Apple Verses PC? - Page 7 - Technology - Contractor Talk
Apple Verses PC?
Old 07-04-2010, 04:51 PM   #121
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Re: Apple Verses PC?
I am now Ubuntu convert. Running dual boot for now but plan on going exclusive. I also have a old xp celeron E machine box in the closet that is going to get a update to Ubuntu.
JustaFramer is offline
The Following User Says Thank You to JustaFramer For This Useful Post:
moorewarner (07-07-2010)
Old 07-04-2010, 11:24 PM   #122
Moderator
Double-A's Avatar
I had more fun playing with my Wang... I miss tape drives.
Give me a an old 80386 and DOS 5.1 and we can talk. Otherwise, I want to stay away from winders based machines as much as possible. In this world, that isn't always possible, but in my little world, there is no such thing as Bill Gates. It's my world, if you don't like it, get out.
New York Times, July 20, 2006
Double-A is offline
Old 07-05-2010, 11:22 AM   #123
I kind of remember those tape drives. The time out room in elementary school had one in there. Not that I was in there alot
Old 07-05-2010, 09:10 PM   #124
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
I liked DR DOS 6 the best of any. Then we went to Windows 3.0. Took some getting used to so I usually spent my time back in DOS anyways.
RobertCDF is offline
Old 07-05-2010, 09:46 PM   #125
www.Ridgeline-Roofing.com
RidgelineRoof's Avatar
Trade: Roofing, Siding, Gutters
Rewards Points: 25
Windows 7 is far from sucky suck. Neither is Windows XP. Sure, Vista wasn't great, but it was an entire re-design of the OS.... 7 got rid of lines of decade old code that was not great.
Ubuntu is a good OS but you run into a lot of compatibility issues with devices, something you certainly do not want when you're trying to run a business. The fact is, PCs are over 90% of the market... so you're going to find pretty much all of the software you need on a PC.
They are all good products, although Apple makes their OS and the computers. Microsoft simply supplies the OS, so if you buy the computer from a poor manufacturer that is your own fault. Are Apple laptops like every other device in that the battery is locked in the device and removing it basically voids the warranty? Never owned one and never actually looked at that..
Serving North & South Carolina
http://www.Ridgeline-Roofing.com
The Storm Stops Here.
RidgelineRoof is offline
Old 07-05-2010, 09:57 PM   #126
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
This is one of my biggest issues with people pointing blame at Microsoft. They normally start out with a cheap ass laptop/desktop and blame the problems on Microsoft when infact it's the hardware the user is trying to run it on. Then they go out and buy a apple pc and then say how much better it runs but they paid 4x as much for it. If they would have spent that much on the first laptop/desktop then they would have had one he'll of a system to start with. Vista was very hardware dependent and required a lot of bandwidth and processor power and to many people tried to run the OS on to lower spec system they had already run windows 98 and XP on and were way past running vista.
www.bcconstructionllc.com
BCConstruction is offline
Old 07-05-2010, 10:20 PM   #127
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Cheap should not mean incompatible. If a manufacturer is selling a $400 laptop, it should still work under the constraints of the hardware/OS. If not, they have no business selling it in the first place.
So what you're alluding to is there shouldn't be any <$500 WinOS laptops.
The reason Apple doesn't have a lot of comparable issues to cheap Win PCs is they don't allow it. I have a big issue with Apple's mobile computing devices but their computers are top notch. There are too many "weak" PCs because they were/are built too close or under requirements. Ubuntu has issues because of lack of universal hardware support and a rough UI. Apple has nailed it.
Just like a lot of construction/remodeling, you get what you pay for. If you want a solid computer that has little/no hardware compatibility issues and a great UI, pay for the Apple. If you want cheap, you can get Windows and hope it works. No guarantees on hardware compatibility or future upgrades. Oh, and you better protect yourself from the constant virus, spyware, and malware issues. Go could go rogue and get Ubuntu. You're kinda on your own, espcially if you are not computer savvy.
That said, Win7 has been a major relief in the history of crap OS offerings from MS. The reliability in Win7 should have been there back before W2K. Don't get me wrong, Windows has and continues to be maintenance needy and vulnerable to outside threats. As long as you have the correct hardware, software, virus/spyware/malware protection, perform weekly maintenance and don't overload the OS with too many programs, you should have little to no issues.....hopefully.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
moorewarner (07-06-2010)
Old 07-06-2010, 06:27 AM   #128
Trade: Construction
You said exactly what I said. Microsoft have no control on what hardware pc builders put inside a system and have no control over the end users who try to squeeze out another OS build on their already 10 year old $300 desktop. Also Apple are in no way value for money or good quality systems. They put run of the mill components in a shiney case and charge 3x what you could by a pc with same components. They are also known to rename components like graphics cards, main boards, ram, and sound cards with different model numbers so it's not easy to compare the system to another brand.
Old 07-06-2010, 10:25 AM   #129
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
And I'm saying that is an error on Microsoft's part. If they put more restrictions on the hardware, they could have eliminated lots of issues.
But aside from the hardware, there's the OS at heart. Windows is antiquated. While overall it has slowly progressed and become more stable over a decade or so, it will continue to be inferior to other OSs because of two simple words; Windows Registry.
I won't even bring up the continual security concerns of running a WIN OS. Opps, I guess I just did!
Angus
angus242 is offline
Old 07-06-2010, 04:47 PM   #130
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Actually it's not. They tried to do a complete redesign which after several years they abandoned.
"Microsoft originally expected to ship the new version sometime late in 2003 as a minor step between Windows XP (codenamed "Whistler") and Windows 7 (codenamed "Blackcomb" and "Vienna"). Vista's original codename, "Longhorn", was an allusion to this plan: While Whistler and Blackcomb are large ski resorts in British Columbia, Longhorn is the name of a bar between the two mountains that Whistler's visitors pass to reach Blackcomb. Gradually, "Longhorn" assimilated many of the important new features and technologies slated for "Blackcomb", resulting in the release date being pushed back a few times. Many of Microsoft's developers were also re-tasked with improving the security of Windows XP. Faced with ongoing delays and concerns about feature creep, Microsoft announced on August 27, 2004 that it was making significant changes. "Longhorn" development basically started afresh, building on the Windows Server 2003 codebase, and re-incorporating only the features that would be intended for an actual operating system release. Some previously announced features, such as WinFS and NGSCB, were dropped or postponed."
http://en.wikipedia.org/wiki/Develop..._Windows_Vista
Actually for the vast majority of hardware, Linux (Ubuntu) is easier to use and better supported, as it is bundled into the Operating System. You don't have to hunt down and install drivers as a separate act after installing the OS. The only real exceptions are some brand new hardware and devices that have been coded to Windows or OSX specifically, that require some higher level OS specific software to make use of as intended; even then the Linux community almost always finds a way to work around it and get things functioning.
Additionally older hardware is actually much better supported on Linux. Hardware manufacturers, generally speaking, cease writing/updating older hardware drivers once the hardware gets a several generations behind. Drivers for Linux aren't dependent on the hardware manufacturer to update them, so as long as the hardware is out in the world the driver will be included and loaded automatically.
moorewarner is offline
The Following User Says Thank You to moorewarner For This Useful Post:
JustaFramer (07-07-2010)
Old 07-06-2010, 08:38 PM   #131
I have to agree about Ubuntu. Win7 I don't really know about to well. I bought a laptop from a friend a week ago. It is older and a Acer. But it was only 40 bucks. The LCD works but need to be replaced.I thought it might be a driver problem of a loose cable.No dice new screen 80 bucks. So I am into it 120. Some knuckle head put Win7 Ultimate on it. This comp can barely handle it. Nvidia driver was in conflict. Same with the modem. Not that I would dial up.LOL haven't done that since 05.
Ubuntu everything works except the onboard cam and mic. But I am not concerned about those. Since I don't have a OEM OS disc for win7 I am going to wipe the hd.
Old 09-30-2010, 12:18 PM   #132
ttd's Avatar
Bought my first Mac a year ago. Personally will never go back to PC. Love it. No problems and just get Windows for Mac and you can run anything.
ttd is offline
Old 10-05-2010, 02:16 AM   #133
tnstars
pehsa76's Avatar
Trade: hospitality renovations
a salesman convinced me three years ago to pony up the extra funds for a macbook and he told me that when everybody else is slowing to a crawl because of viruses or their system crashes i would still be operating like new and i gotta say looking back that was one of the best investments i ever made because my mac has been trouble free since the first day i bought it.
pehsa76 is offline
Old 10-05-2010, 05:48 AM   #134
Solar Control's Avatar
Trade: Subcontractor
Rewards Points: 304
Somewhat off topic, but for the short term future, as particular websites still require the Windows version of Internet Explorer and certain applications require Windows, the OS still matters. While I prefer the OS X way of doing things, there is no way we would operate without Windows.
Down the road, the operating system may not matter.
Open Source's large goal for domination on the desktop has failed, but it has definitely won the minds of sysadmins around the world. Open source distributors (some) are now focusing on the cloud. While open source and Linux are not equivalent, they are highly synergistic.
Tim O'Reilly's thoughts on the state of the internet operating system are interesting and he outlines them in a somewhat long article, written in two pieces.
Solar Control, LLC--| --Motorized Shades & Blinds--| --Architectural Window Film/Tint
Solar Control is offline
Old 10-05-2010, 12:56 PM   #135
Windows sucks even Goldman Sachs today downgraded M$ stocks because they don't have devices like apple(Unix based OS) or Android(linux based OS) LOL
Old 04-30-2011, 12:25 AM   #136
ReVisionsWindow's Avatar
Trade: Windows and Doors
Rewards Points: 25
Go with the Mac! Pricey, yeah, but worth every penny. Clean and easy to use -- may take a few days to adapt, if you're used to running windows comps. Great coverage / customer service. I've yet to see anything surpass my (stock) Mac.
ReVisionsWindow is offline
Old 04-30-2011, 10:11 AM   #137
Design + Remodeling
BRAVI's Avatar
Trade: Interior Design and Remodeling
Rewards Points: 250
Apple is the only way to go. All their products are trouble free and work very well with each other.
BRAVI 15900 La Cantera Parkway, Ste 19225, San Antonio, TX 78256 (210) 690-4663
San Antonio Remodeling | Interior Design San Antonio | Facebook | Twitter
BRAVI is offline
Old 04-30-2011, 11:37 AM   #138
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
Im really looking hard at a Mac. From my understanding the part inside the Mac are not the same. They are all propritery parts. For instance an intel based chip should be an intel based chip right? Well you can not take a chip from a PC and put it in a Mac. The part are different. It is true intel makes the chip but they are not the exact same. Same goes for the hard drive etc.
Here is how I look at it. I could go a junk yard and get a ford engine, chevy transmission, dodge chassis, Lexus axles, Mercedes wheels and if I'm good enough or know someone good enough with cars they could get that car going down the road. Although if you just went to he dealership and pay a bit more you could find a car all made by the same company that will work more efficiently than the junk yard mobile.
To me this is how apple vs PC is. It is true PC work and they are versatile. But they have more problems because they are too open of a system. It take more work to keep them operating then the Mac. The Mac is like buying a car from the dealer. The support is usually better and the car is usually more efficient. Not saying one it better than the other. I think both have their place. But if you dont want to build your own or work on it all the time I think Mac is better in the respect. Personally I have a hp and I'm ready to try a Mac.
HUI is offline
Old 04-30-2011, 12:02 PM   #139
RobertCDF's Avatar
Really??? Wow you really drank that kool-aid. I recently talked to someone who had his iphone freak out and loose all his songs... No big deal right? Till he synched with itunes and it deleted all of the songs from his computer... Apple told him he would have to rebuy all his music over 6000 songs. Sounds like great products...
The Following User Says Thank You to RobertCDF For This Useful Post:
MALCO.New.York (04-30-2011)
Old 04-30-2011, 12:27 PM   #140
alongston's Avatar
Trade: Plumber
Rewards Points: 75
The most important thing you want to ask if you are thinking of getting an apple is if your current programs you use will transfer over okay.
Denver Plumbers, HVAC Denver
alongston is offline
