What I Sthe Best Waterproof Membrane To Use Under Tile Roof?
Old 08-29-2009, 11:32 PM   #1
maleko's Avatar
Trade: carpentry
I will post this question as well in the tile section. I am building a garage addition that will connect to tiled decks on th esecond floor, The owner wants the tile deck to continue ove rthe garage addition, Its only gonna be about a 1-2 pitch rafter lenght is 12 feet i was thinking about a 1-2 inch drop since it will be a deck owner wants it flat as possible. My sales rep recommended this stuff called protecto wrap, never heard of it,, he says i can apply it over the plywood and thinset right over it? huh? he says its simular to water and ice...? anyone use this, or what you u recomend? i just never had to tile over a roof before, The tile is gonna be slate...
thanks for any info....
maleko is offline
Old 08-29-2009, 11:35 PM   #2
Tom Struble's Avatar
Trade: siding
Re: What I Sthe Best Waterproof Membrane To Use Under Tile Roof?
ive only seen protecto wrap window flashing 6'' rolls
that project sounds scary
Tom Struble is online now
Old 08-29-2009, 11:41 PM   #3
maleko's Avatar
Trade: carpentry
i was thinking about just using water and ice, then use firing strips, then another layer of plywood then durock then thinset the tile to that,?
maleko is offline
Old 08-29-2009, 11:45 PM   #4
Trade: siding
hmm i dont know maybe your better off using epdm instead of i&w
im sure someone here will yell at you pretty soon tho
hang in there and good luck
Old 08-30-2009, 12:11 AM   #5
A&E Exteriors's Avatar
Trade: Roofing, Framing, Finish Carpentry
protecto wrap is a 6-10" roll of pretty much grace I&W, for flashing around doors and windows. I'd probably use grace myself, and apply the backerboard directly to that. I have never done this on a roof though, I have lined a tiled shower pan in this fashion however.
A&E Exteriors is online now
Old 08-30-2009, 02:11 PM   #6
maleko's Avatar
Trade: carpentry
I posted this in the roofing section as well but thought it would get more exposure here.. I am building a garage addition that will connect to tiled decks on the second floor, The owner wants the tile deck to continue over the garage addition, Its only gonna be about a 1-2 pitch rafter lenght is 12 feet i was thinking about a 1-2 inch drop since it will be a deck owner wants it flat as possible. My sales rep recommended this stuff called protecto wrap, never heard of it,, he says i can apply it over the plywood and thinset right over it?thinset right ontop of the membrane, huh? he says its simular to water and ice...? anyone use this, or what you u recomend? i just never had to tile over a roof before, The tile is gonna be 4x6 slate... why not just water and ice it durock over that and tile??
maleko is offline
Old 08-30-2009, 02:23 PM   #7
Warren's Avatar
Trade: framing/remodeling
We use protecto wrap around our windows and doors. Ours comes in 8 inch rolls. I like it for our application, as it sticks well and is thin enough to conform well. Very tough too. I have never seen it in larger rolls and I am not sure if there are any other suggested uses for it.
Warren is offline
Old 08-30-2009, 02:32 PM   #8
JSC's Avatar
Trade: Roofing
A tile roof on a 1/12 pitch? I hope you are going to be adhering the tile to the underlayment with foam and not penetrating fasteners.
Old school would be to install a three ply built up roof first, as the tile will be strictly decorative.
These days there are several options. To name a few:
1. Hot mopped membrane per the above.
2. Three ply torch down modified bitumen.
3. 3 ply self adhering modified bitumen system.
Whatever you use, remember that the underlayment IS going to be the roof.
JSC is offline
Old 08-30-2009, 03:19 PM   #9
maleko's Avatar
Trade: carpentry
Let me try to explain a little better, sorry if i wasnt clear. The house has a wrap around deck that is tiled, the only side that doesnt have the deck is the side they want a garage with a flat roof, and to use that roof to connect the decks togheter with the tiled floor. so im trying to figure what will be the best way to make the roof weather proof but be able to install the tiled floor over it? maybe a dummy roof that is the waterproofed one then frame a dummy roof that i can tile on? just trying to figure what will make the most sense.
maleko is offline
Old 08-30-2009, 05:37 PM   #10
maleko's Avatar
Trade: carpentry
^BUMP^ anyone??
maleko is offline
Old 08-30-2009, 05:41 PM   #11
Originally Posted by maleko View Post
^BUMP^ anyone??
answered in "roofing", you are doing a pretty unique project, use your
better judgment. I really think grace, backerboard, tile is the best bet if the HO is set on tiling the roof.
Old 08-30-2009, 08:35 PM   #12
10fingers's Avatar
Trade: Contractor Residential Construction
STEP 1
CBM48
CRACK BUSTER Crack Prevention Mat Underlayment - 1.8mm x 4' x 100' roll
STEP 2
DITRA150
DITRA-MATTING ANTI-FRACTURE MEMBRANE - 3'3" X 45'9" Roll
Check if products suitable for exterior application. Also make sure to check tile rating. Not all tiles can be used outdoors. You probably knew that though.
10fingers is offline
Old 08-30-2009, 10:49 PM   #13
Watts's Avatar
Trade: Roofing
Check out Hydro-Stop. They have a product that you can install tile over. They deal with an elastomeric SYSTEM, that is much better than an elas. coating.
Watts is offline
Old 08-31-2009, 09:09 PM   #14
Its all ball bearings
angus242's Avatar
Trade: Tile
Just so everyone knows what info is available and what advice is being given:
http://www.contractortalk.com/f73/wh...ed-roof-64104/
http://www.contractortalk.com/f15/wh...le-roof-64103/
No need to post so many threads on the same subject...
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is offline
Old 08-31-2009, 09:09 PM   #15
angus242's Avatar
Trade: Tile
There are actually 3 threads running....
Angus
angus242 is offline
Old 08-31-2009, 11:10 PM   #16
Moderator
Double-A's Avatar
I merged the two threads. Please do not double post.
New York Times, July 20, 2006
Double-A is offline
Old 09-07-2009, 09:07 PM   #17
apehangeralfy's Avatar
Trade: Certified Roofing Contractor
Seal-o-flex CT.
This is not a job to learn on. It must be installed correctly or it will leak, then you get to redo the deck and the tile...
This is not really a roof, you are dealing with a walking deck and that changes things significantly...
apehangeralfy is offline
Old 09-14-2009, 08:33 PM   #18
ccmoto's Avatar
Trade: architectural sheet metal
Build a floating floor. use one of the above methods with some deck footings (pre-cast pylons or treated 6x6) roofed in, then frame the second floor above the lower roofing.
ccmoto is offline
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 11:12 AM
Tile roof coating 4thGeneration Painting & Finish Work 0 02-01-2008 05:49 PM
Roof tile salvage? jamesfl Roofing 7 12-14-2007 03:53 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
