Small Space Between Two Skylights
Old 09-14-2009, 02:15 PM   #1
Builder of Stuff
Young_Buck's Avatar
Send a message via AIM to Young_Buck
I am in Vermont, bidding on a roof replacement involving a large skylight. The existing skylight is roughly 6’ x 6’. It doesn’t open, but it does leak like a screen door on a submarine. The owner wants a skylight that A. doesn’t leak and B. opens to allow some hot air to escape the room. A small sunroom with a 6’ square skylight gets pretty damned hot, as you can imagine.
Well obviously, you can’t even buy a 6’ skylight let alone a 6’ skylight that opens. I am discussing replacing it with two smaller units, installed side by side. My concern is that if I place these things side by side with just framing between them, I leave a channel of about 4’ between the two. That’s a great place for snow and ice to build up. And skylights are already leak prone. My instincts tell me that I need to have something like 12” between the two lights. Anyone have input or opinions?
Young_Buck is online now
Old 09-14-2009, 02:20 PM   #2
MrRoofer's Avatar
Trade: Roofing
Re: Small Space Between Two Skylights
Skylights can come in a lot bigger sizes than that.
Don't tell me they don't make custom builds in the good ol US of A anymore...
I would really try and avoid the channel thingy, and track down a reputable skylight maker to suit your needs.
'I'm living on the edge!'
MrRoofer is offline
Old 09-14-2009, 02:25 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Yeah, order the right size and find someone that knows how to install one.
I've never had the flashings leak on me yet.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 09-14-2009, 02:39 PM   #4
TaitINC's Avatar
Trade: Build, Remodel, Roofing, Siding etc...
I know for fact you can call Velux and they will custom size for certain skylights. What is the exact size of the opening? What pitch is the roof? The pitch determines what kind of skylight needs to be installed. Less than 15 degree pitch you will need a curb mounted skylight, over 15 degrees and you can use a deck mounted skylight. (This is based on Velux skylights) Velux sells gang flashing kits for the products as well. This allows you to flash skylights together with one piece. It's just a matter of getting the opening size and fitting them best, if you decide to go that route. If you would rather put on skylight back, just call Velux, or stop a supplier, and see what they offer in the size needed. If you have leakage problems with skylights, you aren’t flashing them correctly. Revise your install method, or brand you’re installing.
TaitINC is offline
Old 09-14-2009, 03:15 PM   #5
Aframe's Avatar
Trade: Carpenter/GC
I second what Tait said,
one of the Veluxs products if you end up ganging stock units
http://www.veluxusa.com/products/res...ofileRoof/EKL/
We have also made up our own channel to sit between the units, just use with the standard flashing kits.
May be easier for the HO to operate smaller units as well as for you to install
May want to go the commercial route if you go for a larger single window
Aframe is offline
Old 09-14-2009, 06:09 PM   #6
Ganged units are easier and cheaper
to repair/reglaze if damaged as well.
Stock sizes make for quicker parts orders.
neolitic is offline
Old 09-14-2009, 11:27 PM   #7
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
I vote Velux too. Roto or Anderson units are inferior with their rubber gasket seals in my opinion.
I've ganged many 21" wide units and build my own channel using coil stock. Just bend a U shaped piece to run the length in between the units. Totally leak proof!
I will build you whatever you want, just draw it on the back of a big enough check.
JamesKB2 is offline
Old 09-15-2009, 02:08 PM   #8
Don't Eat Yellow Snow!
English Roofer's Avatar
Trade: Pro Slater and Roofer
I agree with all above that Velux is the one you want, ive fitted three close together with ready made channel that fits inbetween.
Cheers
' I can resist anything but temptation' Oscar Wilde
www.drroofing.co.uk
English Roofer is offline
Old 09-16-2009, 10:29 PM   #9
Builder of Stuff
Young_Buck's Avatar
See, I called Velux and they told me to call a dealer. I called the local Velux dealer, and they laughed when I asked them if I could get something anywhere near 6'x6'.
I have never installed a skylight that leaked. But a big farking whole in a roof -- well flashed or otherwise -- is not the kind of place to blaze ahead with any kind of "this MIGHT work" plans.
Thanks, everyone, for your inputs. I got an e-mail from the guy today implying that he's going with another contractor so I'm not putting anymore time into it.
Old 09-17-2009, 11:37 PM   #10
21gun's Avatar
Trade: carpenter
Too bad bro, that's happening a lot here lately... but maybe next time. Just remember, mom said there'd be days like this. It cant last forever and next time comes sooner than you think. You got good responses on this one... glad i read it. The biggest skylight i ever installed was a Velux 4'x8' fixed. And i swear to god i put it up on the roof by myself. was a 7 foot gutter height from the wrap around deck on a gambrel roof... i used a couple 2x4's and some leverage, a prop and a bunch of prayers... wish i had that on video too!!!!
carpet? no, we dont do carpet.
No sir... that spells CARPENTER.
21gun is offline
Old 09-21-2009, 03:52 PM   #11
Bah Humbug!
Grumpy's Avatar
I tried posting this the other day but it would not work. This photograph is of some skylights we isntalled on a project in Riverwoods, IL. Previously it was a 9' wide curb that was a tremendous ice dam since water ice and debris could not drain around the skylights.
What got some custom sized velux FCM skylights and built up curbs, then did a custom skylight flashing between the skylights creating a channel for water, snow and debris to drain. This is especially helpful in our Chicago winters.
Grumpy is offline
Old 09-21-2009, 03:55 PM   #12
Bah Humbug!
Grumpy's Avatar
Young buck your dealers are idiots. Velux will make skylights 72" x 72" in the FCM series. By my math, that's 6' x 6'.
I've called and got quotes from Velux on many occassions and all they did was fax the quot to my supplier who added on their markup LOL. But I do this when I need a price for something specialty, since I often know more about the skylights than my suppliers.
Grumpy is offline
Old 09-21-2009, 04:04 PM   #13
Did you look on the Velux website?
This interweb stuff is keen.
neolitic is offline
Old 09-25-2009, 12:44 PM   #14
tccoggs's Avatar
Being that they are made on LI, Insula Domes are the most common brand around. They are excellent units with a welded Aluminum frame and heavy soldered copper flashing. They will probably make anything you want as well. I have probably installed about 30 of them over the years with not 1 callback.
http://www.insula-dome.com/
tccoggs is offline
Small towns & contracts furstclass General Discussion 16 01-30-2009 12:28 PM
Small bathroom I just finished shanekw1 Remodeling Picture Post 12 01-03-2009 12:32 PM
Best small tool? shanekw1 Tools & Equipment 24 12-30-2008 12:31 AM
Billing on small jobs Philly Dude Business 14 11-16-2008 04:25 PM
A small cut dormer roof from the UK djmesh Carpentry Picture Post 15 10-11-2008 05:10 AM
