Varmint Control...
Old 05-01-2006, 07:43 PM   #1
RJC's Avatar
Trade: Landscaping
Varmint Control...
This past winter a family of squirrels took up residence in the rafters, gaining entry through holes they had chewed in the roofline. Had a varmint control outfit come get them out. Now I want to get the roofline sealed up and repaired. The outfit that removed the squirrels said there is some kind of edging that roofers install that prevents this from happening. Anybody know what this edging is called and if this is the best way to go about this?
Thanks!
RJC is offline
Old 05-01-2006, 09:00 PM   #2
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Re: Varmint Control...
A picture would be nice to see exactly what you are talking about. Style D roof edge is what I use. Get the whole covered up with metal somehow.
MJW is offline
Old 05-01-2006, 10:11 PM   #3
RJC's Avatar
Trade: Landscaping
Sorry I don't have a picture but it's a two-story old victorian farmhouse w/gabled roof so it's a pretty steep pitch, w/a fascia board butting into the roof sheeting. The squirrels dig in between the fascia and sheeting and leave little golf ball sized holes.
Just googled the info from your post ("style D roof edge") and so I see this kind of edging appears to be readily available. Is it standard procedure to install an edge like this when a roofer puts on a new asphalt-shingle roof?
RJC is offline
What kind of control devices do you use? avalon Outdoor Lighting 7 02-29-2008 11:12 PM
Solution for VCT cracking @ control joint puzzledlog Flooring 2 05-16-2007 08:48 PM
Labors hours control igorrepublic Painting & Finish Work 19 03-03-2006 07:27 PM
possible problem with the USG with dust control wolffhomerepair Drywall 2 02-25-2006 09:35 PM
