Suntuf Install
Old 08-18-2017, 03:08 PM   #1
VinylHanger's Avatar
Rewards Points: 7,596
Suntuf Install
I'm putting together a quote to do a large Suntuf patio roof. I've done smaller ones, but this one is 84 feet with 16 foot panels. I have no idea how long it would take for one guy, or two guys especially since this is the 4 foot panels and we would need to crawl around on top.
Also, is there a screw that predrills itself that is compatible with this stuff. The last one was only 10 x 20 and it drove me nuts predicting.
Any thoughts would be appreciated on time and screwing.
VinylHanger is offline
Old 08-18-2017, 05:00 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,192
Re: Suntuf Install
These self drilling pole barn screws should work right?
A&E Exteriors is offline
Old 08-18-2017, 05:39 PM   #3
Re: Suntuf Install
You are supposed to drill a 1/16th inch bigger hole. Not sure if those will. The only ones I've found that seem to be the right ones are some out of New Zealand.
They are metric, so I wonder if they will stop imperial water?
https://www.bunnings.co.nz/psp-supad...50pk_p00290116
They have a nice big grommet as well. The ones here have small grommets. I would hate to get leaks in a big roof, a small one isn't as big a deal.
Old 08-18-2017, 06:52 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Suntuf Install
..sometimes it's nice to take your time screwing other times fast is good too
Tom Struble is offline
SLSTech (08-18-2017)
Old 08-18-2017, 07:46 PM   #5
Mordekyle's Avatar
Rewards Points: 3,300
Re: Suntuf Install
Gasket head nails work too.
Mordekyle is offline
Old 08-18-2017, 07:58 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 96
Re: Suntuf Install
Predrill all the panels at once...
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
VinylHanger (08-18-2017)
Old 08-18-2017, 11:27 PM   #7
Re: Suntuf Install
Well, crap. Now that you said it, it seems to be the obvious solution.
You'd think after 20 plus years in the trades I would have thought of that.
Sheesh, some days I think it is my first day on the job.
Old 08-18-2017, 11:27 PM   #8
Re: Suntuf Install
Nope, nails void the warranty.
Old 08-18-2017, 11:29 PM   #9
Re: Suntuf Install
Another thing. Do most of you use the plastic wiggle board, or the wood ones. I used the wood ones last time and they didn't match up for jack, as well as half of them splitting. Not tall enough to hold up the flat corrugations. Do the plastic ones fit tighter?
Old 08-18-2017, 11:30 PM   #10
Re: Suntuf Install
Where have you been Mr. Truble?
General Contractor looking for advice, Thank you Dukelewis8719 General Discussion 38 09-26-2015 12:00 PM
Paint walls than install trim? Birdland Bldrs Painting & Finish Work 60 09-08-2015 11:34 PM
Door install with thick exterior foam? iHandy Windows, Siding and Doors 16 09-22-2010 08:47 PM
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 02:36 PM
