Trade: painter, roofer
Water Stain Pipe Or Roof?
How do u tell if a water stain is from leaky pipe or from the roof? I checked out the roof and it looks good. How do check to see if a pipe is leaking?
Trade: Roofing Contractor
Re: Water Stain Pipe Or Roof?
Water test the roof first above the pipe with a garden hose.
Let it saturate the roof over the suspicious area for several hours while monitoring the attic for moisture infiltration. If no leaks develop, then water test the actual pipe, if you are speaking of a plumbing vent pipe. Do not force water into a b-vent or furnace pipe. Before you go through that much time, see if any soldered joints on the pipe flashing have seperated. Ed |
#3 | |
Re: Water Stain Pipe Or Roof?Quote:
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Old black water pipe | pedro mac | Plumbing | 4 | 12-28-2005 04:13 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
