Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof
Old 07-04-2008, 01:11 PM   #1
Tampa
Roof Cleaning's Avatar
Trade: Roof Cleaning
Slate Roof Cleaning Tampa FL - Using Lift
Here is a Slate Roof we just did in Tampa using an Articulating Boom Lift.
You will see Rich, our ground man, adding some of the New Envirospec Roof Cleaning Additive.
It worked good, smelled better then the normal mix alone.
Slate Roofs can not be walked on, if they are thin.
They require only shingle roof strength chemical.
We thought we were going to have problems getting the lift through the gate, and it was touchy operating it in the back of the house. The back of the house has a pool, jacuuzi, trees, etc, etc.
This 10,000 Sq Ft home belongs to a Famous Athlete.
To respect his privacy, his name will not be revealed.
Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-25-2008-7-14-24-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-6-06-10-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-6-04-41-am.jpg
Apple Non Pressure Roof Cleaning Tampa
Roof Cleaning is offline
Old 07-04-2008, 01:13 PM   #2
Tampa
Re: Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof
More Roof Cleaning Pictures
Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-6-42-30-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-7-14-53-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-7-33-13-am.jpg
Old 07-04-2008, 01:17 PM   #3
Tampa
More Cleaning Roof Pictures
Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-8-12-22-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-9-36-11-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-8-24-15-am.jpg
Old 07-04-2008, 01:21 PM   #4
Tampa
More Before And After Roof Cleaning Pictures
Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-6-50-46-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-6-56-53-am.jpg   Slate Roof Cleaning In Tampa FL - Using Lift To Clean Slate Roof-tile-roof-cleaning-tampa-fl-2-26-2008-8-24-15-am.jpg
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Roof woes hobbyguy2002 Roofing 12 01-29-2008 01:29 AM
Cutting Roof Slates VA Remodeler Roofing 9 08-15-2007 01:01 AM
Clean slate ron schenker General Discussion 11 04-20-2007 07:29 AM
white residue on slate roof BChester Roofing 1 01-23-2006 11:55 PM
