Old 12-15-2014, 07:31 PM   #50
cwatbay's Avatar
To answer your question, it all depends on two other things: the maximum resolution that the DVR will process the incoming video at, and, the maximum resolution of the viewing monitor.
If the DVR will only process at 500 TVL then thats it. Putting in 600 or 900 TVL cam won't do a thing. And, if the DVR will process 900 TVL, but the monitor will only do 300 TVL, well....it's till going to look crappy on the screen. So you see, there are three major factors: the resolution of the camera, the resolution of the DVR and finally, the resolution of the viewing monitor. There are some other factors, but they aren't worth getting into right now.
cwatbay is offline
Old 12-15-2014, 07:41 PM   #51
cwatbay's Avatar
In my experience with Q-See, Swann and Lorex, the cable you get is the cable you get. It works with that particular set up.
http://www.lorextechnology.com/Secur...n/prod660001.p
If the system uses regular RG59 or RG6 you are in luck. You can either make or buy cable to run the lengths you want. If it is premade, it will have connectors on it already, but you may need additional connectors and couplings. You need to get solid core coax, not the stranded type.
cwatbay is offline
Old 12-15-2014, 08:01 PM   #52
Inner10's Avatar
They all use bnc for video and barrel for power.
Inner10 is offline
Old 12-15-2014, 08:02 PM   #53
Inner10's Avatar
If it reaches use what they give you.
Inner10 is offline
TNTSERVICES (12-15-2014)
Old 03-08-2015, 04:02 PM   #54
GC/carpenter
Got it.
Old 03-08-2015, 04:06 PM   #55
GC/carpenter
Here it is
Old 03-08-2015, 04:18 PM   #56
GC/carpenter
Hope I don't burn the place down installing it.
The Following 3 Users Say Thank You to Californiadecks For This Useful Post:
J L (03-08-2015), m1911 (03-08-2015), Xtrememtnbiker (03-08-2015)
Old 03-08-2015, 07:34 PM   #57
skillman's Avatar
Rewards Points: 1,968
Found thread in time . Looking to do samething to .
skillman is offline
Old 03-08-2015, 07:57 PM   #58
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,872
Here it is
Is that Wall-e on the box?
Tried & True on Facebook
Tried & True Website
TNTSERVICES is online now
The Following 2 Users Say Thank You to TNTSERVICES For This Useful Post:
Californiadecks (03-08-2015), gfourth (03-08-2015)
Old 03-08-2015, 08:01 PM   #59
gfourth's Avatar
Trade: Structural & Misc. Steel
Rewards Points: 164
Cool. Good info in this thread. In escrow on our first home and this is on the list of to dos!
gfourth is offline
Old 03-08-2015, 08:01 PM   #60
GC/carpenter
I was just thinking if Inner10 can do it, how hard could it be?
The Following User Says Thank You to Californiadecks For This Useful Post:
m1911 (03-08-2015)
Elgen GSF septic system rino1494 Excavation & Site Work Picture Post 9 01-05-2013 05:11 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 07:43 PM
Vts 59 track system GroundHawg 1 Excavation & Site Work 2 06-02-2012 11:54 PM
Job Site Web Camera MikeTheBuilder Technology 15 10-10-2007 04:58 PM
CCTV Digital Security Camera Systems 3rdEyeSecurity General Discussion 1 05-01-2007 02:09 PM
