Venting A Dormer?
Old 08-25-2007, 10:19 AM   #1
ecooke21's Avatar
Trade: Rremodeling..finish carpentry, etc
Venting A Dormer?
I am currently bidding on a small 10x10 addition (laundry room) ... Normaly I would have my roofers do the roof, but I figure I wont waste my roofers time with this small job..
The addition is going to be 10x10 single story attached to a 2 story bullding. it will have a 4/12 pitch shed roof that attaches to the main part of the house.. do I need to vent the roof? since it is a shed roof, how do I vent if needed? since there isnt a ridge, I cant use ridge vent.. box vent?
here is a poor sketch in powerpoint.. first is the top view, second is the front view..
thanks
A bunch of little rabbit turds banding together usually just makes one bigger piece of crap. -Mike Finley
ecooke21 is offline
Old 08-25-2007, 10:38 AM   #2
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Re: Venting A Dormer?
Yup, vent it the same as anything else. Soffit vents and a box vent on the roof. Just make sure rain doesn't hit the vent from the roof above with that long fall if possible.
MJW is offline
Old 08-26-2007, 02:10 AM   #3
Roofboy's Avatar
Trade: Roofer
Hello,
You can also use wall vent where the roof line meets the siding. Leave the plywood 1 and 1/2 to 2" down from the wall transition. We generally use the 4 foot pieces of ridge vent cut in half and butt them against the wall. Make sure that you cut the siding out enough so your roof to wall metal can go over the vent and slide behind the siding.
This method will elliminate any chance of water dripping on a box vent.
Hope this helps.
Keith
Roofboy is offline
Old 08-26-2007, 02:35 AM   #4
Ed the Roofer's Avatar
Trade: Roofing Contractor
Here is the perfect product for a solution to your problem.
http://www.dciproducts.com/html/shedroof.htm
As RoofBoy said, make sure you fabricate some roof to wall sheet matal apron flashing to cover the entire Smart Vent designed for the shed roof application.
Ed
Ed the Roofer is offline
Old 08-28-2007, 12:31 AM   #5
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
it`s called clerestory vent
theroofinggod is offline
Old 08-29-2007, 11:55 AM   #6
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
Yup i was going to say vented wall flashing. There are a lot of different kinds out there.
Patriot Broadcasting Network
doubleaction is offline
calculating dormer! softgun Carpentry 3 08-24-2006 09:45 AM
Dormer Windows ch0mpie Windows, Siding and Doors 9 07-09-2006 09:56 PM
Dormer Vs. New Roof Baghuan Construction 13 02-01-2006 01:22 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
Shed dormer venting reveivl Roofing 11 05-31-2005 10:08 AM
