What Is The Lowest Pitch Roof Everyone Is Comfortable With Putting In A Skylight?
Old 03-01-2007, 08:01 PM   #1
mikeybobo's Avatar
Trade: residential remodeling
Hello, carpenter here asking a roofing quesion. I have 2 anderson skylights with the flashing kit. I'm changing the pitch on a shed style roof on a sun room on the first floor, and I want to lower the ledger height to get it away from the 2nd story windows. What is the minimum pitch everyone is comfortable with for a 28X48 anderson skylight with regular 3tab shingles?
mikeybobo is offline
Old 03-01-2007, 08:34 PM   #2
RooferJim's Avatar
Trade: roofing
Re: What Is The Lowest Pitch Roof Everyone Is Comfortable With Putting In A Skylight?
Any pitch if you flash it right. low pitch you use a curb
RooferJim is offline
Old 03-01-2007, 08:47 PM   #3
Bah Humbug!
Grumpy's Avatar
Agreed to what rooferjim said. However follow the insallation guideliens of your manufacturer. I am sure Anderson has a written specification for how the skylight should be installed and it's warrantable limits.
Velux has some skylights which are able to be installed dead level, zero degrees. Like Jim said, build a curb. However some of the Velux skylights must be mounted 15 degrees. Further more Velux also gives high end limits, I think 85 degrees off the top of my head, so you don't go mounting skylights on walls as windows.
Grumpy is offline
Old 03-01-2007, 11:39 PM   #4
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
same here,don't matter if it's the right one for the application
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 03-02-2007, 01:58 AM   #5
Roofboy's Avatar
Trade: Roofer
Hello,
I would also use Ice and water shield from the eave to above the skylights. If you use a curb as was mentioned I would also wrap that as well. Make sure you wrap it up the side and then flap on top of the 2 by.
Keith
Roofboy is offline
Old 03-02-2007, 10:43 AM   #6
mikeybobo's Avatar
Now what does everyone mean by use a curb if the pitch is low? I'm assuming you mean something above the window to divert the water around it? I have seen the small metal v shaped above skylights before that kind of looks like angle iron. Any other methods out there?
Old 03-02-2007, 11:04 AM   #7
reveivl's Avatar
Trade: Renovations
A curb is just a 2x6 that supports the skylight off the roof. This curb can then be flashed or otherwise dealt with to keep the water where it belongs.
reveivl is offline
Old 03-02-2007, 12:44 PM   #8
Ed the Roofer's Avatar
Trade: Roofing Contractor
Mickeybobo,
You are referring to either a saddle or a cricket, which would divert the downward flow of water to either side of the structure.
Reveivl properly described a curb structure for you. Building a curb and then pre-flashing all 4 sides as Roofboy stated, exactly, is the proper way to go.
Ed
Ed the Roofer is offline
Old 03-02-2007, 01:52 PM   #9
Bah Humbug!
Grumpy's Avatar
SOmething we should be asking... What is the pitch of the roof? Should there even be shingles on the roof is this question is being asked?
Grumpy is offline
Old 03-02-2007, 02:42 PM   #10
Good point.
If it is a 3/12 or less, then to still install shingles, you would have to cover the entire decking with an ice and water shield product.
If it truly is that low of a slope though, a proper flat roof membrane would be a preferable choice.
Ed
Old 03-03-2007, 11:34 AM   #11
Tom M's Avatar
IRC says any skylight less than 3 on 12 should have a curb as described by everyone above. I would consider doing it for a 3 or even a 4. It can be done without if you have a good roofer but its a crap shoot on who knows what the're doing and who says they know what the're doing. If wrong it could be troublesome for years especially if your recycling a previously installed unit. Use the ice shield up the sides and get matching aluminum usually "territone or bronze" and make a new flashing system. Add a diverter as well for the hell of it the less traveling water it sees the better.
Tom M is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
