Trade: general contractor and inspector (incl roof insp.)
Wood Shingles: When To Recommend Replacement
At what point should all wood shingles on a roof be replaced rather than area repairs made?
RIDGID CONSTRUCTION
Re: Wood Shingles: When To Recommend Replacement
in my oppinion wood shake should be replaced when it starts to split of get dry rot these two things will depreciate the life the shake and may lead to leaks
Sean
Replaced with? There are a few methods; When the anticipated repair costs for 3 or 5 years will outweigh the cost of replacement or come close to it. Another method is when the damage goes beyond X% of the roof.
Kenton & Ridgid-Bryson, first welcome to CT, would you mind posting an intro here? Ridgid --- Next question, are you prepared for a fight with Ridgid tools & the use of the same color orange that they use & HD? |
Re: Wood Shingles: When To Recommend Replacement |
#5 | |
Sean
Re: Wood Shingles: When To Recommend ReplacementQuote:
You are looking at a job for either patching a wood shake roof or replacing it with shingles - how much would it cost to replace the roof? Then figure out how much they are looking for in repairs, how much per year afterwords inc. regular maintenance? Present the numbers to the HO & let them decide. FYI, as shingle prices go up, it may be cheaper now then waiting till later. http://www.benchmark-inc.com/searcharticles/archive031.html some interesting reading about this subject (it deals with commercial roofing but the principles are the same) As for shingle roofs, it depends on the life left, type of damage, do they mind seeing shingles that don't match, etc... |
Thanks Sean!
#7 | |
Certified Crazy!
Trade: Insurance Restoration Roofing
If you observe an eroded surface, cupped, cracked or spit shakes or shingles, or if you find a lot of moisture damage inside the attic it's worth considering replacement. I think that if you find a slope with the noted defects above consisting of about 20% of the square footage replacement should be taken into consideration. This is mainly to due repairability factors causing additional damage while you work on the slope and damage to peripheral roofing while trying to replace defective roofing. Last edited by RidgeWalker; 04-01-2009 at 11:57 AM. |
Trade: Framing,Remodeling,General Contractor
Trade: Roofing Contractor
Kenton,
HAAG Engineering has come up with a Replacement Cost Versus Repair Cost Formula, called the D.U.R.A Formula. It would be advantageous for someone from NACHI to take the courses from them and get their Certification. I don't have the formula readily handy at the moment and it is hard to find through a Google Search. You will often find things written about it that just refer to it, but not the actual formula itself. I believe that one of the Free PDF downloads on the HAAG Site, through their Store allows that one to be downloaded for free though, but I am not 100% certain. Ed
Please Stay Tuned For A Very Important Message From Our Sponsor http://www.rightwayroofingcompany.com/ www.rightwayroofingcompany.com Roof Estimates, Roof Repairs, Roofers, Roof Leak Help, Elgin, Carpentersville, East Dundee, West Dundee, Sleepy Hollow, Algonquin, South Elgin, Huntley, Lake In The Hills, Illinois |
Trade: Public Insurance Adjuster
Ed or Ridge,
Did you ever take the HAAG CRRI course last year. I remember the thread and can't remember which one of you started it. They are having a Commercial course for my area (DFW) starting in Sept. I am kicking around taking the course on 4/15, but the fees are now $825.....I could've sworn they were around $400 last year. Sorry to hijack. BTW, my threshold on maintenance is 15% spent of the cost of replacement in a year.
Pinnacle Limited
Public Insurance Adjusters (800) 918-7840 |
| Help, old shingles stuck to ice shield??? | 232323 | Roofing | 45 | 09-16-2009 04:27 PM |
| What kind of wood? | Knighton | Finish Carpentry | 9 | 02-25-2009 07:26 PM |
| Alcove for Wood Stove | Agolk2 | Construction | 0 | 09-02-2008 01:23 PM |
| water damaged wood floor replacement | 72chevy4x4 | Flooring | 21 | 03-30-2008 09:39 AM |
| pricing wood replacement | Grumpy | Roofing | 13 | 03-04-2007 10:39 PM |
