Skip Sheathing Layout
Old 04-27-2010, 03:20 PM   #1
Joe Wood's Avatar
Rewards Points: 520
I'm trying to figure out how to layout skip sheathing, using cedar shingles at 5" exposure. This looks pretty good, just layout the sheathing at 5" OC, but then there are only 1 1/4" spaces between the 1x4s, and it seems to me that other skip sheathing I've seen has much wider spaces between boards.
How about the sheathing overhanging the rafter tail by 1/2", and the shingles overhanging another 1", would this change the sheathing layout at the eaves?
Am I on the right track?
Skip Sheathing Layout-skip-shething1.jpg   Skip Sheathing Layout-skip-shething2.jpg
https://woodsshop.com/
Joe Wood is online now
Old 04-27-2010, 03:23 PM   #2
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Re: Skip Sheathing Layout
I have seen cedar roofs with up top 8" exposure, so that may account for it.
AaronB. is offline
Old 04-27-2010, 04:19 PM   #3
Kent Whitten's Avatar
Rewards Points: 2,040
If you intend on leaving it at 5" exposure, then your space will be 1-1/2".
Assuming a 3-1/2" wide board.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 04-27-2010, 04:30 PM   #4
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Rewards Points: 708
1x2 or 1x3 batts are fine also if you trust your layout abilities.
Renegade is offline
Old 04-27-2010, 08:40 PM   #5
Joe Wood's Avatar
Rewards Points: 520
OK fellas, thought I was on the right track. Things often seem complicated when you haven't done them before. Thanks for the help!
Rigid Foam Board under sheathing milfordtom General Discussion 27 09-10-2012 04:37 PM
Sheathing gap at corners LetItBeLEED Windows, Siding and Doors 5 03-24-2010 06:28 AM
Sheathing bad? KennMacMoragh Remodeling 3 01-10-2010 07:53 PM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 12:55 PM
Need Help w/ a Bathroom, closet, and laundry layout in addition TurnkeyConst Remodeling 8 12-15-2008 11:50 PM
