Trade: low voltage installation
Insurance Classification Codes
I am attempting to ind out what the Insurance classification codes in Ohio are for the range 91581 thru 91589. Does anyone know of a document with this info? I am trying to refine my insurance coverage but can not find info on the codes. Also looking for codes for low voltage cabling installation and service. Thanks.
Trade: Insurance Broker - Commercial Construction
Re: Insurance Classification Codes
Here are the class codes for 91581 to 91589:
91581 Contractors – subcontracted work – in connection with construction, reconstruction, erection or repair not buildings – NOC (No other classification) 91582 Contractors – subcontracted work – in connection with building construction, reconstruction, repair or erection – apartment or office buildings over 4 stories 91583 Contractors – subcontracted work – in connection with building construction, reconstruction, repair or erection – one or two family dwellings 91584 Contractors – subcontracted work – in connection with construction, reconstruction, repair or erection of buildings – for industrial use 91585 Contractors – subcontracted work – in connection with construction, reconstruction, repair or erection of buildings – NOC 91586 Contractors – subcontracted work – in connection with oil and gas field construction, reconstruction or repair 91587 Contractors – subcontracted work – in connection with pipeline (other than oil or gas), or communication or power line construction, reconstruction or repair 91588 Contractors – subcontracted work – in connection with bridge, tunnel or elevated street or highway construction, reconstruction or repair 91589 Contractors – subcontracted work – in connection with street or highway construction, reconstruction or repair – not elevated Also, I ran a search for "volt" or "voltage" and got nothing. A search of "cable" resulted in the following: 52467 Electrical Wire or Cable Manufacturing 59977 Wire Rope or Cable Manufacturing – metal 91302 Cable Installation in Conduits or Subways 91315 Cable or Subscription Television Companies 91577 Conduit Construction for Cables or Wires 99613 Telephone, Telegraph or Cable Television Line Construction |
thanks Astrix,
I talked to a peer in new York, he gave me this code 91127, he says this is an alarm system code. Could you verify. |
Re: Insurance Classification Codes91127 Alarms and Alarm Systems – installation, servicing or repair 91130 Alarms – security systems – monitoring ![]() |
Is there a code for CAT5 or networking installation? How about fiber optic cabling installation, also how about computer hardware installation.
I have these codes as an Excel spreadsheet. I tried to attach it here but the file was too large (440kb) and maximum allowable file size appears to be 200kb.
If you feel comfortable sharing your email, I'll email the Excel list (1,172 codes) to you. Alternately, I suppose I could split it into 3 smaller files and then attach them in 3 separate posts. You could then re-assemble it into one list at your end. Is this okay with the moderators or would I be contravening any rules re posting and attachment sizes? P.S. - I ran a search for "fibre optics" (and also "fiber optics") as well as "network", but no hits. The closest category appears to be 91302 Cable Installation in Conduits or Subways. |
Trade: Remodeling / Carpentry
What are you searching ? Insurance bureau rating codes ?
Are these SIC Codes or what ? I'm Carpentry NOC don't know the number off hand but its the same number used to classify NC WC code too. |
Division 16
Trade: Electrical Contractor
Astrix,
I'd love to have a copy of the spreadsheet also, if you wouldn't mind. With codes on the COIs, I've always just trusted that my agent has the right ones listed. info@JLLonginc.com Thanks!
Buy American-made products and help create jobs for Americans. Yes, it's that simple. |
Division 16
Insurance companies use codes on GL/WC policy documents that aren't SIC or NAICS codes. They're descriptive of the scopes of work you're insured to perform in special insurance industry codes.
Astrix,
I see why it is so hard for insurance companies to provide accurate coverage, the coding system needs to be upgraded. here's my email for the spreadsheet bob.whitney@rlwsupportservices.info THX. |
#11 | |
Hi Guys,
I've emailed to both of you here as well as the couple of guys who PM'd their emails. If any of you didn't receive it for some reason, let me know and I'll try to re-send it. (I'm more than happy to share the info.) Quote:
If you take the time to split out your business operations into a couple of class codes, instead of just one, then you can possibly save some money in liability insurance. Alot of brokers/agents and underwriters take the easy way out by using only the highest-risk code for everything that you do and then charging 100% of your receipts against that one rate. Or, on the opposite end, if the client won't provide them with a breakdown of their total revenue, then the insurer can't do a split rating for them. But if you do the extra bit of work and split out your receipts between several applicable codes, then a % of your receipts may be eligible for a low-risk rate and only the true % of high-risk work is charged the high-risk rate. For example: a common example of short-cut taking is charging 100% of a roofer's receipts using the commercial roofing code (highest rate). But if they break out (1) residential shingling from the hot-tar work and also break out (2) sheet metal (eavestroughing/flashings) and (3) siding work, not to mention (4) sub-contracted receipts, you'd save quite a bit of money because these 4 additional categories all have lower rates than the hot-tar commercial roofing rate. It's all in the math. |
Division 16
Thank you for the spreadsheet Astrix. My policy renewal is next month and the information you've provided is very helpful. Now I can decide what I need instead of completely trusting that my Agent will translate it to the proper codes. I wish other Brokers and Agents were as willing to make sure we have the most cost effective insurance. Thanks again!
Trade: Home and commercial builder
May I get a list of those codes also? I have the work comp codes but I do not have the GL codes. Thanks!! qrpllc@hotmail.com
Wolfe,
I've emailed you the list. (My apologies for the delay in responding but I've been sick and haven't been on-line much the past week or so.) |
| Non Payment problem involving Insurance job?? Very long but need feedback! | kdub1777 | General Discussion | 28 | 12-02-2009 09:31 AM |
| My insurance letter | copusbuilder | General Discussion | 11 | 05-20-2009 10:25 AM |
| Don't read this is you are easily depressed! | Mike Finley | Business | 55 | 02-28-2009 05:32 PM |
| INSURANCE! Mad & scared, your help is needed. | ncurls | Business | 32 | 06-14-2008 08:17 AM |
