Buying A Costco Security Camera System - Page 2 - Technology - Contractor Talk
Old 12-14-2014, 05:20 PM   #21
GC/carpenter
Californiadecks's Avatar
Rewards Points: 780
Re: Buying A Costco Security Camera System
Californiadecks is offline
Old 12-14-2014, 05:46 PM   #22
Walker1's Avatar
Trade: Windows, Sun Rooms, Porch Enclosures
Rewards Points: 133
I bought a Lorex LW2960 system at Best Buy for $299.00 comes with 2 cameras. I bought it for my vacation rental property I have in Florida. I'm in PA so its nice checking on the place and getting alerts on my phone.
It was very easy to set up and the phone app works great! You can switch cameras on the phone and see and hear in real time. You can also talk through the cameras when someone is on the property through your phone. One thing I like is the alerts you get on your phone when you set the motion sensor on.
Here is a few snap shots from the cameras day and night pictures. The night shot on the boat tonight is bad because of the neighbors lights on usually you can see it pretty good.
Walker1 is offline
The Following User Says Thank You to Walker1 For This Useful Post:
Californiadecks (12-14-2014)
Old 12-14-2014, 05:51 PM   #23
GC/carpenter
Rewards Points: 780
I too Have a couple cameras like that. But I have to plug each camera into a 120 outlet. This other gets hardwired back to a receiver with one outlet for all the cameras. Plus it has 10 cameras.
Old 12-14-2014, 06:07 PM   #24
Walker1's Avatar
Rewards Points: 133
So with that system do you have yo run a wire back to the receiver with every camera?
Walker1 is offline
Old 12-14-2014, 06:09 PM   #25
GC/carpenter
Rewards Points: 780
Yes. I'm ok with that. It's much better then running a 120 outlet to the eaves of my house for each camera
Old 12-14-2014, 06:10 PM   #26
GC/carpenter
Rewards Points: 780
I think it's like running speakers. There is a channel for each camera.
Old 12-14-2014, 06:15 PM   #27
Walker1's Avatar
Rewards Points: 133
I could see that with 10 cameras
I just ran the wire from each camera inside through the wall and plugged it in. They gave you enough wire so it wasn't a problem.
That's a real good price for 10 cameras. I just wanted 2 to keep an eye on the golf cart and the boat.
Walker1 is offline
Old 12-14-2014, 08:43 PM   #28
Licensed Gas contractor
gastek's Avatar
Trade: Pools
Rewards Points: 998
I installed a Qsee 8 camera system about a month ago. Purchased from BJ's. System is decent, good night vision. Started to notice it was rebooting a few times per day all by itself. Worked with their tech support and needless to say I have to get them to replace it. It's not supposed to reboot like that. But all in all, I like the system and it works good. Worth what I paid for it.
gastek is offline
Old 12-14-2014, 09:54 PM   #29
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,420
I think I found the one I want. It's a Samsung
Don't unless you need the extra cameras, the Samsung is about half the resolution.
Inner10 is online now
Old 12-15-2014, 10:00 AM   #30
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Are those Lorex IP cams the same as the Hikvision ones?
EricBrancard is offline
Old 12-15-2014, 10:20 AM   #31
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,084
I would say no. Lorex is from a different chinese manufacturer than Hikvision. For our low end, we buy directly from a chinese manufacturer with a US office near us. These cams look exactly like Hikvision, and, I have seen thousands of cams, and, these are spot on.
FLIR/Lorex/Digimerge are all the same company now. But like all firms, there are low end and high end products. The different product levels may come from different manufacturing facilities within the same company. Or, the company may farm out different product lines to other manufacturers.
I used to have an office in Taipei and did a lot of business in Mainland China. You really had to dig deep to find out who exactly was making what.
Also, if a firm (usually internet type) says they have Sony CCTV cams. Well....don't believe it. Almost all CCTV cams use a Sony CCD chip in the cam cus Sony has the patent on it. The rest of the cam can be pure crap, but it has that Sony chip in it. It's like having Mercedes spark plug wires in a Yugo.
cwatbay is offline
The Following User Says Thank You to cwatbay For This Useful Post:
EricBrancard (12-15-2014)
Old 12-15-2014, 10:50 AM   #32
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
So what's the difference between NVR and DVR systems?
-Steve
TimelessQuality is offline
Old 12-15-2014, 11:03 AM   #33
cwatbay's Avatar
A NVR - Network Video Recorder is associated with networked cameras, usually POE type. Cameras will normally use CAT5e or CAT 6 wiring with RJ45 connectors. Cameras are individually programmed (in better systems) and occupy a network address on the system: ie: 192.168.1.102 for one cam, then 192.168.1.103 for the next cam and so forth.
A DVR - Digital Video Recorder - is associated with analog cameras that simply terminate at the recorder, usually via BNC connectors and coaxial cabling. These cameras will have limit on their resolution as expressed as TVL: total vertical lines.
cwatbay is offline
Old 12-15-2014, 11:42 AM   #34
So is quality necessarily higher with an NVR system?
-Steve
Old 12-15-2014, 04:20 PM   #35
cwatbay's Avatar
Not necessarily. If you are talking about resolution (i.e. clarity) then there are some differences. However, quality depends on a lot of things. You can have well built analog and network cams, or, the other way around. There has been a big promotional push for high resolution Mega Pixel (i.e. 1 megapixel = 1 million pixels) cams, and there are some that are true junk.
Maybe here is some info you can use:
Analog cameras tend to top out on resolution at around 900 TVL. However some new types - HD-TVI: High Definition Transmit Video Interface cams - can have a resolution up to 2.1 Mega Pixes (2.1 million pixel - otherwise known as 1080P as in your HiDef Flat Screen TV). These analog, HD TVI cams will transmit high definition video signals over standard coax - RG59u and RG6.
Analog cams will use your DVR electronics to interpret and process the video signals.
Network/Digital/Mega Pixels cams usually have a base level resolution of 1.2 to 1.5 Mega Pixels------which you can see is below that 2.1 Mega Pixel resolution I mentioned earlier.
However you can get Mega Pixel cams that go up to 30 or more Mega Pixels.......We have installed plenty of 20 Mega Pixel cams and shot the video over high speed/high volume LAN (mostly point to point).
A decent NVR will process and interpret the Mega Pixel video resolution signal so that you are viewing it in "High Definition".
Regardless of what resolution your camera processes video images at, it don't mean squat if your DVR or NVR processes these incoming video signals at a lower resolution. You will get low resolution recordings regardless of your cams.
Additionally, if you have a low resolution VGA monitor, you will be viewing the images in low resolution regardless of what the cams and DVR/NVR's process the video streams at. The same is true for viewing on your computer, smart phone, tablet, etc.
We have tried using the new 4k Flat Screen Monitors for Mega Pixel video streams, but it still has issues that need to be resolved, so we are currently sticking with 1080p Monitors.
Hope this clears things up
cwatbay is offline
Old 12-15-2014, 04:50 PM   #36
Inner10's Avatar
No, Swann IP are rebadged Hikvision cameras. IMHO Hik makes a better product than Lorex/Digimerge.
If you pick up any IP camera in the world there is about a 60% chance you are holding a Hik, despite the brand.
One records analog or SDI video streams, the other uses a variety of compressed network video streams such as H.264. One for analog cameras, the other for IP.
In short yes, all the best systems are IP, not analog or SDI.
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
EricBrancard (12-15-2014), TimelessQuality (12-15-2014)
Old 12-15-2014, 04:55 PM   #37
Inner10's Avatar
TVI is the replacement for SDI, and for a lesser extent CVI. They will never had a large foothold in the market because IP are more flexible.
Old 12-15-2014, 05:27 PM   #38
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
Originally Posted by Inner10 View Post
The kit probably comes with wires for all the cameras, you may need to extend a few.
I know you aren't suggesting someone use the premade cables
SectorSecurity is offline
Old 12-15-2014, 05:29 PM   #39
Inner10's Avatar
He's paying a whole 400 dollars for the kit he better make good use of the supplied cables!
Old 12-15-2014, 05:30 PM   #40
cwatbay's Avatar
That is true. It does replace SDI. I didn't want to get too much into it with folks that don't have a lot of depth in the subject.
I did forget to mention that you need to have a TVI capable DVR to use TVI cameras, but I kinda figured that would be a moot point here.
And, yes, IP is more flexible. I program IP cams all freaking day to work with various networks.
One thing that is not discussed much is API.....which every IP Cam salesman seems to not understand or want to talk about. This is especially true with "inexpensive" NVR's with on board POE.
But then again, this whole discussion is about low end analog systems.
cwatbay is offline
Elgen GSF septic system rino1494 Excavation & Site Work Picture Post 9 01-05-2013 04:11 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
Vts 59 track system GroundHawg 1 Excavation & Site Work 2 06-02-2012 10:54 PM
Job Site Web Camera MikeTheBuilder Technology 15 10-10-2007 03:58 PM
CCTV Digital Security Camera Systems 3rdEyeSecurity General Discussion 1 05-01-2007 01:09 PM
