Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing
Old 02-09-2008, 08:53 PM   #1
Trade: Roofing Contractor
Tenwolde's 5 Myths Of Moisture
Well, I have several articles that just were sent to me, and I may disagree with some perspectives, the topics are always noteworthy for further discussion.
Ed
MADISON, WI -- Each year American homeowners spend millions of dollars attempting to fix or prevent moisture-related problems. Too often, their efforts don’t fix the problem. In some cases, these efforts actually make matters worse. So says Anton TenWolde, a physicist and researcher who has been studying moisture in buildings for more than 20 years. According to TenWolde, many generally accepted moisture-control practices in the United States are based on limited or no research but mostly on tradition among home builders and others.
“We spend very little on housing research in the United States. Several countries, including Canada and even smaller nations like Denmark, the Netherlands and Sweden, invest more than the United States in research into home-building technology,” he says. TenWolde, a native of the Netherlands, holds degrees in physics and engineering from the University of Delft in the Netherlands and the University of Wisconsin at Madison.
He has been a physicist at the USDA Forest Service Forest Products Laboratory (FPL) in Madison, Wis., since 1980. He is currently project leader of the Building Moisture and Durability research unit there. Since 1999, the FPL has been home to the Advanced Housing Research Center, through which much housing-related research is managed and coordinated.
Several ongoing projects at FPL study moisture-related issues. For example, FPL’s research-demonstration house, a full-size four-bedroom house built in 2000, is equipped with scores of sensors embedded in the walls and elsewhere to track the movement of moisture and water vapor in the walls and foundation. Other projects look at sealants and wood-preservatives as well as adhesives. The problem of basing home construction or repairs on unproven building practices is amplified because some of those traditional practices have become part of building codes around the country, TenWolde says.
According to TenWolde, building codes historically deal with safety issues such as fire prevention, electrical safety, or structural standards. Building codes sometimes go beyond safety when they try to deal with moisture.
“And moisture is one area where current building codes get it wrong, especially when they apply standards that might make some sense in northern Maine or Minnesota to Florida or Texas,” TenWolde says.
TenWolde identifies five main ideas about home construction and maintenance that are widely misunderstood or downright incorrect. He calls them “The Five Myths of Moisture.”
Myth One concerns so-called vapor barriers, or vapor retarders.
“ A vapor retarder, normally installed only on exterior walls, is intended to slow the diffusion of moisture from an area of higher humidity to one of lower humidity. Such barriers are ineffective if there is any air movement, which is almost always the case in wood-frame construction. An air barrier, to be effective, needs to envelop the entire house—ceiling and floor as well as walls,” TenWolde says. “Problems caused by diffusion are very rare; moisture problems caused by moving air are much more common.”
In warm, humid climates, a vapor barrier can do harm. Nonetheless, practically all building codes require vapor barriers or retarders. (Vapor barriers originated in the 1930s, partly based on research conducted at FPL.) A more effective approach to controlling moisture intrusion would be to make the house as air-tight as possible and provide good drainage around the house, according to TenWolde. Myth Two is that attics need to have lots of ventilation. Again, venting requirements are not based on rigorous scientific research.
TenWolde explains that attic venting originally arose as a moisture-control strategy for cold climates. Other purported benefits, such as longevity of the shingles, arose later. It is widely believed that increased attic venting will prolong the life of roofing shingles by cooling them. But research shows that venting has very little, if any, effect on shingle temperature. The most important issue in shingle temperature appears to be the color of the shingles. Light-colored shingles reflect sunlight and don’t get as hot as dark shingles.
One possible real benefit of attic venting in climates with large snowfalls is to reduce snow melt on the roof to avoid the formation of ice dams. But according to TenWolde, a more effective—and energy-efficient—way to control snow melt in almost all climates in the United States would be to use air barriers and insulation to prevent heat from entering the attic.
Myth Three is that new homes are built “too tightly” and that walls have to “breathe.” That is the reason often given for the presence of mold in newly built houses. TenWolde cites recent research in Canada that revealed that houses that leaked air had as much, or in some cases more, mold than tight houses.
“It takes very little air movement to accomplish drying, and even a house with good air barriers usually will permit enough movement to permit moisture to escape, unless there is massive water entry. Uncontrolled air movement may actually cause moisture problems, and certainly can cost money in air conditioning and heating,” he says.
Myth Four: Crawl spaces need to be vented. To TenWolde, venting crawl spaces is just as dubious a practice as venting attics. Venting crawl spaces is marginally effective in dry climates but can be harmful in wet or warm humid climates. The best way to control moisture in crawl spaces is to use site grading, downspouts and soil covers to prevent water from entering the crawl space.
TenWolde’s Myth Five is the belief that building codes actually address residential moisture problems.
“Building codes address only vapor “barriers” and venting attic and crawl spaces. These are only two ways of controlling moisture and not very effective ones at that,” TenWolde says. “Most real moisture damage in homes is caused by water entering the home through leaks or poor flashing details. The most effective practices for controlling moisture are related to proper installation of windows, flashing, site grading, foundations, rain absorption, roof overhangs, and whole-house ventilation and humidity control.”
TenWolde’s “Five Myths” reflect the fact that there is considerable confusion and misunderstanding around moisture problems. In an attempt to resolve some of those differences and publicize the latest research finings, the FPL has joined with industry-related organizations to establish a Residential Moisture-Management Network. The network will evaluate existing research and develop uniform recommendations for dealing with moisture.
The USDA Forest Service Forest Products Laboratory was established in 1910 with the mission of conserving and extending the country’s wood resources. Today, FPL’s research scientists explore ways to promote healthy forests and clean water, and improve papermaking and recycling processes. Through FPL’s Advanced Housing Research Center, researchers also work to improve homebuilding technologies and materials. Additional information about FPL and its research activities is available at http://www.fpl.fs.fed.us/.
###Source:
Ed the Roofer is offline   Reply With Quote
Old 02-10-2008, 11:00 AM   #2
MJW
Trade: General Contractor, Roofing, siding, windows
I liked the write up here, kind of interesting.
Is any of this "real world" results? All I see is some data collected from lab tests. Is this supposed to actually be taken seriously?
MJW is offline   Reply With Quote
Old 02-10-2008, 12:24 PM   #3
oldfrt's Avatar
I would guess this to be a generalized consensus based on the observations of various observers in remotely different geographical locations!
Did I just say that?
Anyways ,it seems that no one has all the facts for each climate and we all must adapt our own industry standards according to our own observations in the field.
As stated above,
So when I crawled around in an non vented crawl space in the Northeast
in a five year old house, that was full rotten floor joists and thousands of carpenter ants,and I read:
I'm suppose to be convinced this guy knows what he's talking about?
I agree with the lists and basic concept for moisture control,but unseen problems may arise that would call for ventilation of this area.High water tables and underground springs come to mind.
I would say to err on the side of caution here.I've yet seen a vented crawl space that had any moisture problems in this part of the country.
They should do field studied in real life situations,not controlled labs, where the conditions may not reflect every possible combination of structural components.
They want to start with controlled conditions ?With what products?How long will these tests take?
It may be a means to a solution,but by the time they figure out all the variables :
Who knows how many of the original materials tested would have been made obsolete or changed because of the findings of manufacturers?
How long will newer tests take with the newer products.
How many products have we seen introduced to the market in the last 30 years are still being used?Some have been updated,some have become obsolete.
Case in point:
The first spray on insulation,which started as a top of the line remedy for the oil crisis of the 70'sand later became a toxic liability.
Now we have a new spray foam insulation which claims no ventilation needed.
How long was this field tested?
There are probably numerous other products that we all have used over the years that would not fit into today's market.
Every home is different and should be approached as such.
Controlling the indoor humidity levels mechanically should be a secondary approach because of the added cost and consumption of fossil fuels.
So,to say there is any kind of a absolute remedy would be like saying we all wear the same size suits.
There is no warranty, expressed or implied, as to the accuracy, reliability or completeness of furnished data.Information gathered here may be for the sole purpose of entertainment.
oldfrt is offline   Reply With Quote
Old 02-10-2008, 03:37 PM   #4
Al Smith
all homes are different. some observations that you see in one structure and the solutions do not apply to other homes with what seem like similar symptoms but different causes. Lets take oldfrts wet crawlspace for example. Would you say that all unvented crawl spaces are wet? of course not. Something is causing the moisture to arrive in that crawl space to begin with. venting it may or may not help to remove that moisture depending on where the venting is placed. the dew point, The atmospheric conditions of the climate the crawl is in. Is the crawl space getting moisture from a high water table? Is the water table low but the surrounding grading was done poorly? is it sand or shale or clay? Is the conditioned space above completely enveloped in a polyethylene bag? with poly over fiberglass? Is there a dryer vent pipe going through the crawl? Are five kids taking showers twice a day? Is the siding leaking around the windows and moisture finding its way behind the band joist? is a vent stack flange leaking (quite common) and water running down the outside of the stack to the crawl? You need all the data to come to the correct solution. You cannot just assume. things happen for a reason. No laboratory can duplicate every combination of conditions. While some of his views on myths may be correct and i do agree with a lot of what he says. I cannot use that data alone to come to conclusions because his laboratory homes are free of defects.
Al Smith
http://www.awsmith.com
A W Smith is offline   Reply With Quote
Moisture Problem Milhaus Commercial Construction 6 12-26-2007 02:47 PM
Moisture Conditioned Pads Dirtguy Excavation & Site Work 36 01-13-2007 08:18 AM
Acceptable moisture content of unfinished hardwood Grainywood Flooring 2 09-24-2006 07:46 PM
Unfinished home with too much moisture? Steve Unkie Carpentry 20 03-22-2006 11:07 PM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
