Steeper Re-Roof Questions
Old 04-04-2009, 12:04 PM   #1
ARoofing's Avatar
Trade: Roofing
When you are doing a residential re roof on a 6 12 or greater pitch how do you like to set up and start until you have the first few rows done and can put roof jacks in? Do you use ladder jacks, scaffold, pump jacks let me know your tricks for getting those first rows done. Also when doing a steeper re roof do you always just get the shingles ground dropped and carry them up? Last question for this thread is whats the best way to shingle a steep using designer shingles with two guys nailing. When I first started shingling I was told to just rack really steeps ones and don't bother stepping them but with designer shingles the pattern looks awful if you rack them so you more or less need to step it up which I find sometimes makes planning where to put toe boards difficult.
ARoofing is offline
Old 04-04-2009, 12:28 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Re: Steeper Re-Roof Questions
Your trade is listed as roofing and you dont even know how to get started? Something isnt adding up.
This forum is for professional contractors, involved with the building trades day in and out. You might want to go ask your question here:
www.diychatroom.com
Cole is online now
Old 04-04-2009, 12:35 PM   #3
waterman1971's Avatar
6 on 12 is easily walkable.
waterman1971 is offline
Old 04-04-2009, 12:40 PM   #4
I like Green things
WarnerConstInc.'s Avatar
I use a helicopter, just like the loggers.
I got a 42' man lift, piss on ladders and carrying shingles up and down, I am getting too old.
WarnerConstInc. is online now
knucklehead (04-16-2009)
Old 04-04-2009, 12:43 PM   #5
Warren's Avatar
Trade: framing/remodeling
when in doubt I use two very useful tools.
Cell phone and checkbook
Call a roofer, wrire a check
Warren is offline
Old 04-04-2009, 01:55 PM   #6
Lefty H's Avatar
Trade: Roofing
Hi,
Ladder jacks.
Always have the shingles delivered on the roof.
There is always a pattern. I do not strech as far as I can. So putting a jack in a course early does not upset me.
Lefty H is offline
Old 04-04-2009, 02:06 PM   #7
ARoofing's Avatar
Trade: Roofing
Ive been roofing for 3 years (which is not a lot as compared to many of you) and have just started to sub contract off of a larger company. I have roofed hundreds of houses everything I have done though is a 5 12 or less, most homes in the area I live are relatively lower sloped. I was just curious as to how roofers who routinely deal with steeper roofs approach it. Just because I may not have a lot of experience on steeper roofs does not mean I don't know what I am doing.
ARoofing is offline
Old 04-04-2009, 02:49 PM   #8
I like Green things
I was telling the truth on the man lift part.
Before that it was ladder work until jacks then tear off and jack as you go (no smart comments).
Pull off bottom jacks and back to ladders, then jacks after 5 courses, maybe 4. Then your off to the rodeo.
The man lift gets rid of a lot of steps though.
I've done 4/12 all the way to some darn near verticle Gambrel barn roofs.
Average pitch for me 8/12, that pushes my comfort level any more.
Do several 12/12's and steeper each year. The real bitch is sheeting those big ones.
Old 04-04-2009, 03:12 PM   #9
MrRoofer's Avatar
Trade: Roofing
I have known some guys to rope the entire roof, or rope it until the jacks come into play. They would often employ the use of korkers or cleats (tearoff) with big pieces of foam in lieu of kneepads (install), all the while dangling from a rope.
Personally I preferred to ladderjack - then roof jack.
Depending upon the roof design it may or may not be practical to load the shingles rooftop. Most delivery outfits here will not load steeper than 8/12 unless a roofer is onsite to help facilitate the load. Most guys I know tend to like about half the shingles on the roof, and half on the ground.
The main thing is do NOT cheap out on roof jacks, buy lots of them, do NOT stretch, and be sure to put an adequate number of nails into those trusses! (roofing nails have been known to work, but it's not recommended ). Do not skimp on the board you are spanning jacks with either.
Peace of mind goes a long way towards achieving a job well done.
Nailing is easy, follow the instructions, then if it looks bad you are not to blame. Otherwise you end up trying to explain to the homeowner how your cost cutting measures left them an aesthetically unappealing and possibly dysfunctional roof.
'I'm living on the edge!'
MrRoofer is offline
Old 04-04-2009, 04:03 PM   #10
Mod / ArchiBuilder
Cole's Avatar
Oh ok, maybe introducing yourself first would be the best option. We dont really know anything about you, so that is why you got some bs answers at first. Sorry for jumping off the handle about things not adding up, but from our side, it didnt add up at all.
Cole is online now
Old 04-04-2009, 08:23 PM   #11
ARoofing's Avatar
Trade: Roofing
Fair enough, thanks for the help so far this season is off to a bad start we just 2 feet of snow.
ARoofing is offline
Old 04-04-2009, 08:45 PM   #12
Well, now we know you aren't
in Key West.
How about...........
neolitic is offline
Old 04-04-2009, 09:31 PM   #13
Mod / ArchiBuilder
Cole's Avatar
Welcome to the site!
I dont consider steep until 10/12.
If you didnt get the hint, we like for members to fill out there location in their profile.
Cole is online now
Old 04-05-2009, 09:40 AM   #14
Roofer
Slyfox's Avatar
I'll set up ladder jacks and plank than using toe boards first a foot up from the eave, than another row every eight foot or so upward to the ridge,
tear off and felt downward, moving each row of toe boards up onto the newly installed felt as we go, than tear off the very bottom from the ladder jacks/plank, install new i&w and shingles, set up roof jacks, etc.
For me,
Dead Flat - 2/12 'Commercial Grade'
3/12 - 6/12 is Walkable
7/12 - 8/12 is Non Walkable
9/12 and upward is Steep
and my prices differ at each level.
I will roof top deliver when it's possible, but when you get into steep we will almost always set them on the ground and use laborers to carry or a loading ladder.
God, Family, Country, Work, Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline
Old 04-16-2009, 10:20 AM   #15
kodiak_island's Avatar
Trade: remodel retrofit
Send a message via MSN to kodiak_island
www.diychatroom.com
LOL
kodiak_island is offline
Old 04-16-2009, 06:28 PM   #16
J-Peffer's Avatar
Trade: Roofing & Siding Contractor
I'm a big fan of scaffolding.
It takes a little time to setup, but get a few guys on it and it goes real fast.
I leave it up, until the job is done and clean is almost done then. I board the top with 3-2x12's at so your rake is at about waist height.
It takes a little time to setup, but I normally grab one guy, and get it all setup the day before we start. When the labor gets there, guys are walking up the roof with shovels and when the tear off is done, you are working 3' off the ground (scaffolding).
J-Peffer is offline
Old 04-16-2009, 08:55 PM   #17
Ed the Roofer's Avatar
Trade: Roofing Contractor
Ladder Jacks with an aluminum walk plank until you have the first 3 feet or so installed and then toe-boards from that point on, along with fall arrest safety equipmant.
Ed
Ed the Roofer is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 03:03 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 01:55 PM
roof valley Fix-it Carpentry 3 11-12-2007 07:41 PM
