Tile Color Question
Old 03-01-2004, 08:51 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Tile Color Question
Does the color of the tile, dark vs. light effect the temperature inside the
house? I understand they secure the tile with a polyfoam that is supposed
to insulate the house.
Any thoughts?
Kathy
Old 03-01-2004, 08:00 PM   #2
Teetorbilt's Avatar
Re: Tile Color Question
My wife was named Kathi.
Dark tile will absorb light and heat, light tile does the opposite with the exception that it will reflect both to a different location such as the walls or roof.
I have never heard of securing tile with foam and if it is done the volume (thickness) would not be enough to add much energy efficiency.
Teetorbilt is offline
Old 03-02-2004, 07:31 AM   #3
Unregistered
Guest
Posts: n/a
That is what I thought. So a dark red on the roof would make the house hotter inside during the summer. I may go with a lighter color with some additional flash for a color blend, to reflect the sun.
Foam is really an adhesive I guess.
Old 03-11-2004, 10:08 PM   #4
jmorgan's Avatar
Trade: Roofing
The foam adhesive is not a solid layer. It goes down in "rows". It's becoming the craze on large jobs. If you are well vented the hotter roof won't matter that much....melts snow quicker in the winter.
Jim
jmorgan is offline
Old 03-12-2004, 10:11 AM   #5
Bah Humbug!
Grumpy's Avatar
I think it was GAF who did a study a few years back. They did a test to see the real difference in temprature between white and black. This is all coming out of my memory but:
Black shingles vs WHite shingles have a surface (roof top) variance of 30 degrees.
Inside the attic... there was only a two degree difference between white vs black.
Grumpy is offline
Old 03-12-2004, 01:01 PM   #6
Unregistered
Guest
Posts: n/a
That is intersting. As you can imagine in South Florida the surface tempreature can get guite hot. I did choose a lighter shade of tile vs. the dark red shades.
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Bad tile job AAPaint General Discussion 9 07-26-2006 04:56 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
