Trade: roofing
Tectum Decking
Today my crew tore-off a roof and there was some damage to the decking. When they tore it out it was 3" thick and looked like pressed hay or straw. I called every distributor in my area and discovered it was called Tectum Decking, most had heard of it but none had it in stock. They knew of one guy that could get it and he said there was a 9 piece minimum and cost was $1,100. Panel size (30"x83"x3")
Also it would take 1 week to get the stuff. This panel served as the Deck, Insulation, and Ceiling. Has anyone else encountered this surprise? |
Commercial Roofing
Trade: Roofing Contractor
Re: Tectum Decking
I have used tectum. It was not a surprise because I corethe roof when I measure for bid.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
#3 | |
large member
Re: Tectum Decking
Its used in school gyms all the time for wall panels. Almost indestructable and has great sound absorbtion qualities. Usually in 1" to 1 1/2 inch thickness for wall panels. Try your local ceiling supply house.
Trade: roofing
Re: Tectum Decking
Don't need it now..
I put a 1/2" sheetrock, 2" iso board, and an 1/2 osb. Told homeowner it was no longer available. |
Trade: Roofing, siding, framing
Re: Tectum Decking
Commercial Roofing
Re: Tectum Decking
So you pretty much have no structural support between the purlins?
Trade: roofing
Re: Tectum Decking
Actually it's very supportive
Commercial Roofing
Re: Tectum Decking
What is providing it the structural support?
Trade: roofing
Re: Tectum Decking
Beams are about 16" apart and the Beams are 4" wide.
What would you have done? |
Commercial Roofing
Re: Tectum Decking
Replaced the roof decking?
| Choice composite decking turned into Junk | John Hyatt | Decks & Fencing | 1 | 05-18-2007 12:41 PM |
| Procell decking | jeclarke | Decks & Fencing | 3 | 04-15-2007 01:44 PM |
| How much decking... | ruskent | Pool Construction & Enclosures | 2 | 03-08-2007 08:38 AM |
| Powerwashing composite decking??? | dougchips | Pressure Washing | 3 | 02-12-2007 12:58 PM |
| vinyl decking with hot tub | nriddock | Decks & Fencing | 2 | 06-16-2006 02:10 PM |
