Tear Off Or Shingle Over?
I have the dreaded Certainteed Horizon shingles that have cracking, grain loss and some curling. The curling is pretty minor. Is it OK to just shingle over everything. I only have one layer. They were installed in 1992 on a new construction. Can I just trim off the few corners that are curling or if I single over them wont the weight of the new shingle flatten things out?
Thanks |
Bah Humbug!
Re: Tear Off Or Shingle Over?
Curling means you cant roof over. Sorry. Any imperfection will carry over to the next layer of shingles. Remember the existing shingles will continue to degrade and curl.
#3 | |
Trade: Roofer
Re: Tear Off Or Shingle Over?Quote:
Sunny Southern California
Trust me, stripping is the best way to go.
I just finished stripping my roof with only a couple of layers. I couldn't figure out why my roof looked so bad, now I know. |
Trade: Commercial and Residential Roofing
Tear it off and start over! It will be a little more expensive (new underlayments) and labor intensive, but well worth it.
IF you are dead set on installing over the existing shingles, you should go with a high grade shingle (marketed as 40 and 50 year shingles). |
Trade: Roofing Contractor
Certainteed should compesenate you for at the least the materials minus the ridge, vents, felt, and i/w. In my area of MN Certainteed has hired a person to personally look at the defective Horizon roofs and most people are satisfied when the deal is done which is what a salesman at the lumber yard said.
Tearing off is your only option. Depending on your area it may be expensive but you will have to fight with Certainteed for every penny. |
| Does weight determine how long shingle will last? | shopman | Roofing | 35 | 12-15-2009 08:14 PM |
| Owens corning a solid strip of tar | nolo | Roofing | 26 | 01-29-2008 01:25 AM |
| Shingle color choice | ArnDavis | Roofing | 9 | 07-31-2007 11:08 PM |
| IKO Shingle Failures | BASSP SECRETARY | Roofing | 7 | 03-19-2007 12:29 PM |
| shingle tear offs are ??? | tear off tool | Roofing | 6 | 05-22-2004 05:16 AM |
