Handymand Hourly Rates And Pricing Systems
Old 01-16-2008, 05:38 PM   #1
BlueCrabContrct's Avatar
I have a handyman business and charge a flat rate per hour but have begun to contimplate whether I should go to a sliding scale. I was wondering what you other handymen do.
Example 1: Charge $50/hr. no matter how many hours you work.
Example 2: Charge $100 for the first hour, $50/hr. for the rest
Any info is much appreciated.
BlueCrabContrct is offline
Old 01-16-2008, 06:50 PM   #2
fathersonfab's Avatar
Trade: General Contractor / REO Repairs
Re: Handymand Hourly Rates And Pricing Systems
I do hourly rate now and I'm switching to flat rate per job. The hourly rate won't help cover things like travel miles, getting lost, bad directions, plus gas, etc...
Use a published price guide like RS Means, or Craftsman books... I'm sure Jesse will chime in here about the flat rate thing.
Example: Change out toilet.... $120
"I cut it twice, but it's STILL too short!" singerREO.com
fathersonfab is offline
Old 01-18-2008, 07:49 PM   #3
philner's Avatar
Trade: remodeling contractor, SE Mass.
I normaly charge a minimum of 4 hours to do a small job. I charge $48/ Hr and material cost plus 10%. Even if it takes an hour I still charge the four. I will sometimes suggest a small additional repair to fill out the hours, like adjust a door, caulk a tub etc.. just so I can get what I need and not leave the customer feeling ripped off.Often the customer will then find enough to fill up the entire day or more. I've never found the small jobs as profitable as my large jobs though and often turn them down unless it's for a repeat customer or some other type of connection. Phil
philner is offline
Old 01-18-2008, 08:32 PM   #4
JPF's Avatar
Trade: Handyman Services
I do a little of both. I do a lot of stuff for a couple of designers and it benefits me more to charge per task.....hang a door *** amount, install toilet *** amount, etc....also a small "show up" charge, typically $25 to $30. I also do a lot of punch list work for a couple contractors in the area, usually couple day affairs, and i can get $65hr from the time i walk out the door at home, running for materials and such, till i leave the job at the end of the day, so that works better for me there. I figure as long as i make what i need.
JPF is offline
Old 01-18-2008, 09:11 PM   #5
Philly Dude's Avatar
Just don't use RS Means for estimating painting. I'm doing a job now I priced based on it and the job is WAY underbid.
I try to give people prices in days or half days. But after reading this website I'm thinking of going to an hourly rate with a minimum 4 hours.
Philly Dude is offline
Old 01-18-2008, 10:03 PM   #6
GregS's Avatar
Trade: Low Voltage
I'm not a handyman but I do a lot of hourly rate jobs.
I charge a minimum of 2 hours for most jobs. That helps keep me in one spot for 2 hours as opposed to driving all over the place chasing nickels.
GregS is offline
The Following User Says Thank You to GregS For This Useful Post:
EliteContrating (12-14-2011)
Old 12-14-2011, 11:58 AM   #7
EliteContrating's Avatar
Trade: General Contractor/Handy man
Our business charges an hourly rate of $35/hr. Sometimes depending on the job we charge by the square foot. After reading all this info, I think I might change to something like a flat rate for a minimum of so many hours...Gas adds up with bad directions and running around all over the place for materials.
Should I be charging more per hour???
EliteContrating is offline
Old 12-14-2011, 12:27 PM   #8
Handle It!
MALCO.New.York's Avatar
4 years ago...
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-14-2011, 12:27 PM   #9
Master Plumber
Oconomowoc's Avatar
Trade: Plumber / contractor
We can't ask pricing here on the forum. Also, this thread is dated 2008. A lot has happened in the world since then.
Oconomowoc is offline
Old 12-14-2011, 12:55 PM   #10
PRO
BrandConst's Avatar
Where's Angus when you need him?
BrandConst is offline
The Following 2 Users Say Thank You to BrandConst For This Useful Post:
aptpupil (12-14-2011), Big Rig (12-14-2011)
Old 12-14-2011, 01:01 PM   #11
Its all ball bearings
angus242's Avatar
Trade: Tile
Only YOU know that answer. Follow the link in my signature for more.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
