Smoke Testing For Leak Detection - Roofing - Contractor Talk
Old 03-06-2018, 11:40 PM   #1
plazaman's Avatar
Rewards Points: 1,204
Anyone ever use smoke testing equipment to detect roof leaks? NYC is becoming popular with roof decks. And that itself presents a challenge when called to address leaks.
Im guess this can be used to detect plumbing leaks as well .
plazaman is offline
Old 03-06-2018, 11:59 PM   #2
Insrepair's Avatar
Trade: Ins Repair
Rewards Points: 18
Re: Smoke Testing For Leak Detection
Why don't you just get a FLIR Camera? They are getting very affordable the last few years. Mine cost $5,000 4 years ago and now for less than a $1000 I could get a better one.
Insrepair is offline
The Following User Says Thank You to Insrepair For This Useful Post:
Tom M (03-07-2018)
Old 03-07-2018, 12:03 AM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,262
I used to sell smoke machines for automotive repairs. They are a tool that has no equal in the auto industry, mostly used for vacuum leaks. To test for water leaks in vehicles the best way is to pressurize the vehicle using the HVAC fan, and in a calm setting blow the smoke over the outside of the vehicle and look for air blowing the smoke away. The last thing you would want to do is fill the inside of the vehicle with smoke as it would...smell. So I would assume houses would be the same way. Therefore you would need a way to pressurize the home, more specifically the attic, which would mean sealing up the vents.
Looking forward to hearing/learning how it works on houses!
Peter_C is offline
Old 03-07-2018, 08:26 AM   #4
rrk's Avatar
Rewards Points: 2,734
Just hire a leak detection specialist, They use cameras and will save you headaches. There are many around the NY area, job I was on had 5 or 6 roofers who could not find the leak until they came. They found it and problem fixed
rrk is online now
Old 03-07-2018, 01:58 PM   #5
plazaman's Avatar
Not going to hire someone to locate a leak . I want to improve my services and invest in the proper equipment to do so .
plazaman is offline
The Following User Says Thank You to plazaman For This Useful Post:
TNTSERVICES (03-08-2018)
Old 03-07-2018, 03:56 PM   #6
rrk's Avatar
The company that I saw used a $50k system to find the leak. Do you have any idea how much smoke you would need inside a building to find such a leak?
And the cost of cleanup of smoke damage?
rrk is online now
Old 03-07-2018, 08:35 PM   #7
plazaman's Avatar
you are thinking about huge buildings. Im talking about residential homes , single fam, brownstones in brooklyn, and manhattan. Its do able.
plazaman is offline
The Following 2 Users Say Thank You to plazaman For This Useful Post:
rrk (03-08-2018), TNTSERVICES (03-08-2018)
Old 03-07-2018, 08:36 PM   #8
plazaman's Avatar
i was looking into flir cameras also ...
plazaman is offline
Old 03-07-2018, 08:47 PM   #9
Insrepair's Avatar
Trade: Ins Repair
Rewards Points: 18
I’ve seen “smoke”testing attempted before. They used a Low Volume sprayer with a fogging agent. The pressure in the cavity was the problem so it was not successful.
rrk (03-08-2018)
Old 03-08-2018, 04:04 PM   #10
rrk's Avatar
The leak that they found where I was working was in a 2 br apt., I think they were charged $600
What is going to make smoke come out of the small openings? increased air pressure which also will disburse the smoke. Ask any fireman how much smoke has to be in a house before it is seen coming through small openings . You would also have to seal any other openings in the walls and floors.
rrk is online now
Old 03-10-2018, 05:00 PM   #11
plazaman's Avatar
What was the name of the company? $600 seems reasonable.
plazaman is offline
Old 03-12-2018, 09:00 AM   #12
HOT... Smells like Money!
talos4's Avatar
Trade: commercial roofing
Rewards Points: 47
We purchased a Flir E5 camera several years ago to aid in leak and wet insulation detection.
I've attached an example for you to see.
In the example, the camera takes two photos at once. One in IR and the other in standard photo format. The example shows a known leak area.
Photos were taken late in the day after sunset on a clear day. The sun was on the roof most of the day. The sun warms the moisture trapped under the membrane and in the insulation therefore showing up as warmer than the surrounding area. The brighter the image the warmer the temp. The suspect area is under the window just off the wall flashings and migrating into the surrounding area.
The standing water on the roof surface shows up as cooler because this area is now in the shade and cooled off.
These photos directed the crew to investigate the area and we found two open seams and a core cut confirmed damp insulation.
talos4 is offline
The Following User Says Thank You to talos4 For This Useful Post:
Peter_C (03-12-2018)
Old 03-13-2018, 05:22 AM   #13
christysk's Avatar
Trade: 12
Rewards Points: 8
Yes! Actually using leak detector is quite complex but gives fantastic results.
christysk is offline
Old 03-14-2018, 01:13 PM   #14
elite-roofing's Avatar
Trade: roofing, remodel
Rewards Points: 80
Never heard of anyone using smoke to find a roof leak. Usually a visual inspection is all it takes to find a roof leak. I would think smoke would not work well as the attic is not air tight enough to get a good read on it. I do like the FLIR idea but to me even that is overkill. I would be amazed if you mis-diagnose on visual by any more than 1%.
Jesse
Elite Roofing
elite-roofing is offline
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Latest ways to prevent cigarette smoke passing through ducts? bob_cntrctr HVAC 13 04-04-2013 10:29 PM
I have a burning question JonM Tools & Equipment 25 02-26-2013 09:08 PM
How to Interconnect Smoke Alarms Between Dwellings for Secondary Suite backyardauto Electrical 17 11-05-2011 01:37 PM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
