Snow & Ridge Vents...bad Combination?
Old 01-09-2005, 08:39 AM   #1
findwaldo's Avatar
Well, this is the first winter for my new roof. After much research I increased the intake ventilation (soffits, approx 12 sq. in/ft) and installed a highly recommened ridge vent (Smartridge, 18 sq. in/ft).
We've had a couple moderate snow falls (couple inches to 1/2 foot) in which the roof has done great. When it is below freezing, no melting on the roof!
We had another 1/2 foot yesterday, but this time it seems to have clogged the ridge vent. When it was about 20 out, the snow could be seen melting off the roof. I then checked the attic tempature, and it was close to 40!! I can only assume that the ridge vent has been clogged. I was told that the warm air would make tiny holes for the attic air to escape...I've given it a day but this hasn't happened.
When I did the roof, I sealed the gable vents so I wouldn't short circuit the flow. As suggested I have a soffit and ridge vent system.
I just tried unsealing the gable vents, to see if that will bring the tempature down.
What are people's thoughts about ridge vents and snow?
Thanks
findwaldo is offline
Old 01-09-2005, 10:28 AM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Snow & Ridge Vents...bad Combination?
Did you ever measure the temprature before you installed the ridge vent?
What is the slope of your roof? Anything less than 3/12 and I gurantee it is clogged. Anything between 3 and 6/12 and it's 50/50 Anything greater than 7/12 and it's probably not clogged.
Do you feel air flow in the attic? Light a match and hold it about a foot away fromt he ridge vent. This will tell you if there is any air flow.
Do you have any soffit vents? If not you should have never installed the ridge vent. Ridge vents only work in combination with soffit intake ventilation.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 01-09-2005, 11:38 AM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
The widely accepted formula for intake ventilation is one square foot of net free vent space for every 150 square feet of attic floor space. Same for exhaust ventilation.
You will get some thaw no matter what, you just hope it doesnt thaw faster than it can exit the roof before re-freezing, thus creating ice dams at the eaves
AaronB. is offline
Old 01-09-2005, 11:41 AM   #4
findwaldo's Avatar
Yes, the tempature difference between the attic and outside is currently matching the the days before I improved the ventilation.
The roof is 5 or 6/12 (I can't remember).
I can feel air flow from the soffits...I'll have to try the match trick.
Yes, in fact I improved the soffit ventilation (see original message).
Thanks for your thoughts. I'm going to let the gable vents do their thing for a bit longer today. They have been open for about 3 hours and I haven't see much of a tempature difference. In fact I think the tempature may have gone up (a couple of degrees or so). I don't know if the ridge vent hadn't had a chance to create vent holes (from the warm air) or what. If I don't see any change in temperature in the next couple of hours, I may seal the gable vents up again...
Old 01-09-2005, 11:47 AM   #5
findwaldo's Avatar
I can't recall the numbers, but I'm above the 1/150 ratio. I have a little bit more intake then exhaust.
This is what I've observed for the other snow falls...and I've been pleased with the results. What's different about this one is that icicles have begun to form and there is a bigger tempature difference then average between the attic and outside air.
Old 01-09-2005, 12:14 PM   #6
Commercial Roofing
AaronB.'s Avatar
Did you improve the ceiling insulation?
AaronB. is offline
Old 01-09-2005, 01:47 PM   #7
findwaldo's Avatar
No.
Correct me if I'm wrong. I'm thinking insulation wouldn't have much to do with my issue. We've had colder days, with snow on the roof and the attic temperature has been closer to the outside temp. That's why I'm thinking the ridge vent may have been clogged.
Has anyone experienced a clogged ridge vent before?
Old 01-09-2005, 02:10 PM   #8
Commercial Roofing
AaronB.'s Avatar
The reason I asked is if you blow in insulation (which will improve thermal efficiencies, you will sometimes get insulation blown over your intake ventilation. Also, greater heat loss from the building envelpoe will cause more sever melt, causing more severe ice damming.
What type of ridge vent?
AaronB. is offline
Old 01-09-2005, 02:37 PM   #9
PipeGuy's Avatar
Trade: underground
FYI
Originally Posted by findwaldo
I installed a highly recommened ridge vent (Smartridge, 18 sq. in/ft).
PipeGuy is offline
Old 01-09-2005, 03:15 PM   #10
Commercial Roofing
AaronB.'s Avatar
Ah yes. I have not used this particular ridge vent.
AaronB. is offline
Old 01-09-2005, 05:30 PM   #11
findwaldo's Avatar
I have rolled insulation. When I installed the new soffits this summer, I had a chance to make sure that there was no insulation blockege.
It is on my list to increase the insulation in the attic.
Old 01-09-2005, 10:28 PM   #12
minnesotaroofin's Avatar
Rewards Points: 150
I have not been real comfortable installing ridgevent on any roof and am even more uncomfortable now this is the 5th time i have heard of it plugging up in 3 years.
I would probably make sure you have at least 12 inches of insulation in the attic all heat bypass areas sealed trp door, furnace pipes, recessed lighting etc....Install air chutes between rafters before adding insulation so your soffit vents won't clog. If you still have a problem cut some turtle vents in the back of your house as close to the peak as you can. The have been venting houses 50 years plus.
minnesotaroofin is offline
Old 01-10-2005, 09:23 AM   #13
Grumpy's Avatar
Do not cut additional vents in your house unless you remove the ridge vent. You should NOT mix ventilation types...
which reminds me as soon as the snow melts off tha ridge vent you need to cover your gable vents.
-Grumpy
Grumpy is offline
Old 01-10-2005, 02:21 PM   #14
Commercial Roofing
AaronB.'s Avatar
I agree. I use GAF Cobra vent and never had this problem.
AaronB. is offline
Old 01-10-2005, 05:08 PM   #15
Rewards Points: 150
Sorry yes you shoud remove ridgevent prior to cutting any turtle vents in. The only ridgevent i will use is GAF snow country and only on or above a 7 pitch. with my experience i will still try to convince the homeowner to use turtle vents at the peak unless they have made their mind up to use ridgevent. I just have'nt seen it being used long and often enough. i have seen similar problems including bugs, cottonwood,squrills chewing through it and now snow. Although i have heard about problems that may arise because of snow and a low pitch.
Old 01-10-2005, 06:00 PM   #16
Grumpy's Avatar
What if it is a vaulted/cathedrial ceiling?
-Grumpy
Grumpy is offline
Old 01-10-2005, 08:15 PM   #17
Rewards Points: 150
I have seen a few like this that are truely vaulted ridgevent may be the most economical option. Although most of the houses i have roofed Have Scissor trusses. http://minnesotaroofing.com/24612a.gif There is still room at the top for venting.
I have also seen on some new construction where if it is truely vaulted the space between the rafters is completely filled with spray in foam. I have also roofed houses truely vaulted with 1 inch toungue and groove wood interior held in place by 6x6 beams. this type of vaulting rarely has enough space for insulation and no room for venting we applied 2 layers of 3 inch ISO Than 1x4 firring strips to create air space we left 10 inches space on top and every 10 ft vertical. Installed 1/2 inch plywood Ice and water shingles. Just finished a 12 pitch metro shingle steel roof last week attic was finished we installed 2 inch ISO with 1x4 firring strips then 1/2 plywood but did vent it with ridge vent. We had a hard time venting soffits we did cut holes low into attic space and punched holes between rafters to allow some venting from soffit area.
http://minnesotaroofing.com/before.JPG
http://minnesotaroofing.com/after.JPG
Looks like snow is melting evenly if Ice is still aproblem we may have to find and alternitive for the soffit venting. We hope to finish porch this week
ridge vent versus traditional vents signal15 Roofing 16 02-11-2011 04:16 PM
Snow, Oh Beautiful Snow! Ed the Roofer Off Topic (Non Trade) 3 02-14-2007 04:34 PM
Colorado Snow Storm EZ Rider Off Topic (Non Trade) 28 01-15-2007 10:43 AM
Copper vents -vs- plastic/aluminum shopman Roofing 2 03-01-2006 07:51 AM
Winter Blues in Vermont CE1 Off Topic (Non Trade) 3 02-25-2006 10:35 PM
