Vent Porch Ceilings Below Open Decks?
Old 11-26-2007, 08:11 PM   #1
webermail's Avatar
Trade: Residential Construction and Remodeling
Question
I'm re-building an unenclosed 3 level porch-deck. The level 2 and 3 decks are waterproofed with an EPDM membrane over plywood over 2x8 floor joists. I will install beadboard panel ceilings on the undersides of these decks.
I plan to prime the back side of the beadboard ceilings - and vent the ceilings to allow any moisture condensation to escape. Are back-priming and venting necessary? (The owner thinks I'm going overboard here since there is no heated space, but I assume the interior joist spaces will heat up and cool down at a much different rate than the outside air, and will therefore produce a decent amount of moisture from condensation).
I'd appreciate any suggestions.
Thanks,
webermail
webermail is offline
How to level out a concrete porch? ProVolley9 Masonry 17 08-27-2008 09:09 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
Got a call for 208 decks today.... curapa General Discussion 7 11-13-2007 01:07 AM
Ridge vent issues? apkole Roofing 4 05-08-2007 06:46 PM
9 foot ceilings or 8 foot ceilings with treys? williefb General Discussion 1 02-11-2007 01:29 PM
