Square Gutters? - Roofing - Contractor Talk
Square Gutters?
Old 02-20-2018, 06:06 PM   #1
Lettusbee's Avatar
Rewards Points: 2,882
Square Gutters?
I was looking at a window job the other day and the client was asking if I knew where to get square gutters with a square detail about halfway up?
His house was built in 1955 as part of the modern architecture movement, and he wants to maintain that aesthetic. Every gutter company he has contacted will only provide K-style.
I'm not clear at this point what the heck style he is referring to, but I should be able to get pictures soon. Apparently they are somewhat common in Australia.
Thanks
Lettusbee is online now
Old 02-20-2018, 06:09 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,679
Re: Square Gutters?
Thanks
I have seen some square wooden gutters, but they go back a lot further than the 1950's.
Easy Gibson
Warren is online now
Old 02-20-2018, 06:16 PM   #3
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 3,848
Re: Square Gutters?
Like this or no ?
NYgutterguy is online now
Old 02-20-2018, 06:21 PM   #4
Lettusbee's Avatar
Re: Square Gutters?
That might work for him. He is just artsy enough that the fillet angle at the bottom might make it a no go, but I'll see.
Where do you go to get that?
Old 02-20-2018, 06:26 PM   #5
water re-locater
Re: Square Gutters?
Called a box gutter. Comes in different sizes but usually used for commercial so pretty large. My supplier has a machine and makes for me but you might be able to order and have trucked in from someone close to you but would only be 20' sections.
Hard to believe nobody there has a machine for box gutters though
I've never seen a square gutter around here like you're describing
Old 02-20-2018, 06:29 PM   #6
Lettusbee's Avatar
Re: Square Gutters?
My guess is that any commercial roofer/gutter company isn't taking calls from homeowners.
Now that I can almost speak the language, I could hit up the roofing supply house and see if they can point me in the right direction.
Probably should have thought of that first. Hopefully these are available in a 4" or 5" range?
Old 02-20-2018, 07:00 PM   #7
water re-locater
Re: Square Gutters?
Have only seen them in 7"&8". They would look silly on a residence.
Old 02-20-2018, 07:25 PM   #8
Lettusbee's Avatar
Re: Square Gutters?
I was afraid you might say that.
Old 02-21-2018, 11:21 AM   #9
calmod's Avatar
Trade: general contractor
Rewards Points: 188
Re: Square Gutters?
They exist but locating them is the problem. I do mostly modern and mid century stuff so it's been on my radar for a long time. I know we used to use ten foot "box gutters" and do it that way. I finally found a los angeles company that had enough volume to get the heads to run it seamless. Either straight square profile or with the front canted out 10 degrees. I put the canted one on my house. Look for box gutters. I get what the guy is saying the K style look great on lots of houses but not on clean lined modern houses. If I knew how to post pictures I would post a couple
calmod is offline
The Following User Says Thank You to calmod For This Useful Post:
Lettusbee (02-21-2018)
Old 02-21-2018, 03:55 PM   #10
Designer/Contractor
Rio's Avatar
Rewards Points: 2,630
Re: Square Gutters?
To post pictures just go to advanced. click on the paperclip, then browse for your photo(s). The only trick is the files have a maximum of 200kb. If they're bigger than that open with paint and use resize to make them smaller, really easy to do. Once they're less than 200kb upload them and they'll show right up (hopefully).
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
calmod (02-22-2018)
Old 02-21-2018, 05:16 PM   #11
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,214
Re: Square Gutters?
Not sure if you have them down there , but ABC siding has a gutter that looks something like that , although not truly square.
Randy Bush is offline
Old 02-21-2018, 06:35 PM   #12
Lettusbee's Avatar
Re: Square Gutters?
I had looked at ABC's website, and by extension Norandex, but didn't see anything other than K-style and round.
I'll stop in and chat with them though.
Old 02-21-2018, 09:07 PM   #13
Randy Bush's Avatar
Re: Square Gutters?
Try this link www.abcseamless.com/steelgutters This is the style they do here.
Then click on gutters.
Old 02-21-2018, 09:25 PM   #14
Lettusbee's Avatar
Re: Square Gutters?
That's odd. When you say ABC, I think of these guys, https://www.abcsupply.com/ who are a big player in the roofing game here.
The link you provided, is for a different ABC it seems. But they have a store in Cheyenne, and I'll be up there next week and give em a look.
Thanks
The Following User Says Thank You to Lettusbee For This Useful Post:
Randy Bush (02-21-2018)
Old 02-22-2018, 10:45 AM   #15
Fishindude's Avatar
Trade: Industrial
Rewards Points: 454
Re: Square Gutters?
Look at MBCI's online commercial catalog.
They have a couple different square box gutters.
Fishindude is offline
Old 02-22-2018, 10:48 AM   #16
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,467
Re: Square Gutters?
Google quad gutters
WBailey1041 is offline
Recommend a double square for tool belt Spencer Finish Carpentry 20 04-29-2016 10:11 AM
Gutters before facia wrap?? goneelkn Windows, Siding and Doors 84 01-20-2016 05:01 PM
Need help bidding new work by the square foot Dokota Painting & Finish Work 16 01-11-2016 10:45 AM
Mason foundation out of square with existing house jebeltra Masonry 16 08-01-2014 06:39 PM
aluminum or paint grip steel gutters? red_cedar Roofing 17 03-20-2012 09:25 PM
