Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing
Old 01-29-2008, 03:20 PM   #1
Trade: remodels
staging on 12/12 pitch
I have to replace metal ridge cap on 12/12 pitch. What is the best setup for a working platform? My hope is to work both sides from one side. This is bush Alaska so access to equipment rental is minimal.
tks
www
woodwoodwood is offline   Reply With Quote
Old 01-29-2008, 04:29 PM   #2
Roofer with a vision :)
coolflatroof's Avatar
Trade: Flat and Metal Roofing
how tall is the roof? can you put ladder to the ridge?.... anyway, post pics, otherwise people don't know what you are talking about
coolflatroof is offline   Reply With Quote
Old 01-29-2008, 04:31 PM   #3
tinner666's Avatar
Trade: Roofer, Remodeler,
I often use 'vise-tongs' to work them. No specifics come to mind. I just do what seems safe.
Frank Yes, I DO sell domains and hosting and Websites.
Slate Repairs, Richmond, Va.
$7.49 .Com Domain Names and Websites
tinner666 is offline   Reply With Quote
Old 01-30-2008, 08:10 AM   #4
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
Depends how tall but if it's a 1 story I often put a 40' ladder leaning against the roof slope and braced against the ground. That's not feasable if it's taller than a 1 story. In that case you probably want to nail up toe-boards spaced not more than 4' apart following the rafter up. Once your at the ridge, ride it like a saddle.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 01-30-2008, 01:28 PM   #5
Trade: roofing
ladders and jacks with aluminum pic at eaves, then roof brackets and planks all the way.
RooferJim is offline   Reply With Quote
Old 02-04-2008, 06:24 PM   #6
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
just curious as to why the pic at the eve? If he is working at the peak all he would need is the fist toe board up and set the ladder on that then run toe boards to peak to work off of. Just seems the the pic is unneeded
Patriot Broadcasting Network
doubleaction is offline   Reply With Quote
Old 02-05-2008, 02:13 AM   #7
Trade: Roofer
Hello,
You should call Spenard Building Supply and see if they can ship you some 2x6 roof jacks. They may cost a little with the shipping but you would have them for any other repairs you need to do in the future.
Depending on the length of your roof(from eave to ridge) and the width should determine how many you would need... one 4 to 6 foot 2x6 starting at the eave using 2 roof jacks. Installing 2x6s every 6 to 8 feet until you get to the ridge area. Then enough2x6 and jacks to go the width of your house. Using a 16 foot 2x6 you should use 4 roof jacks but could get away with just 3.
Hope this is helpful.
Keith
Roofboy is offline   Reply With Quote
water drainage - roof pitch requirement RusRoofingAdmin Roofing 2 11-30-2007 01:09 PM
What is the lowest pitch roof everyone is comfortable with putting in a skylight? mikeybobo Roofing 10 03-03-2007 11:34 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
How to fiqure roof pitch? JPV123 Roofing 13 03-18-2006 01:12 PM
