Velux Skylights
Old 09-05-2010, 09:07 AM   #1
Slipurma's Avatar
Trade: builder
Velux Skylights
Can velux skylights be used on a pitch of 15 degrees
Slipurma is offline
Old 09-05-2010, 09:11 AM   #2
tcleve4911's Avatar
Trade: Remodeling contractor
Re: Velux Skylights
Anything below a 3/12 pitch requires the roof buildup kit.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 09-05-2010, 09:31 AM   #3
Designer/Contractor
Rio's Avatar
Re: Velux Skylights
15 degrees is one degree more than 3:12 I believe.
Rio is offline
Old 09-05-2010, 09:35 AM   #4
tcleve4911's Avatar
Re: Velux Skylights
Look on your speed square.........
Back in Maine
Dubbin' Around
Old 09-05-2010, 09:38 AM   #5
genecarp's Avatar
Re: Velux Skylights
Slip, why not introduce yourself to the community, tell us a little about your professional history, thanks, GMOD
genecarp is offline
Old 09-05-2010, 09:40 AM   #6
tcleve4911's Avatar
Re: Velux Skylights
oops ....thanks Gene.
I always forget to look for the intro
Back in Maine
Dubbin' Around
Old 09-05-2010, 10:01 PM   #7
SEMI RETIRED
griz's Avatar
Re: Velux Skylights
Yes. http://www.veluxsolutions.com/static.../flashing.html
griz is offline
Old 09-06-2010, 11:08 AM   #8
dougger222's Avatar
Trade: Roofing Contractor
Re: Velux Skylights
Anybody use the new Velux window? Done a few now and they seem nice but working with there sealant strips is a real pain.
10 year leak warranty? Wonder how many will still mess that up???
dougger222 is offline
Old 09-06-2010, 12:25 PM   #9
Super B
skyhook's Avatar
Re: Velux Skylights
Degrees are mostly used in road building.
15 degrees would be 15' rise in 100' run. Or 1.5' in 10'
Something like 1.8' / 12'
skyhook is offline
Old 09-06-2010, 03:07 PM   #10
Designer/Contractor
Rio's Avatar
Re: Velux Skylights
Degrees are used in all sorts of applications. There are 360 degrees in a circle. Using trigonometry or a computer with a graphics program it's a piece of cake to translate any pitch into the commensurate angle or vice versa.
See attached pdf for the angle of a 3:12 pitch
Rio is offline
Old 09-06-2010, 03:19 PM   #11
Designer/Contractor
Rio's Avatar
Re: Velux Skylights
I went ahead and did a 15 degree angle with a 100 unit run, and an angle generated from a 100 unit run to a 15 unit rise to show the difference. It's easy to mistake one for the other and if one is doing ADA ramps can cause a real headache, as in 'tear it out and redo it'.
A side note on triangles which I find fascinating is that the angles of any triangle will add up to 180 degrees, 1/2 of a circle............. Those ancient Greeks were amazing mathematicians......................
Rio is offline
Old 09-06-2010, 04:06 PM   #12
Don't Eat Yellow Snow!
English Roofer's Avatar
Trade: Pro Slater and Roofer
Re: Velux Skylights
In the U.K. we use degrees to state a roof pitch all the time, it has only been in this forum and roofing talk that i've heard you guys talking about a 3/12 pitch etc.
Cheers
' I can resist anything but temptation' Oscar Wilde
www.drroofing.co.uk
English Roofer is offline
Old 09-06-2010, 04:13 PM   #13
genecarp's Avatar
Re: Velux Skylights
Cheers
Dave, we always refer to roof pitches as 3/12--------5/12----Etc...in our minds we really don't think of degrees, even though it actually is all about degrees. 3" in a foot---------5" in a foot. Personally I just know what these numbers represent, and if I can safely work on the roof with or without scaffolding, And, what type of roof and skylight should be used on the building.GMOD.....
genecarp is offline
Venting cathedral cieling w/ skylights mattsk8 Roofing 38 12-12-2009 11:38 AM
Small space between two skylights Young_Buck Roofing 13 09-25-2009 12:44 PM
tiling for velux window andymc Roofing 1 08-25-2009 06:14 PM
skylights loudgy Windows, Siding and Doors 7 05-11-2009 09:44 PM
FYI, Velux for flat roofs Grumpy Roofing 7 12-05-2005 11:01 AM
