What Is Best Way To Cut Corrugated Steel Roofing?
Old 03-23-2011, 10:22 PM   #1
MikeGC's Avatar
Trade: All construction, remodeling, home improvements
Location: Rochester, NY Elmira, NY, WNY, Finger Lakes, Southern Tier
Rewards Points: 510
29 gauge
straight cuts and then angle cuts
any experience schwenson shear ?
MikeGC is offline
Old 03-23-2011, 11:41 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 760
Re: What Is Best Way To Cut Corrugated Steel Roofing?
What kind of money are they asking for that shear? If at all possible I would use a shear or snips either hand or power. Some guys cut it with a metal saw . But personally I will not. Can not remember if it was on here or on the JLC forum ,but this subject has been gone over pretty much.
Randy
Randy Bush is offline
Old 03-24-2011, 03:14 AM   #3
Joasis's Avatar
Rewards Points: 1,306
http://www.amazon.com/Hitachi-CN16SA.../dp/B00005Q7BR
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
Old 03-24-2011, 07:51 AM   #4
Grumpy's Avatar
Rewards Points: 2,000
There is or was a table setup called a Kleen Cut, or Kleen Kut, I forget. Anyways it allowed you very precise angular cuts with a normal hand saw I think. I have read stuff saying not to actually "cut" metal because you expose the edge to the weather. Where as sheers and slitting tables actually don't cut but compress the metal which leaves the galvanized or paint intact at the edge, less rust. I'm no expert, personally if they want galvanized currogated metal, they want cheap IMO so I am using the saw. I have only ever bid one such currogated project and they said I was too expensive. Go figure.
For standing seam and flat lock and the like, I am all for power sheers. But it takes a steady hand so your cuts don't look drunk. That's the beauty of table setups, nice straight cuts.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 03-24-2011, 11:23 AM   #5
Joasis's Avatar
Nibblers tend to "burnish" the cut, or burn the edge, in my experience, and do not lend to rust issues.
The carbide saws produce a beautiful edge for sure, but you can build a table for that out of a sheet of plywood. Use a 2X for a fence, pivot on one end and clamp the other to hold the sheet secure.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Old 03-24-2011, 04:24 PM   #6
Grumpy's Avatar
You can build a simple table from plywood and 2x4's. We do that for cutting our aluminum soffit material. Problem is it's not adjustable and only custs on a 90'. I suppose it can be made easily adjustable.
-Grumpy
Grumpy is offline
Old 03-24-2011, 06:41 PM   #7
MikeGC's Avatar
Rewards Points: 510
I made an adjustable saw table for vinyl soffit and siding.
If a circ saw is the best way to cut clean angles thru corrugated steel roofing and siding Ill do that. What type of blade?
I was looking at a nibbler and power shears but so far we have not reached concensus.
MikeGC is offline
Old 03-24-2011, 06:56 PM   #8
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Malco snips that attach to a cordless drill
These work great for cutting length wise, angle and across the ribs.
Chris@Sunrise is offline
Old 03-24-2011, 08:41 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,685
Tinstaafl is online now
Old 03-24-2011, 08:43 PM   #10
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
but where do you find an Ecuadorian with a skill saw
Tom Struble is offline
Old 03-24-2011, 09:02 PM   #11
Capra aegagrus
Tinstaafl's Avatar
That ain't no Ecuadorian, that's a hillbilly.
Old 03-24-2011, 09:18 PM   #12
Crystal Ball Malfunction
jps614's Avatar
Trade: Construction / Remodel / Home Improvement
Rewards Points: 150
Hillbillies know about velcro?
jps614 is offline
Old 03-24-2011, 09:27 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Well, he's an OLD hillbilly. Very well-versed in the easiest ways to do just about anything.
jps614 (03-24-2011)
Old 03-24-2011, 09:32 PM   #14
Trade: siding
Rewards Points: 20
Chris@Sunrise (03-24-2011)
Old 03-25-2011, 01:23 AM   #15
mcmullan's Avatar
Trade: General
I use a nifty lil tool that hooks on my cordless drill i forgot the name and its worn off the tool. I have had it for a while and use it everyday. it will cut ribs and any angle ya want..
mcmullan is offline
Light Gauge Steel Framing or Red Iron Houses JimCarter Commercial Construction 12 03-08-2010 10:41 PM
Beacon Roofing Supply Reports $19 Million 4Q Profit, Record Earnings for Year Grumpy Roofing 6 12-15-2009 07:40 AM
Steel roofing help Scooterman Roofing 6 07-10-2009 09:08 PM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 08:40 AM
