![]() Trade: student again
Ownership Of Valuable Scrap Materials?
If I create an ITB for a project but omit the ownership of valuable removed materials and bid submissions do not stipulate what happens to the ownership of the removed materials, do I get to say "by the way, the removed condensing units and evaporators are not to leave the premises" after the binding bid is received or is there something specific in UCC/construction law that stipulates "implied ownership" of valuable scrap to contractor?
I know that if its not explicitly stated in bid, contractors like to leave materials that cost money to dispose, so I think there's no such thing as automatic implied ownership that lets the contractor conveniently leave behind trash, but take home treasure. i.e. the ITB would be something like "furnish 10-ton 25 condensing units and matching evaporator. Recover refrigerant from existing install into owner furnished recovery container for later use in owners' equipment. Furnish labor to disconnect existing units and properly install new units using existing line set. capacity/warranty/efficiency shall be blah blah blah" If the project creates worthless scrap that costs money to dispose (i.e. ballast replacement and relamping) then obviously, DISPOSAL will clearly be spelled out in ITB, otherwise, there will be a ton of scrap left behind on the premise. I'm thinking, by omitting what happens to valuable scrap, someone will bid assuming they get to keep scrap, but lacking legally valid implied ownership, I get to say they can't take it after their bid is accepted and that difference will realize savings for me. |
Trade: Builder
Re: Ownership Of Valuable Scrap Materials?
I get the jist of your post. Make sure it's spelled out in the contract somewhere, somehow.
I can see the problem. If while digging you uncover a pile of sh*t, who does the customer thinks owns it? If while digging you uncover a jar of money, who does the customer thinks owns that? |
Trade: siding
i sometimes get people who tell me they want the scrap i tell them to strip it
Tom |
#4 | |
Re: Ownership Of Valuable Scrap Materials?Quote:
I'm sure customers say: crap is contractors', treasure is mine contractor would say crap is customer's, treasure is mine Really the point is to omit something that may lead to a lower bid without adversely affecting me while specifically spelling out things that would have adverse impact on me. |
#5 | |
Project Superintendent
#6 | |
It's the responsibility of bidder to ask questions first and bid accordingly. If you don't ask questions and assume you're bound to get yourself into trouble. |
#7 | |
I've done work for your type before. Will try to avoid it in the future. |
Since when did you come to the idea that its fair to automatically assume ownership to any valuable project byproduct, but conveniently not automatically assume responsibility for undesirable ones?
Trade: General Contractor - ret.
Always stipulate in your contract that all removed materials will be disposed of by you, unless intended to be reused on the job. Your pricing should reflect disposal fees for everything removed from site, regardless if you're recycling or not.
#10 | |
I went back and read several of your previous threads, this seems to be a theme with you. Why would you come on a contractor forum and talk about screwing over contractors? Regardless, I would absolutely assume that we had to do cleanup and disposal on any job whether specifically spelled out in the contract docs or not. I would assume salvage rights if it wasn't spelled out, but I would clarify before bidding. I would also assume that on your seven figure projects you have a pre-bid meeting, and anyone who was counting on salvage value should be asking questions at that time if it is unclear in the specs. Probably what would happen if this still wasn't clear, the contractor would yield because it wasn't worth it, and you would win. Or, he might sue you and then the courts could sort it out. |
#11 | |
Generally, you can't make the pizza bigger, so the battle is about how to claim the biggest portion or how to give away the smallest portion given the same work. Last edited by Electric_Light; 09-01-2010 at 11:50 PM. Reason: uh... screwed up something |
SO apparently your are a GC screwing over your subs. We work with our subs as a team so that we can all make a decent profit.
| The Following User Says Thank You to mudpad For This Useful Post: | seeyou (09-02-2010) |
Trade: Stupidintendent for a Commercial GC
If it's not in the contract, and it's a significant enough amount, you'll spend more $ on legal fees and in arbitration then the scrap is worth.
I hate GC's that beat down subs? You do realize that a guy like you could BK a small contractor because of a "technicality" in your business practice. That contractor has a family just like you do. The problem I have with this topic is that you are purposefully trying to get a sub to underbid and then tell them FU, u signed the contract. If you stated your intentions of the valuable scrap before hand, it would be a non issue if they didn't read it. Last edited by Elyrain; 09-01-2010 at 10:15 PM. |
SEMI RETIRED
This should, and usually is, spelled out in the bid documents. How else would a guy know what he has to get rid of. This applies to residential, commercial & public works jobs.
Electric_Light, why are you on this forum? |
Trade: ooo
Being that i'm a plumber and scrap is a daily occurance I have had this issue come up several thousand times.
It's simple, two rules apply here.
Anything else is juvenile
see ya!
| The Following User Says Thank You to Mike's Plumbing For This Useful Post: | dakzaag (09-02-2010) |
#16 | |
Have you submitted a bid without doing it and if so, what happened in the end? |
Trade: ooo
I don't own the scrap, I don't want to own the scrap, and I will not own the scrap.
Nothing in my bid revolves around anything scrap. If they want me to move scrap and allocate my resources to organize scrap then I make money on the resources I supplies via labor to deal with the scrap. I make my money plumbing and by eliminating scrap from the menu my GC's know I can ALWAYS be trusted. My GC's also know my feelings about scrap when I bid, they know darn well that Mike's Plumbing has NOTHING to do with scrap, period, end of story. All scrap does is create conflict......just like this thread. On a jobsite it's a disease. I scrapped 13,000 worth of med gas copper from a Veterans Hospital...per the GC and the hospital administrator. They gave it to me and the guys as a good will gesture for working in a crawlspace for a month in 140 deg stagnent air. We decided to take it and every employee from every possible position found out and it created so much friction I vowed to never do it again. Scrap as means of a profit is such a bad idea I would rather not have the job. Mike
see ya!
#18 | |
Trade: Consultant
I've learned over 20+ years in the construction industry, much of it in commercial contracting, that stating what you exclude is as important- or more important- than stating what you include in your bid. There's always some d-bag owner or GC looking to stiff you wherever he can, and the only way to survive in this business over the long term is to be very clear- in writing- regarding everything. |
#19 |
![]() Trade: Waste
Removing it or not, the owner is still the owner - and that is whoever owns the property and/or improvements there-on.
I am confused if the OP is a sub or GC in this case, but anyway; in general terms, the GC contracts with the owner and that contract will stipulate removal of waste, debris, etc. The bid documents and any bid should contain language that stipulates removal of waste and debris. Absent such language, the job-site still belongs to the GC, and they ultimately assume all responsibility. A sub should not just "assume" that they can take scrap, absent language to the contrary. If this is a large project with a formal bid process, there should be requisite Q&A process that can easily resolve this. When I ran RFP for a donut franchise, occasionally we would have to demo old buildings. As we paid disposal by weight, we "usually" worked with or GC's in bringing in scrapping crews that would take anything of value. For the GC's scrapping was not worth the effort, and for us it reduced our demo cost. As for the OP, I think you will find business goes better when you try to work WITH your GC's and/or subs, rather than trying to screw them by thinking you can get fancy with omissions in bid docs. Don't be short sighted, business is built on reputation and relationships. |
| The Following 2 Users Say Thank You to DPCII For This Useful Post: | Electric_Light (09-02-2010), mudpad (09-02-2010) |
#20 |
That's close minded. I don't want to be in the trade that I actually have to do physical work that involves me personally getting dirty, but that doesn't mean there isn't work in contract related work.
| left over materials | kubie | General Discussion | 52 | 08-13-2009 09:41 AM |
| Time To Really Consider Escalation Clauses | Ed the Roofer | Business | 18 | 06-25-2008 11:42 PM |
