Trade: professional building company. Russia
Water Drainage - Roof Pitch Requirement
Good day guys, I am from a Russian based building company and we came accross with a certain problem while working with a flat roof. we are installing an inverted roofing system on a flat roof with 0% pitch - can you share how you create (build) a pitch slope to drain excess of water and what is desirable % of this pitch. Big thank you in advance. Angela
Certified Crazy!
Trade: Insurance Restoration Roofing
Re: Water Drainage - Roof Pitch Requirement
http://www.houstonfoam.com/pdf/TaperedRoof.pdf here's who it works.
Trade: Roofing Contractor
You need a minimum of a 1/8" per foot slope, but a 1/4" per foot slope would be more effective.
There are many manufacturers of tapered insulation systems to get detailed layout drawings from. But you already stated that this is a 0 % slope and an IRMA, Inverted Roof Membrane Application, which means that the insulation blocks will be going down on top of the roof membrane and then ballasted on top of that, didn't you? If that is correct, the tapered insulation system needs to be applied prior to the roof membrane being installed. Ed |
| 1:12 pitch roof and water pooling | KesslerDweller | Roofing | 3 | 11-28-2007 09:48 PM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
