Small Rake Trim Folds - Roofing - Contractor Talk
Old 01-05-2016, 11:19 AM   #1
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Building Contractor
Rewards Points: 1,380
Ok I'm trying to get the folds right on the small rake trim for the gable ends.
We used to never bend them...
The one on the left is finished?!? And the one on the right is prepped but am I doing it wrong? It just doesn't look right to me. Anyone have any pics to compare and possible pointers?
Thanks!
Builders Inc. is offline
Old 01-05-2016, 11:24 AM   #2
Re: Small Rake Trim Folds
And some moderator please change the topic to small "rake"
Stupid auto correct...
Old 01-07-2016, 07:11 AM   #3
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,574
I don't think there is a "right" way. A wrong way would just be one that looks bad.
I don't think there is a way to fold it to make it look great. Neatly cut and folded, as you have is about what you can expect.
I don't do a ton with that type of trim, but I do the fold on the rake at a plumb angle.
Another way to close odd intersections (not just capping rake trim) is to cut a cover piece to fit from a scrap pan or sheet. leaving extra to fold tabs, the piece can be riveted or zip screwed in place.
Above all, a good roof
Mr Latone is offline
Old 01-07-2016, 07:26 AM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
yea..i don't understand what your trying to cover,usually there would be a return peice on the eave that will cover the end..any pic of the gable?
Tom Struble is offline
Texas Wax (01-07-2016)
Old 01-07-2016, 08:23 PM   #5
I ended up making a few more cuts here and there. It's just rake going over a gable end of a roof. It's at the bottom. I think I am going to take the two tabs I have and make the outside one about an inch longer and fold it back under crimping it to the underneath piece like a hem. I couldn't get the folded tabs to lay completely flat just folding them over one another. The jobs over. I'll have to get pics of the next one I do.
The Following User Says Thank You to Builders Inc. For This Useful Post:
Tom Struble (01-07-2016)
Old 01-07-2016, 09:53 PM   #6
FrankSmith's Avatar
Rewards Points: 4,750
I would love to see where these go. I was thinking on the rake of a building with a steel roof. Otherwise I can't think of any situation on house where these would go. Do all those bends get covered by an overlapping piece of eave trim?
FrankSmith is offline
Old 01-07-2016, 10:03 PM   #7
It's trim for the gable end of a house, steel roof. Ridge cap goes over it. It covers the drip edge gable ends. Exposed fasteners.
Old 01-07-2016, 11:21 PM   #8
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,110
For what you are trying to do the one on the left look as good as it can get IMO. Personally I don't like putting steel over shingle nor leaving the drip edge on. If I had to leave the shingles on for some reason I would get rid of the drip edge so I could use regular gable trim. Nicer look IMO .
Randy Bush is online now
Old 01-08-2016, 06:59 AM   #9
Been around
Mr Latone's Avatar
Trade: Roofing
Thanks!
OK with the folds you have made there are two slight improvements you can make.
1. As I mentioned a fold the follows the plumb angle on the side that drops down the wall.
2. Don't don't cut off the small little angle. Instead leave a tab to fold. This tab will clean up the raw edge and look better. I can see if I have a piece of corner trim laying around and I could post a pic later.
I don't know where you get you supplies, but have you ever seen the Denver Rake Trim? It might be an option if available.
Old 01-08-2016, 10:11 PM   #10
FrankSmith's Avatar
Its to big of a profile for residential. Try one like this.
http://www.menards.com/main/building...75197415958741
On pole barns and sheds those don't get folded over they just get ran past. It looks cleaner.
Old 01-08-2016, 10:30 PM   #11
They call that here rake eve. What I'm using is smaller called small rake. They also have a large rake. It depends on gable size. If it's huge commercial I'll go large rake or rake eve. But small jobs and small gable ends I'll use small rake. It's proportionate to the structure.
Old 01-08-2016, 10:31 PM   #12
Right on! I would love to see a pick. I noticed aster I trimmed the corner edges I could have folded instead. I'll try to do that next time. Thanks!
Hardie trim vs Azek trim JerseyJ General Discussion 13 08-21-2015 05:09 PM
Furring out exterior trim Cache Carpentry 13 07-31-2014 09:03 PM
Trim prep nakarsten Painting & Finish Work 20 08-11-2012 07:40 PM
How would you approach this Azek trim project ? plazaman Finish Carpentry 42 07-05-2012 01:51 PM
Trim detail sans fascia crovello Carpentry 19 10-28-2009 08:01 PM
