Trade: remodel and finish
What Is This Underlayment?
framing in a hip roof for an addition. to tie in had to remove clay barrel
tile from the existing roof. underlayment is from a roll, 32" before overlap, granulated surface, looks like hot tar at overlap, 3/16 inch thick. thought it might be granulated peel n stick, but at the drip edge can sort of pry it up pretty easy. anyway...the questions. what do you think it is looks in good shape - so is the entire application with quality material. some of the tiles were stuck to the tar area at the overlap and in removal small portions of the top granulated layer were damaged or removed. can these be repaired. thanks for the time bob brown |
Commercial Roofing
Trade: Roofing Contractor
Re: What Is This Underlayment?
YEs they can be repaired. Probably 90# roll roofing or SBS modified bitumen.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
Trade: roofing
Tile roofs need a heavy duty underlayment. now a days we ice shield the whole roof under them.
RooferJim www.jbennetteroofing.com |
so, if these small repairs can be made would it be advisable to replace with more modern product - or just waste of $
and what would the repair process by - roof cement? Last edited by bobbrown; 10-25-2006 at 07:30 AM. |
Trade: roofing
Please for the sake of humanity, dont use roof cement on a tile roof. many times you can replace broken tile and redo the flashing work and thats fine. other times you have to take all the tile off stock pile them ice shield the roof then put the same tiles back with new copper slaters nails and new flashing work"rip&relay". its not worth it if its concrete tile though only clay.
a good slate and tile man can do repairs and you can never tell. RooferJim www.jbennetteroofing.com |
don't wory jim -.....it never entered my mind to put roofing cement on a tile roof.
i was concerned about repairing the small holes in the granulated underlayment. thanks |
| Underlayment for Floor tile - South Florida | ETHICS05 | Flooring | 14 | 07-18-2007 03:32 PM |
| floor underlayment | mudd-cat | Flooring | 8 | 02-18-2007 04:42 PM |
| Best underlayment | jscozz | Flooring | 0 | 07-03-2006 10:59 PM |
| Pb for tile underlayment? | Steve Unkie | Flooring | 12 | 03-25-2006 03:57 PM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
