What Sould Gutter Pitch At? - Roofing - Contractor Talk
Old 01-16-2009, 11:25 AM   #1
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
Rewards Points: 252
I have always heard 1/16" -1/8" depending on how long of run. (Longer run less pitch. But have recently became involved in an argument with a aquatince, they say to run them level? What is rule of thumb on gutters?
Thanks
doubleaction is offline
Old 01-16-2009, 12:16 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 6,995
Re: What Sould Gutter Pitch At?
As much pitch as you can get out of a run is best. Without making the reveal look stupid. Running them flat is asking for problems down the line. Freezing in the winter and then the gutters fall off because of all the weight, mud forming in the summer because of the leaves that decay and have no where to go. Any pitch is better than none.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-16-2009, 12:24 PM   #3
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Rewards Points: 526
I have heard and done 1/8 per foot. you definately want that water to move or you will have problems down the road.
Norman Sharp
Be sure to like us on Facebook
https://www.facebook.com/Sharpimprov...homepage_panel
Norrrrrrrrrrrrm is offline
Old 01-16-2009, 12:32 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
thing is you should check with a level.
Ive seen facia that was way out.
Tom Struble is offline
Old 01-16-2009, 01:05 PM   #5
Tom M's Avatar
Rewards Points: 8,432
In my opinion some pitch is good, I'd say 1/8 per ft. My gutter installer keeps them close to level unless something above dumps into it. I have never had an issue with this, as for mud and sludge build up----it makes no difference it dont move inside the gutter. Simply put dirty gutters attract more dirt than a smooth surface so its best to flush out the gutters when you do clean them. If you think about it, a gutter with zero pitch that has 2 spouts cant hold water.
Tom M is online now
Old 01-16-2009, 02:12 PM   #6
Al Smith
A W Smith's Avatar
Rewards Points: 1,000
dirt and mud will seek its own level anyway. I have seen gutters with excessive pitch tear themselves off buildings because the ends at the leaders get overrun with debris and get clogged and filled with 3 inches of mud. Ask yourself where would you rather have your mud? evenly distributed across the gutter or all at the ends where your drop tubes are? also consider that on the lowest ends during a hard storm rain will overshoot the gutter. In theory If your gutters are dead level the ice and mud wont be very deep. plus it looks nicer on the facia. Myself though I always pitch my gutters at least some minimal amount.
but the correct answer is,, it depends.
Had to edit my post as 1/8 is WAY too much. for a 30 foot gutter thats 1 7/8 inches of crown And ive NEVER done that much,
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-16-2009, 02:20 PM   #7
nlgutters's Avatar
Trade: seamless gutters
We always run level and never have had an issue. When you over pitch is when you really have an issue.
Water self levels itself so if you have a gutter that is pitched 2" in the wrong direction it will fill with 2" of water then drain. If you have a gutter rip of an asphalt roof beacuse of this your gutters are not strong enough.
nlgutters is offline
Old 01-16-2009, 07:06 PM   #8
Trade: siding
Rewards Points: 20
i think the theory is like when you pitch a waste line,too little pitch theres not enough flow to remove debris,too much pitch and water flows around any debris
Old 01-16-2009, 07:32 PM   #9
red_cedar's Avatar
Rewards Points: 1,250
no more then a 1/4" to a 1/2" per 20'
red_cedar is offline
Old 01-16-2009, 07:34 PM   #10
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
I do that per 10 feet
rbsremodeling is offline
Old 01-16-2009, 07:44 PM   #11
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I don't care for mosquitoes.
I jam it up under the drip edge as far as possible-hope it hits the bottom of the drip edge. Then on the downhill side, on a 48' long building for example, I'll have the bottom of the gutter flush with the soffit. This is on a 2x6 fascia, so I'm hopefully dropping 5 1/2" over 24', which is less than 1/4" per foot.
There is a quite noticeable crown on the building this way, but I haven't had any complaints. If people want it level, I say make them pay to fumigate for mosquitoes every summer. These level ones are constantly wet just from the dew in the morning.
cleveman is offline
Old 01-17-2009, 11:17 AM   #12
red_cedar's Avatar
Another way to view this, is what material, kind of customer and neighborhood you are in.
Aluminum seamless gutters in a area that home values are lower to moderate then its not as imortant.
Some copper gutters you want to keep the pitch not so noticable, but still pitched, because they tend to be looked at as more ornate. Like a picture frame to a picture.
One is framing the roof perimeter so to speak.
I keep the pitch to a minimum ( as least try to ) with steel, copper and aluminum, just because thats what looks better to my eyes and still does not allow for standing water.
Once the water gets going it keeps going on its own.
Running the gutters level will only be good for continuous run aluminum.
Other metals you will be limiting the material service life.
Just my opinion.
Old 01-19-2009, 02:38 PM   #13
Lou the roofer's Avatar
Trade: Roofing
Rewards Points: 25
I don't have a X" per foot rule but i would guess it's close to 1/16 per foot.
I use my 4 foot level to determine to pitch.
I don't understand why someone would have them level
Lou the roofer is offline
Old 01-19-2009, 05:02 PM   #14
AAA Gutter's Avatar
Trade: Seamless gutters
Rewards Points: 75
I do try to get some pitch to the gutter when possible, a level gutter will drain all of the water.
What I try to avoid is, a belly or low spot in the gutter that will hold water and give you problems.
and what does a little water in a gutter matter? evaporation will take care of it
AAA Gutter is offline
Old 01-19-2009, 07:01 PM   #15
Duane
Duane1982's Avatar
Trade: Roofing Siding and remodeling
Rewards Points: 85
My gutter guy runs level all the way until 2-4 feet from the end then gives it 1/8-1/4 downward into the downspout.
Water runs level naturally.
Hasn't anyone ever used a water level??
Duane1982 is offline
Gutter Setup? guttersbyryan General Discussion 14 11-14-2008 04:57 PM
Com Cast tv cable in wood gutter Driftwood Carpentry 6 10-04-2008 08:40 AM
Gutter Stainers handy man88 Roofing 1 09-17-2008 11:58 AM
ice shield at gutter line? Grumpy Roofing 38 09-08-2008 07:22 PM
Shingles hang over gutter robertc65 Roofing 14 07-11-2006 08:58 AM
