Spainish Tile - Tips Wanted
Old 10-25-2006, 04:28 PM   #1
ron kugel's Avatar
Trade: slate roofing
Looking for tips on installing Spainish Tile or S tile in Florida- Such as layout - Do you chalk verticals as well as horizontal lines? best way to mud the caps? Dry cut or wet cut saw? valley cuts,best way ect.. Have installed a few up North but 95% of my work is Slate...Thanks, Ron
ron kugel is offline
Old 10-25-2006, 07:44 PM   #2
RooferJim's Avatar
Trade: roofing
Re: Spainish Tile - Tips Wanted
Ludowici will send you a manual that is very helpful but yes you do have to snap vertical and horizontal lines so your locks all line up. I find using "Bulldog Red slaters cement" a lot easier on hips and vallys than colored mortor, for field repairs use the flat bar renail trick as opposed to using those foolish and unsightly clips.
RooferJim
RooferJim is offline
Old 10-25-2006, 10:08 PM   #3
dennis's Avatar
Trade: Roofing
Yes on the lines.
Don't use ring shank copper nails.
Jim, have you tried the Flexim mortar? I have not, as I always mix my own, but I was wondering how it worked.
I use a flat bar for the field also. Take a minute or two to find the old nail hole.
Wet saw on the ground. 5" Bosch for roof details.
I don't do a " lot " of tile. Small jobs and repairs.
dennis is offline
Old 10-25-2006, 10:15 PM   #4
Teetorbilt's Avatar
S-tile or true Spanish? BIG difference! I've done the old Spanish, have nada on the new stuff.
Albert Einstein
Teetorbilt is offline
Old 10-25-2006, 10:53 PM   #5
ron kugel's Avatar
Thanks- For repairs I use the flatbar also to renail(no tabs)--I will send for a manual -- could someone explain procedure for cementing ridges , valleys & hips with mortar & roof cement, seems mortar is the preference in Fla..I will be working in Jacksonville over the winter..--I am in the pittsburgh area most tile roofs here have closures at the ridges,,, valleys are either factory made or open on the spainish tile(most all tile here is Ludowici(spelling?) -have used red roof cement on the hip pcs.where they fit up to the nailer--I have also installed several flat & spainish tile roofs over the years mostly lift and relay after installing new underlayment...just looking for some good tips from guys who do alot of tile.
Old 10-25-2006, 11:09 PM   #6
Teetorbilt's Avatar
ron, lots of new stuff recently. I'm not a roofer but you had better look into it.
Albert Einstein
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
any tile tips? surfsupinhawaii Flooring 6 12-29-2005 01:04 AM
