Why? - Roofing - Contractor Talk
Why?
Old 02-04-2008, 08:57 PM   #1
Forry's Avatar
Trade: General Contractor, Remodeler
Rewards Points: 526
Why?
Did some work on a house last fall... rotted sheeting due to improper ventilation. 3/12 pitch the rot was in the area where the ceiling was lofted to the rafter bottoms. Client never had a leak before, but the roof was failing bad. Soft enough to walk through. Sooo we removed the roofing/sheeting in the lofted area, insulated, leaving 2" above the bats, added soffit venting, cut in continuous ridge vent, wove in matching 3-tab, installed ridge vent, fixed a few flashing problems, and called it a job. Everything was good all winter through wind and rain storms. Last week we had the worst snow storm in ten years. At the first thaw, client heard a crack and about an hour later a dribble coming through the t+g ceiling. I went up and tarped the roof. Today, we went up to solve the problem, and I'm not sure what it is. Best guess is 9" of snow on a 3/12 and ridge vent, but I dunno. Pretty clear I'm not a roofer I guess. Any thoughts?
Forry is offline
Old 02-04-2008, 09:34 PM   #2
Forry's Avatar
Rewards Points: 526
Re: Why?
bump
Forry is offline
Old 02-04-2008, 09:35 PM   #3
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Rewards Points: 250
Re: Why?
you may have a problem at the juncture with the regular pitch,but all in all too vague to comment on ,need pics,and to be specific as to leak area etc.
"If it`s worth doing.It`s worth doing right!!!
www.ADVANCEDROOFINGNEWYORK.com
theroofinggod is offline
Old 02-04-2008, 09:37 PM   #4
Expert Roofer
Rewards Points: 250
Re: Why?
in probability the insulation was not enough ato stop ice forming,and the weight and ice and water backup caused the problem is the direction I would probably go
Old 02-04-2008, 09:41 PM   #5
Forry's Avatar
Rewards Points: 526
Re: Why?
Not much to see really, we pulled up some roof today and found wet sheeting about 12' down from the ridge. It's a simple gable roof @ 10 sq. All I can figger is that the 9" snow and the 3/12 w/ ridge vent didn't get along. I was hoping someone could confirm. Can a 3/12 gable roof have a ridge vent and 9" snow at the same time? It doesn't snow here much, so we mostly just worry about keeping the rain out. Guess I'm thinking I screwed up somehow, but can't figure how.
Forry is offline
Old 02-04-2008, 09:49 PM   #6
Expert Roofer
Rewards Points: 250
Re: Why?
it`s cathedral,the cathedral should have 2x12 beams to allow enough insulation so that ice doesn`t form,and once the ice forms it becomes a dam so melting water from higher up is forced under the shingles,should add iso or a homasote where you can have a roof that won`t be affected by freeze /thaw cycles
Old 02-04-2008, 10:01 PM   #7
Forry's Avatar
Rewards Points: 526
Re: Why?
What's hard about this is that while their roof was rotting, they never had leaks. We didn't do a complete tear off and reroof(should have, but they didn't have the $), just worked with what was there. However, this leak happened after we did our work, and after the first big freeze in ten years. I can't figure out if it was our work, or the crazy weather that caused the problem.
Maybe I'll call a local roofer out to take a look... just trying to get some perspective I guess..
Forry is offline
Old 02-04-2008, 10:06 PM   #8
Expert Roofer
Rewards Points: 250
Re: Why?
you paid attention to the air space requirement,when before it was probably stuffed tight and absorbed more into the decking,nothing beats a site visit,where are you located
Old 02-05-2008, 09:37 AM   #9
Forry's Avatar
Rewards Points: 526
Re: Why?
Eugene, OR. Don't expect I'll be seeing you anytime soon!
Forry is offline
Old 02-05-2008, 09:42 AM   #10
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
Re: Why?
I don't see any mention of ice and water shield in your posts. Theres your problem. Especially on a 3/12 pitch, i wouldn't put a ridge vent on that shallow a slope either even though thats the minimum slope recommended.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 02-05-2008, 09:59 AM   #11
Forry's Avatar
Rewards Points: 526
Re: Why?
Nobody uses I+W shield in this area, I'd have to special order it! I know the pitch is shallow, but how else to vent it? If I need a different kind of vent, I'd like to know about it. Any Ideas?
Forry is offline
Old 02-05-2008, 10:21 AM   #12
Al Smith
A W Smith's Avatar
Re: Why?
Anywhere it snow's you need ice and water shield. If no one used it around there i bet yours wasn't the only phone ringing after that snow storm. You may have discovered a new niche market. here read up on it.
Here are distributors in Oregon . note that there are two distributors right there in Eugene
A list of the distributors in your selected city is below.
A.B.C. Supply Company
4227 West 6th Ave.
Eugene, OR
Allied Building Products
3285 B West 1st Avenue
Eugene, OR
here is a web cast
Mushroom or hat vents
Al Smith
Old 02-05-2008, 10:26 AM   #13
Forry's Avatar
Rewards Points: 526
Re: Why?
Thanks for the info... I don't think mushroom vents would work here... unless I'm missing something? There's no attic in the area in question. Guess I'd need a vent every 16"?
Forry is offline
Old 02-05-2008, 10:29 AM   #14
Al Smith
A W Smith's Avatar
Re: Why?
does your existing ridge vent have a baffle to prevent wind driven snow or rain from blowing into it? also when you removed the rotting sheathing did you happen to notice if the rot was more on the roof side or the inside?
Al Smith
Old 02-05-2008, 10:40 AM   #15
Forry's Avatar
Rewards Points: 526
Re: Why?
There is a wind/rain baffle. The rot came from underneath and there was NO venting when we started. We introduced the vent as a solution, but maybe it wasn't the right one? The problem may be at the seam in the ridge vent. We'll know more later today when we open it up further. Wondering if the problem came from the vent when the snow started melting... we started at the wet area yesterday and followed it up the roof 'til it got dark... covered the roof and figured we'd finish today. Not really sure what to do today 'cept look deeper and scratch our heads some more. The thing we changed from existing is adding the venting. Guess that's probably the problem. Wondering if there's a better vent system?
Forry is offline
Old 02-05-2008, 10:49 AM   #16
Al Smith
A W Smith's Avatar
Re: Why?
I read that wet sheathing as 12 inches down from the ridge not 12 feet. if it starts that far down its not the ridge vent. Its ice damming.
Al Smith
Old 02-05-2008, 10:57 AM   #17
Forry's Avatar
Rewards Points: 526
Re: Why?
Still haven't found the top of the wet... Got dark last night first. Today we'll see if we can find the top. If it doesn't go as far as the ridge, we'll leave the ridge alone for now and focus on the roof. Client's not ready for a reroof, so I think I+W shield is out. The best thought for now is we did something wrong, I just can't figure out what it is.
Forry is offline
Old 02-05-2008, 11:02 AM   #18
Forry's Avatar
Rewards Points: 526
Re: Why?
P.S. Thanks for the time and help Al...
Forry is offline
Old 02-05-2008, 11:31 AM   #19
Kgmz's Avatar
Re: Why?
There are suppliers that sell I&W shield, check ABC supply in Eugene, 4227 W 6th Ave. You are not normally going to find it at Home Depot, Lowes or even most lumber yards, you need to go to a real roofing supply company. Also some suppliers will not carry the Grace brand, but will have something equivalent.
Also check:
Allied Building Products, 3285 W 1st Ave, they have Grace and other brands.
Roofline Supply, 3297 West 1st Ave, they carry IKO ArmourGard I&W protector.
Kgmz is offline
Old 02-05-2008, 02:26 PM   #20
Ed the Roofer's Avatar
Trade: Roofing Contractor
Rewards Points: 2,054
Re: Why?
You did not mention which brand of Ridge Vent you used, but did state that it had seams.
Is this the metal 8 foot sectional version of ridge vents?
Did you caulk under the external baffle where it lies on top of the shingles? On that shallow of a slope, the back up of melting snow and now water could puddle up near the heat from the exhaust of the ridge vent and give the leak scenario described.
Ed
Ed the Roofer is offline
