Who Is Still Using Felt?
Old 09-02-2009, 06:37 PM   #21
J-Peffer's Avatar
Trade: Roofing & Siding Contractor
Re: Who Is Still Using Felt?
From what I understand felt or underlayment was orginally used simply as a way to "dry" a roof in and eventually became part of the roofing system.
No.15 felt will not keep much water from penetrating a roof deck, but if a little does get through the shingles, it will prevent it.
Honestly any area that there is a chance of ice or water getting through because of wind driven rain, or ice build up should really have something more than no.15 or 30 felt.
Most code will let you double No.30 instead of ice and water even.
Out in the open roof, with just water treading, honestly....felt is probably just a precaution and not necassary.
Code or not though, I'd recommend it and I'm sure a customer would be wondering why felt is NOT being used because it's just considered part of the roofing system. Code is BARE minimum requirements, they have code approved houses called "modular" homes that are just awful, yet code approved too.
J-Peffer is offline
Old 09-02-2009, 06:41 PM   #22
Warren's Avatar
Trade: framing/remodeling
Maybe we install it because shingles are not waterproof.
Warren is offline
Old 09-02-2009, 09:19 PM   #23
jstange2's Avatar
Trade: general contractor
We use the new synthetic underlayments and I have see this on the gaf shingles also.
jstange2 is offline
Old 09-02-2009, 09:25 PM   #24
davitk's Avatar
Trade: Perfessional Contracter
They're NOT?? OMG we've been getting lied to all these years.
Next thing you know we'll find out step shingles are not necessary, another one of those redundancies an engineer dreamed up.
davitk is offline
Old 09-02-2009, 09:43 PM   #25
Inmate 369's Avatar
Trade: Remodeling & home repair
felt or underlayment is not required by manufactors or code but if not used over time your shingles will stick to your sheething and show terrible and any buckling in your becking will tear your shingles. Good Luck
Inmate 369 is offline
Old 09-02-2009, 09:55 PM   #26
mics_54's Avatar
Trade: contractor
my code book (2006 IRC) says it is.
(codes in your area may be different)
mics_54 is offline
Old 09-03-2009, 07:56 AM   #27
Maine's Avatar
Trade: Electrician
Thanks for the info. I talked with a GC in my neighborhood last night, he confirmed that they are now not using much felt in my area, however, it is a horrible idea.
So felt it is, thanks for the info guys.
Maine is offline
Old 09-03-2009, 03:08 PM   #28
Inmate 369's Avatar
Don't get me wrong codes very expecialy when it comes to snow loads (which i know nothing about ) .I ALWAYS use felt paper.
Old 09-03-2009, 05:00 PM   #29
PA woodbutcher's Avatar
So why does the GFCI need to be the first outlet in the circuit in order to work? You show up here busting everyones balls like it's your party. They try to give you an answer and you want more. Go ahead and knock yourself out and install your roof and save 5 bucks a square I wouldn't. A good underlayment is the cheapest insurace your going to get.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 09-03-2009, 06:43 PM   #30
Capra aegagrus
Tinstaafl's Avatar
It doesn't.
Tinstaafl is online now
Old 09-03-2009, 08:53 PM   #31
I like Green things
WarnerConstInc.'s Avatar
The REAL question is, Who does not use felt.
cheapskate's
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 09-03-2009, 08:56 PM   #32
Warren's Avatar
We don't use felt all the time. We like to use the synthetics like Titanium UDL. Its lighter and tearproof. Not to mention, when its 10 degrees out, felt gets soooo brittle. It does cost about 3 times as much though, but thats for the GC to worry about.
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
747 (09-19-2009)
Old 09-03-2009, 08:58 PM   #33
NNY's Avatar
Trade: contractor
We use the felt and Ice and water where needed . We don't get callbacks . That's worth the expense itself . In a perfect world the shingles get the job done . In the contracting world anything can happen and if slapping down some felt can maybe stop a whole host of nightmares from a "little" leak , slap that stuff down . Also , I just can't imagine a homeowner letting you slide on not putting in down .
NNY is offline
Old 09-03-2009, 09:11 PM   #34
davitk's Avatar
OK this is not a roof but fits the "Felt? We don' need no stinkin' felt!!" catagory. Dumbasses.
davitk is offline
Old 09-03-2009, 09:21 PM   #35
NNY's Avatar
Trade: contractor
There you go . You actually see more damage on sidewalls from improper installs . Looks like quite a patch job on the ply .
NNY is offline
Old 09-03-2009, 11:00 PM   #36
Red Adobe's Avatar
Trade: Siding, Metal Roofs, and Beer Drinking PRO
I saw a mesican once felt over shingles then do another layer, I think it was the 4th layer
t's cheap and takes what 30 mins to do 10 sq, I do metal and use radiiant barrier but its basicly the same cheap n easy and make the cusomer happy
Red Adobe is offline
Old 09-08-2009, 01:47 PM   #37
roofbutcher
roofbutcher's Avatar
Trade: exterior carpenter, farm mechanic
In some areas it’s code, and some shingle manufacturers’ use it as an excuse to not honor their warrantees.
From a craftsmanship perspective, I like it on old, rough deck to protect the back-side of the shingle from stubble. I have also seen it trap water against plywood and blow it apart. Being confident in my shingling, I prefer not to use it on clean, smooth plywood.
http://roof-shingle-removal-tool.com/ Rippers with attitude!
roofbutcher is offline
Old 09-08-2009, 02:39 PM   #38
General Contractor
MacRoadie's Avatar
Trade: General Building Contractor
Underlayment is required in any area where the IRC has been adopted as the model code. There may be some semantic issue regarding "felt" versus "underlayment" as a lot of areas don't use asphalt impregnated felt anymore.
MacRoadie is offline
Old 09-08-2009, 07:28 PM   #39
davitk's Avatar
ROFLMAO
davitk is offline
Old 09-09-2009, 08:12 AM   #40
Maine's Avatar
Trade: Electrician
I didnt know I was "busting anyones balls", I was simply trying to learn the pros and cons to using felt, is education a problem for you?
If you would have taken the time to read, you would have seen that I did install the felt.
Maine is offline
TYVEK vs Felt paper--which is better??? enforcer Windows, Siding and Doors 96 10-25-2011 06:32 PM
Is it okay to leave the old felt on? mdshunk Roofing 86 10-23-2009 01:33 PM
Leveling with roofing felt and leveling compound DIA-jp Flooring 18 12-15-2008 01:09 AM
Felt tiles or Felt Rolls on summerhouse Rolf Roofer Roofing 0 03-21-2008 10:28 AM
roofing felt bwashington Roofing 2 08-10-2006 10:52 AM
