White Residue On Slate Roof
Old 01-23-2006, 11:19 PM   #1
BChester's Avatar
Hello,
I'm a Paint contractor in Los Angeles and have a question regarding slate/terracota roofs. Many properties along the coast have a white residue buildup on the roof. The roof is very fragile, so I'm asking for advice on how to clean and walk on the roof without damaging it. I figuered pressure washing with some type of solvent, and some burlap bags filled with styrofoam packing for walking. Any suggestions?
Thanks
BChester is offline
Old 01-23-2006, 11:55 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: White Residue On Slate Roof
Slate and terracotta are two different things all together. Slate is a natural stone mined out of the earth while terracotta (AKA Clay) is a manufactured product.
If these houses are located on the coast I can only guess it is a salt build up on the roofs.
To walk on the roofs I do not suggest. If it is necessary, then you should use a chicken ladder so you never actually place a foot onto the roof. Also consider a harness incase you slip off a ladder since a slate roof will be extremely extremly extremly slick if wet. I have to be honest your idea of bags fill with styrofoam made me laugh.
Grumpy is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
