Weatherhead Flashing
Old 12-13-2006, 10:32 AM   #1
boman47k's Avatar
How do guys handle replacing the flashing at the base of the weatherhead? I have been around several roofing jobs and have seen vent flashing replaced, no problem, but I have never seen weatherhead flashing replaced. Are there two piece flashings out there?
boman47k is offline
Old 12-13-2006, 10:50 AM   #2
reveivl's Avatar
Trade: Renovations
Re: Weatherhead Flashing
Yes, my roofing supplier carries them, yours probably does too.
reveivl is offline
Old 12-13-2006, 11:02 AM   #3
boman47k's Avatar
Thanks for the response. I thought my bro-in-law roof contractor told that was the case. On the roofing jobs I have been on, they may have replaced a few and I just did not notice. I would say most of the time they do not though. As for myself, I do not like to play around the weatherheads much! I've only done one complete roof ( my son's ), and I was very leery of just replacing the shingles around it after reading about some electrical fatalities online.
boman47k is offline
Old 12-31-2006, 05:42 PM   #4
Ed the Roofer's Avatar
Trade: Roofing Contractor
Maybe its different terminology, but I am not familiar with the term "WeatherHead" flashing. Could someone enlighten me? What or where is a "WeatherHead" installed and for what reason? Are you just speaking of a weathered flashing, ie one that has seen better days and needs replacement? Not trying to be picky on semantics, just want to know.
Ed
Ed the Roofer is offline
Old 12-31-2006, 05:44 PM   #5
mdshunk's Avatar
Originally Posted by Ed the Roofer View Post
Maybe its different terminology, but I do am not familiar with the term "WeatherHead" flashing. Could someone enlighten me?
Ed
Service mast flashing. The fitting on the top of the service mast is called the 'weatherhead'
mdshunk is offline
Old 01-01-2007, 10:58 AM   #6
28 years and still learning new terms. What is a service mast?
Old 01-01-2007, 12:36 PM   #7
reveivl's Avatar
Trade: Renovations
"What is a service mast?"
Wood post or steel pipe (or both) where the electric service lines come into the house.
reveivl is offline
Old 01-01-2007, 01:59 PM   #8
Heck, I've been dealing with the electrical service bracket for years and didn't know the name for it. I just called it the power line post and bracket.
I have found 3 good ways of creating my own flashing for the goose neck pipe where the electrical service runs in.
1) Use a prefabricated single ply membrane boot flashing from a company like Duro-Last if available and hot air weld it to custom fit.
2) Use a piece of Grace Ice and Water Shield to completely encapsulate the base of the pipe up to about 3-4 inches. Then completely caulk it over to prohibit UV degradation. Be neat, then spray paint it to match either the pipe or the roof shingle color.
3) 4" X 4" wood post. Use 4 individual small pieces of sheet lead and make your own 4 sides of curb flashings for the post.
Thanks for the explanation.
Ed
Old 11-10-2007, 11:23 AM   #9
Wantasub1's Avatar
Trade: Roofing Contractor Lic. 488700 CA
Check out the new slide on from the side galvanized flashing that can be installed easily around any weatherhead.
spinflashing dot com
It's easy and works great. Slide it on - Spin it closed!
Wantasub1 is offline
Old 11-10-2007, 12:09 PM   #10
Cool, and all of the time I've spent making them out of sheet lead!
neolitic is offline
chimney flashing on standing seam roof kermmonk Construction 22 02-19-2010 03:39 PM
installing new thru-wall flashing @ existing wall. TAO Masonry 5 08-08-2007 05:26 PM
Step Flashing Hardibuilt Roofing 3 05-18-2007 02:08 AM
still trouble with flashing Traditions Painting & Finish Work 20 01-31-2007 09:01 AM
are copper/lead/rubber vent flashing shopman Roofing 8 03-30-2006 07:02 AM
