Mod / ArchiBuilder
Waterproof Underlayment For Deck?
Guys, what can I lay under decking boards so that water will not penetrate the plywood underneath?
I will need to nail 2x4 sleepers to the top of it for the deck boards. I was thinking I&W Shield but it says it is not recommended for low slope applications.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Re: Waterproof Underlayment For Deck?
Not sure what you're asking. What plywood under what deck boards? Is this a 'deck' for people with plywood underneath for some reason?
Or a roof deck that's getting sleepers for a metal roof?
Frank Slate Roof Repairs, Richmond, Va. |
Mod / ArchiBuilder
Well it is a carport/deck. The deck is on top of the carport.
When the job was done 10 years ago, they used plywood on top of the joists and then came with a layer of 30 pound asphalt and then laid 2x4 sleepers down on it for the deck boards to nail to it. It does have a 1/8" slope to the front, which is where the water leaves.
Put 2 layers of mod-bit, plain down, then apply 1 layer of granule-surfaced mod-bit.
You're not looking for an underlay, you were looking for a type of roof.
Mod / ArchiBuilder
Frank, thank you.
I am not a low slope roofer so this was out of my league. I will take what you have said and run with it.
Trade: Roofing
Dont nail or screw the sleepers through the new membrane. Loose laid sleepers are fine.
\Jim |
Expert Roofer
tinner and jmorgan are right,but typically we add strips of mod bit under the sleepers too so they don`t bite into the roof over time
Thanks TRG and jmorgan. I do some things so naturally, I forget to point them out or even mention them. Both are what I do, but I forgot to mention them. And the question of railings hasn't even reared it's head in this thread yet. But we know it's coming!
Expert Roofer
notch them over the roof and secure them to the fascia w/carriage bolts
| Underlayment for Floor tile - South Florida | ETHICS05 | Flooring | 14 | 07-18-2007 03:32 PM |
| floor underlayment | mudd-cat | Flooring | 8 | 02-18-2007 04:42 PM |
| Best underlayment | jscozz | Flooring | 0 | 07-03-2006 10:59 PM |
| Pb for tile underlayment? | Steve Unkie | Flooring | 12 | 03-25-2006 03:57 PM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
