Trade: tile contractor
Liability Insurance Question
I am a tile contractor working in a "high rise" apartment building. I was there to remove old kitchen counter and build a new tile counter. In the process when I went to remove the old kitchen sink...(I turned off water shut off's first) a pipe burst and water flooded the kitchen I was working in and the apartment directly below it. Mostly just carpet soaking, that needed a serv pro to come and vacuum dry them out and some damaged ceiling plaster, and ceiling tiles. It was discovered that the previous plumbing job was not soldered correctly and when I pulled on the sink to remove it, the pipe seperated because solder was not done right. This happened "below" the shut off valve. The maintance guys of the building had to try to figure out where the main shut off was for the whole water line so it took them a while and in the meantime the apartments were floodingwith water while they tried to find it.
My question is.... even though what I did caused the pipe to burst and flood, it really was'nt "my fault" so to speak, it was poor plumbing job. Will my liability insurance cover this? The two apartment residents called their respective renters insurance but they also wanted our liability insurance papers. So what can I expect? Thank You for your input..... |
Trade: custom home building
Re: Liability Insurance Question
In order to avoid this, I always chain down the kitchen sink directly to the foundation. This will prevent anyone from wrenching it out and exposing my imperfect plumbing.
Are you crazy? Why shouldn't your liability insurance cover this? Was the leak there before you entered the building? Of course not. This is your screw up and you are liable. Of course the carpet getting wet is another matter. It's not your fault that they didn't have tile. And the sheetrock damage is not your responsibility. Everyone knows if you don't want water damage, you should just have an exposed concrete ceiling. Yeah, the more I think about it, you should just ride this out. The apt. should have had a leak sensor installed and this should have shut down the leak in a millisecond. |
| The Following User Says Thank You to cleveman For This Useful Post: | cab470 (05-01-2009) |
We NEVER had this happen before, we've replaced a lot of sinks.....plumbing pipes usually don't just seperate with a tug on the sink....
We also have never had any insurance claims before, not familiar with how the insurance claims work, so just wondering (and hoping) they will cover this incident. Thank You for your knowledge and expertise of how the system works. |
Moderator
Get in touch with your insurance agent and file a report... not a claim, a report. Follow his advise on this. Let him send an Accord Cert to the folks that are asking for it.
| The Following User Says Thank You to Double-A For This Useful Post: | cab470 (05-02-2009) |
Cleve is beating on you a little more that he should here. Your insurance should handle all this "no problem"
.These things happen, and it sounds like whatever you did, did not really rattle the wall "too much". But you will be blamed, and your insurance will be the first to pony up. I hope you documented the causes, it may help your insurance go after the plumber
| The Following User Says Thank You to Anti-wingnut For This Useful Post: | cab470 (05-02-2009) |
Thanks Double A, and Anti-wingnut....
It was a pretty intense scene fire dept came, police...The hot water steam set off the smoke alarms..... We're really not "hacks" we have a reputable business for 8 years now. We have made plenty of mistakes that we could correct, but this was quite a blow below the belt, and to our "pride" We just can't wait for this nightmare to end.... We have already filed a claim because we "panicked" so to speak and wanted action right away. The insurance adjuster came within a few hours. And the plumber that had come after the mess....said that the pipe was soldered incorrectly and that it probably would have happened to anyone who replaced the sink/counters. We documented, took pictures and kept the pipe that seperated and showed the insurance adjuster. The customers had previously thought about having granite counters (which most people do) I really wish they had now....
I'm a Mac
Trade: ICF Construction
This is what insurance is for, this was caused by you and was unforeseen.
You claim is very legit. Now, lets hope all the tenants don't try and get a free ride out of the deal.
Chris |
| The Following User Says Thank You to Chris Johnson For This Useful Post: | cab470 (05-02-2009) |
Give your insurance papers to their insurance company...put them in a steel cage and let them fight it out...
| The Following User Says Thank You to JonM For This Useful Post: | cab470 (05-02-2009) |
Here are some of the photos I took after the initial cleanup work was done. Clearly you can see the poor solder work on the pipe.
Professional Instigator
A lot of insurance policies do not cover multifamily dwellings, apartments, condo's etc.
Most Remodeling contractors are unaware of this fact. You have to specifically have the wording covering multiple units in the policy. |
Trade: Public Insurance Adjuster
My liability coverage is very specific in this. I swore to be damned during the inital applications when most people lie that I did not work on buildings over two stories and did no work on apartments or row houses
Pinnacle Limited
Public Insurance Adjusters (800) 918-7840 |
#12 | |
Re: Liability Insurance QuestionQuote:
We take time to read the directions on our new fangle chopsaw with the laser sights, But have no clue what the our insurance policies covers until its to late. I guarantee half of the policies held by guys on this forum don't cover something they think it covers. |
[quote=rbsremodeling;671027]
We take time to read the directions on our new fangle chopsaw with the laser sights, But have no clue what the our insurance policies covers until its to late. Thats because the people who write the instruction manuals for our tools want us to understand them, And the people who write our policies dont.
| The Following 7 Users Say Thank You to genecarp For This Useful Post: | Celtic (05-03-2009), Chris Johnson (05-03-2009), Handymanservice (05-03-2009), mikec (05-03-2009), ProWallGuy (05-06-2009), rbsremodeling (05-03-2009), Tinstaafl (05-05-2009) |
I'm a Mac
Truth be known, insurance rules should follow all other rules...plain english
Chris |
#15 | |
#16 | |
[quote=genecarp;671044]
#17 | |
Fentoozler
#18 |
Trade: Remodeling Specialist - General Contractor
I would echo what others have said. Your insurance is there for this sort of thing. Let them fight it out.
I'm also confused as to why you were pulling the sink/top while the plumbing was still connected. Shouldn't plumbing disconnection be the first thing done prior to demo? |
#19 |
Re: Liability Insurance Question |
#20 | |
Fentoozler
If the method to remove was only detailed that one time, I would figure it was a heat of the moment typo...but 2 times describing some plumbing brutality?
Sounds like SOP to me. Quote:
| Builders risk insurance question | n74tg | General Discussion | 8 | 05-13-2010 12:31 PM |
| GL roofing insurance in Texas | toad5555 | Roofing | 10 | 11-05-2009 09:45 PM |
| General Liability Insurance in MA | hammond b/r | Business | 14 | 04-28-2009 02:23 PM |
| electrical insurance question | roo | Electrical | 3 | 04-27-2008 08:51 AM |
| electrical insurance question | roo | Electrical | 4 | 04-25-2008 07:09 PM |
