Trade: Home renovation and construction
Skylight In Metal Roofing
Does anyone know what is the best method to flash around a Velux skylight, 2' x 4', in a metal roof? The slope is 6:12. The roof is sheet metal, full length of the roof.
thanks for your input |
Trade: Residential remodel
Re: Skylight In Metal Roofing
If there are no ridges, I would make a 2x4 or 2x6 curb for the skylight to sit on and have a sheet metal shop make a flashing all the way around it then seal it to the sheetmetal with something like Vulkem polyurethane caulking. Just my 2 cents.
Rj |
Home Depot aisle walker
Trade: home remodeling
Re: Skylight In Metal Roofing |
Trade: GC/Remodeling
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein Last edited by TimelessQuality; 06-17-2009 at 09:44 PM. |
Trade: siding
skylite install in a metal roof can be a very tricky install,you just cant dam up the panel ribs and expect a good result
Tom |
I though about this after having a commercial roof installed on my home. All that I could come up with was having an adapter plate made of StarBoard machined to fit.
On something like a V crimp you can make up something with a tablesaw and some custom jigs. The material is expensive and you don't want to make a mistake.
Trade: siding
Tom |
Velux has flashing kits for metal roofing, and they are very expensive, about the same price of the skylight when I bought them about 10 years ago.
Mickey
Trade: residential remodeling
I am going to be putting in a Velux skylight with a metal roof in the near future. I have talked with everyone I know and everyone says it a PITA. I don't understand why the metal companies don't make something that would work, what with all the steel roofing starting to be installed on residential, but they don't. And by the way the flashing kit for a Velux still costs more than the window, and it only works for flat mount. The size window I'm replacing only comes as a curb mount. :-) The metal company says to use pitch break, but I'm not sure if that's the best way. Still researching it.
I always learn more by listening that I do by talking. |
Trade: siding
every metal panel manufacturer has a skylight detail
Tom |
this is a typical way with a curb then the skylight goes on the curb
Mickey
That may be true for standing seam metal, but a Metal Sales Corp. rep told me they do not make a flashing kit for Propanel II steel.
Thats because you have to make it yourself
| The Following User Says Thank You to Patrick For This Useful Post: | Tom Struble (06-18-2009) |
#14 | |
Trade: siding
Re: Skylight In Metal RoofingQuote:
Tom |
Trade: Roofer
Hello,
Here are some skylight details on a roof and walls we did about 3 years ago. http://s198.photobucket.com/albums/aa38/RoofinAk/ We have our own sheet metal shop so that helps. Also the Velux metal kits look like a**.(IMO) Keith Last edited by Roofboy; 06-19-2009 at 02:45 AM. Reason: Adding info |
#16 | |
Trade: siding
Roofboy very nice
Tom |
#18 |
Bah Humbug!
Velux makes a line of self flashing skylights which are very suitable for metal roofing applications.
#19 |
Trade: Certified Roofing Contractor
2x6 curb with Z-flashing around the bottom and sides, the top gets an small pan under with a large pan over sealed with butyl and the panels are ran over top of the pan but leaving about 10" space so the ribs don't damn water... same process with Off Ridge vents... the 2x6 frame gets peel-n-sealed to the roof also.
#20 |
I custom make my own full lenght panels for steel roofs.
Frank Slate Roof Repairs, Richmond, Va. |
| The Following User Says Thank You to tinner666 For This Useful Post: | Tom Struble (06-24-2009) |
| Metal Roofing question? | fullhouse | Roofing | 9 | 07-01-2011 10:32 AM |
| Metal Roofing | N.O cont | Roofing | 8 | 11-02-2009 08:18 PM |
| metal roofing on interiors???? | nightingalematt | Roofing | 17 | 06-24-2009 10:20 AM |
| Metal Roofing Machine? | Markon | Roofing | 8 | 03-27-2009 10:37 PM |
| Metal roofing Help | The Boys | Roofing | 9 | 08-22-2008 09:28 PM |
